IPSec tunnel and policy NAT question
Jan 11th, 2012
Hello All!
I have a router acting as VPN gateway on my end and I need to implement NAT translations on my IPSEC tunnel as follows:
1. I need to translate incoming IP address of the remote end of IPSec tunnel to some other IP address on our end
2. I need to translate outgoin IP address of our end of IPSec tunnel to a different IP address
I have impemented following configuration, but for some reason it is not working, I get packets decrypted on my end, but dont have packets encrypted to send to the other end.
Here is the configuration
Remote end  crypto interesting ACL:
ip access-list extended crypto-interesting-remote
permit ip host 192.168.1.10 host 10.0.0.10
My end configuration:
interface GigabitEthernet0/0
ip address xxx.xxx.xxx.xxb yyy.yyy.yyy.yyy
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
crypto map VPN
ip access-list extended crypto-interesting-local
permit ip host 10.0.0.10 host 192.168.1.10
interface GigabitEthernet0/3
ip address 172.16.0.1 255.255.255.0
ip nat inside
speed auto
ip nat inside source static 172.16.0.20 10.0.0.10   (to translate loca IP address to the one on the crypto-interesting list - exposed to the remote peer - it works)
ip nat outside source static 192.168.1.10 192.168.168.10 (to translate remote IP address to some other IP address on our end - not working - I get packets decrypted, but no packets encrypted)
ip route 192.168.168.10 255.255.255.255 gigabitethernet 0/0
ip route 0.0.0.0 0.0.0.0 xxx.xxx.xxx.xxa
All the routes are set, crypto ipsec tunnel is up and working and I am wondering if this is possible to achieve two-way NAT translation ?
Any response highly appreciated!
Thanks!
Ruterford Thu, 01/12/2012 - 08:21
Figured that out.
The problem was in route
should be next-hop IP address instead of interface gigabitethernet0/0
Apparently packet arrives on the interface but does not pass it, when having route like this, becuase there is no one sitting with 192.168.168.10 ip address on the outside
