Cannot Ping www.google.com but the Internet works
Jan 12th, 2012
I have recently made some chages to my ASA 5510 (not sure what) I was previously able to ping www.google.com, and I am now not able to ping anything on the Internet, but The Internet connectivity work perfectly. What can I do on my ASA to resolve this?
varrao Thu, 01/12/2012 - 14:37
Yes that is correct:
ciscoasa(config)# policy-map global_policy
ciscoasa(config-pmap)#  class inspection_default
ciscoasa(config-pmap-c)# inspect icmp
It should work after this
Varun
cjsunderland Thu, 01/12/2012 - 14:42
hou-fw(config)# policy-map global_policy
hou-fw(config)# class inspection_default
hou-fw(config-cmap)# inspect icmp
ERROR: % Invalid input detected at '^' marker. hou-fw(config)# class inspection_default
This is what I get
varrao Thu, 01/12/2012 - 14:58
Hi Chris,
Not sure if you have a policy-map global_policy configured, you can chcek that by the command:
show run policy-map
Chcek what policy-map do you have, under that policy map you would have a class map as well, go into that and then do inspect icmp.
Like mine has:
  inspect dns preset_dns_map
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
So I do:
Another way to do it would be to allow the ping replies on the ACL that you have applied on teh outside interface, for that you need to first chcek the name of the access-list that is applied on the outside interface, first do:
show run access-group
it shoudl do:
access-group outside_in in interface outside
then add the acl:
access-list outside_in permit icmp any any
and it shoudl start pinging after that.
Varun
cjsunderland Thu, 01/12/2012 - 15:08
I have
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect pptp
varrao Thu, 01/12/2012 - 15:36
Then you just need to get into the policy-map and then class and apply the inspection.
ASA(config)#policy-map global_policy
ASA(config-pmap)# class inpsection_default
ASA(config-pmap-c)# inspect icmp
If this does not go right then may be somewhere something is not done correct or you can also try my ACL suggestion.
PS - Have a look at the things that I have in bold, you shoudl get the same while using the commands.
Varun
varrao Thu, 01/12/2012 - 14:22
Hi Chris,
can you add "inspect icmp" in the policy-map and try again??/
   inspect icmp
let me know if it works after this.
Varun
Related Content
