IP-EIGRP(Default-IP-Routing-Table:1):
Answered Question
Jan 11th, 2012
I have cisco 6509. Gateways vlan 1 10.1.1.1 and vlan 2 10.1.2.1 are configured two here. In addition to these there are vlan and others, and with them everything is OK. Everything works, but that's falling out such messages.
IP-EIGRP(Default-IP-Routing-Table:1): Neighbor 10.1.2.1 not on common subnet for Vlan1
IP-EIGRP(Default-IP-Routing-Table:1): Neighbor 10.1.1.1 not on common subnet for Vlan2
Read here http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a0080093f09.html to no avail.
what to do?
Correct Answer by rizwanr74 about 5 years 1 month ago
Check the EIGRP peering neighbor whether are the on the same subnet.
Overall Rating: 5 (1 ratings)
rizwanr74 Wed, 01/11/2012 - 06:20
What is that you are trying to accomplish, default-route failover ?
Peter Paluch Wed, 01/11/2012 - 06:29
Sergey,
The router is telling you that it is receiving EIGRP Hello packets from routers that do not belong to the same IP subnet as the interface on which the Hello packets were received. This is always a sign of a misconfiguration.
Would you mind posting the configuration of your interfaces Vlan1 and Vlan2?
Best regards,
Peter
Sergey Prishchepa Wed, 01/11/2012 - 06:35
interface Vlan1
  ip address 10.0.3.1 255.255.255.0 secondary
  ip address 10.1.1.1 255.255.255.0
  ip helper-address 10.1.10.2
  ip helper-address 10.1.10.3
  no ip redirects
  ip flow ingress
interface Vlan2
ip address 10.0.2.1 255.255.255.0 secondary
ip address 10.1.2.1 255.255.255.0
no ip redirects
no ip unreachables
ip flow ingress
I understand that the switch to the wrong address swears in packages, but I can not understand how to take these wrong packets?
Peter Paluch Wed, 01/11/2012 - 06:42
Sergey,
Thank you. As you can see, the complaints are absolutely logical: your Vlan1 is in 10.1.1.0/24 while the EIGRP peer is addressed with 10.1.2.1, and your Vlan2 is in 10.1.2.0/24 while the EIGRP peer is addressed with 10.1.1.1.
Either the two offending EIGRP routers are connected to wrong VLANs (they should be exchanged), or they are misconfigured and their IP addresses are erroneously reversed.
Best regards,
Peter
Correct Answer
rizwanr74 Wed, 01/11/2012 - 06:32
Sergey Prishchepa Wed, 01/11/2012 - 06:45
I've found - from the network 10.1.2.0/24 had two connections and one of the ports was in vlan 1. Thanks for your help.
Related Content
