Outbound BGP routing pref
Jan 12th, 2012
We currently have dual routers with dual ISPs. We use AS_Path prepends to prefer one link over another inbound. I have seen the use of BGP communities to ensure the outbound uses the same path. We can't load balance because some applications we use do not "play well" when they are asynchronous. My question is which is best for outbound routing to use only one path?
Doug
JohnTylerPearce Thu, 01/12/2012 - 08:00
  • Silver, 250 points or more
So is this a correct interrupration of your network topology?
(Internal Network)---->R1---->BGP---->ISP1
(Internal Network)---->R2---->BGP---->ISP2
Since you have applications that don't play well with asyncrhonous links, then how is your
default routing setup, since you have two different ISPs?
Depending on how your AS's are structured between the two ISPs, you could use the LOCAL_PREF
attribute.
Douglas Bradfield Thu, 01/12/2012 - 08:14
We accept the default bgp route from each ISP. Your network topology is correct. We have our ASN and go to each ISP on their ASN. Check this config for my routers and see if you agree: R2 is my preferred path.
R1 ISP1
router bgp 10000
no synchronization
bgp log-neighbor-changes
network 1.1.1.0 mask 255.255.255.0
network 2.2.2.0 mask 255.255.255.0
timers bgp 5 15
neighbor 7.7.7.7 remote-as 50
neighbor 7.7.7.7 ebgp-multihop 255
neighbor 7.7.7.7 version 4
neighbor 7.7.7.7  soft-reconfiguration inbound
neighbor 7.7.7.7 route-map Verizon-INET out
ip as-path access-list 1 permit ^50$
access-list 10 permit 1.1.1.1.0 0.0.0.255
access-list 10 permit 2.2.2.2.0 0.0.0.255
route-map Verizon-INET permit 1
match ip address 10
set as-path prepend 10000 10000 10000
set local-pref 80
R2- ISP 2
router bgp 10000
no synchronization
timers bgp 5 15
neighbor 5.5.5.5 remote-as 75
neighbor 5.5.5.5 ebgp-multihop 255
neighbor 5.5.5.5 version 4
neighbor 5.5.5.5  soft-reconfiguration inbound
neighbor 5.5.5.5 route-map Verizon-INET out
ip as-path access-list 1 permit ^75$
match ip address 10
set local-pref 150
Douglas Bradfield Thu, 01/12/2012 - 08:17
R1 ISP1
router bgp 10000
no synchronization
timers bgp 5 15
match ip address 10
set local-pref 80
R2- ISP 2
router bgp 10000
no synchronization
timers bgp 5 15
match ip address 10
set local-pref 150
rsimoni Thu, 01/12/2012 - 08:33
  • Cisco Employee,
Doug,
LP 150 is preferred over 80, that is true but....
1) You need to apply the route-map in ingress direction as LP is an attribute LOCAL to the AS (yours)
2) More important you miss the iBGP session between R1 and R2. Without that every router will take routing decision on its own, meaning that each of them will use its default towards its ISP link.
Riccardo
Douglas Bradfield Thu, 01/12/2012 - 08:39
iBGP is on there currently, I just didn't add it to the example. So the route-map with both the prepends and the local-pref needs to be "in"?
rsimoni Thu, 01/12/2012 - 08:45
  • Cisco Employee,
well, no.
the prepend goes in outside direction (sorry I missed it earlier on) and the LP in ingress.
So you need 2 route-maps, i.e Verizon-INET-out with prepends and Verizon-INET-in with LP.
Riccardo
rsimoni Thu, 01/12/2012 - 07:56
  • Cisco Employee,
Hi Doug,
local preference is the best option (iBGP between your routers is required).
second best is the use of weights on both routers (iBGP needed as well).
Riccardo
lgijssel Thu, 01/12/2012 - 08:47
  • Red, 2250 points or more
The first two attributes are weight and local_pref.
Personally I prefer the latter.
regards,
Leo
rsimoni Thu, 01/12/2012 - 09:16
  • Cisco Employee,
please rate and close the question after you test it out on your routers
Riccardo
