Check IOS version on a standby Sup on Cat6500
hanwucisco
I wonder whethere it is possible to check the the IOS version on the standby sup720 of a 6500? if yes, what command would you use?
thanks,
han
5 Replies 5
rsimoni
you can check with
show redundancy
or
remote command standy-rp show version
Riccardo
don't forget to rate and close question if helpful
Reza Sharifi
If SSO is configured correctly then try "sh redu"
This command will tell you the IOS on the active and stand-by sup
Reza,
I was troubleshooting an error. It says redundancy mismatches. When I used the command you recommanded, i could not find anything that showed mismtach. any idea?
Please look at the results from the attached file.
thanks,
Han
Han,
Your Sups are in SSO mode.  The primary is active and the stand-by is Hot.  You are also running the save version of IOS on both sups.  Everything looks good.  I am not sure why you had that error.
why don't you print the message you got? you are way too vague
