awinter2 Thu, 01/12/2012 - 22:52
  • Silver, 250 points or more
Gavin,
in addition to the document which Jens linked to, I would recommend that you read the document "
Cisco TelePresence Video Communication Server IP Port Usage for Firewall Traversal Deployment Guide (X4 to X7)" which is available in the 'Configuration guides' section for the VCS at www.cisco.com/support.
Andreas
gavin han Mon, 01/16/2012 - 13:38
Thanks All. do we have to open up any ports from VCS expressway to VCS control?
I could't find it in the doc.
Jens Didriksen Mon, 01/16/2012 - 16:34
  • Blue, 1500 points or more
Take a look at the firewall traversal section in the admin guide:
http://www.cisco.com/en/US/docs/telepresence/infrastructure/vcs/admin_guide/Cisco_VCS_Administrator_Guide_X7-0.pdf
The basic deployment guide has also some fw info:
http://www.cisco.com/en/US/docs/telepresence/infrastructure/vcs/config_guide/Cisco_VCS_Basic_Configuration_Cisco_VCS_Control_with_Cisco_VCS_Expressway_Deployment_Guide_X7-0.pdf
also, if you log in to the VCS-C and the VCS-E through the web GUI, go to
Maintenance --> Tools --> Port Usage and you'll get a choice of "Local VCS Inbound ports", "Local VCS Outbound ports" and "Remote Listening ports".
Garvan Long Thu, 01/19/2012 - 19:18
No ports need to be opend from Expressway to Control
The VCS Control opens connections to the Expressway and these are maintained with a keep alive.
