VPN Tunnel is not establishing on Site to Site VPN on Router RV220W
Jan 14th, 2012
I have recently bought two CISCO routers RV220W for our main and brach office mainly for VPN tunneling. I didnt know they are routers only not modems. so I have set it up using BT 2wire Router as modem only.
I have successfuly setup the routers and manage to establish the VPN tunneling between two routers.
AS bt doesnt give static WAN IP address so I have used Dyndns which works fine. although I have 5 static ip address which cannot be used for WAN unless i cahnge to one IP address even then BT tech said it will not work.
when I created the tunnel i could ping both servers with their IP only not with the names. I can ping them fine locally. I could also see the network from branch office to main office but not from main office to branch office. today when I restarted the server I cannot ping both server i mean vice versa but VPN tunnel is established. now I cannot see the network from branch office to main office as well.
both sites running windows server 2008 standard. main office server has 6 NIC cards two wwith public and three with private ip addresses, its also runing Terminal server, exchange, file etc. the branch office has two NIC card one with private and one with public ip.
intially I could establish the VPN tunnel as the network range was same on both sites so I changed one in th e10.0.0.0 range other in 192.168.1.0 range and VPN tunnel was established straightaway.
As soon as the VPN tunnel was created I manage to creat an external trust without any problems and both servers are added in each other forward zones as name servers.
in the main office the fues went off and I had to re-start the router and now the VPN tunnel is not establishing, mainly the error is ISAKMP-SA Expired I will paste the log of both routers below
Now I need your help.
1. How to Clear Old or Existing Security Associations (Tunnels) on RV220W
2. how to fix the problem where I can ping the server with their IP as well as domain names ?
3. how to set it up so that both sides can see the network resources as well as access it ?
4. how to set it up so if the staff in branch office wants to log on the domain in main office he can simply do it as he does it in his office.
I can remote desktop both servers without any problems.
I have rebooted both servers few times, I have changed the share key, I also deleted the old setup and created new on both server but still no luck
Any urgent help will be appricated
caveatsolicitors Sat, 01/14/2012 - 15:41
Router1 log
2012-01-14 09:23:03: [rv220w][IKE] INFO: Sending Informational Exchange: delete payload[]
2012-01-14 09:23:04: [rv220w][IKE] INFO: ISAKMP-SA deleted for 197.127.128.1[500]-197.143
.198.1[500
] with spi:9dd3d5f20fabee3d:2bc2b
c5c6660437
f
2012-01-14 09:23:12: [rv220w][IKE] INFO: remote configuration for identifier "router1.vpn.com" found
2012-01-14 09:23:12: [rv220w][IKE] INFO: Received request for new phase 1 negotiation: 197.127.128.1[500]<=>197.1
43.198.1[5
00]
2012-01-14 09:23:12: [rv220w][IKE] INFO: Beginning Identity Protection mode.
2012-01-14 09:23:12: [rv220w][IKE] INFO: Received Vendor ID: RFC XXXX
2012-01-14 09:23:12: [rv220w][IKE] INFO: Received Vendor ID: draft-ietf-ipsec-nat-t-ike
-02
2012-01-14 09:23:12: [rv220w][IKE] INFO: Received Vendor ID: RFC 3947
2012-01-14 09:23:12: [rv220w][IKE] INFO: Received Vendor ID: DPD
2012-01-14 09:23:12: [rv220w][IKE] INFO: For 197.143.198.1[500], Selected NAT-T version: RFC 3947
2012-01-14 09:23:13: [rv220w][IKE] INFO: Received Vendor ID: KAME/racoon
2012-01-14 09:23:13: [rv220w][IKE] INFO: NAT-D payload matches for 197.127.128.1[500]
2012-01-14 09:23:13: [rv220w][IKE] INFO: NAT-D payload matches for 197.143.198.1[500]
2012-01-14 09:23:13: [rv220w][IKE] INFO: NAT not detected
2012-01-14 09:23:13: [rv220w][IKE] INFO: ISAKMP-SA established for 197.127.128.1[500]-197.143
.198.1[500
] with spi:43e947c9f4344673:8059b
360776508e
9
2012-01-14 09:23:13: [rv220w][IKE] INFO: Sending Informational Exchange: notify payload[INITIAL-CONTACT]
2012-01-14 09:23:13: [rv220w][IKE] INFO: ISAKMP-SA expired 197.127.128.1[500]-197.143
.198.1[500
] spi:43e947c9f4344673:8059b
360776508e
9
2012-01-14 09:23:13: [rv220w][IKE] INFO: Sending Informational Exchange: delete payload[]
2012-01-14 09:23:14: [rv220w][IKE] INFO: ISAKMP-SA deleted for 197.127.128.1[500]-197.143
.198.1[500
360776508e
9
2012-01-14 09:23:33: [rv220w][IKE] ERROR: Phase 2 negotiation failed due to time up waiting for phase1. ESP 197.143.198.1->197.127.128
.1
2012-01-14 09:24:02: [rv220w][IKE] INFO: Using IPsec SA configuration: 10.0.0.0/24<->192.168.100.
0/24
2012-01-14 09:24:02: [rv220w][IKE] INFO: remote configuration for identifier "router1.vpn.com" found
2012-01-14 09:24:02: [rv220w][IKE] INFO: Initiating new phase 1 negotiation: 197.127.128.1[500]<=>197.1
43.198.1[5
00]
2012-01-14 09:24:02: [rv220w][IKE] INFO: Beginning Identity Protection mode.
2012-01-14 09:24:02: [rv220w][IKE] INFO: [ident_i1send:180]: XXX: NUMNATTVENDORIDS: 3
2012-01-14 09:24:02: [rv220w][IKE] INFO: [ident_i1send:184]: XXX: setting vendorid: 4
2012-01-14 09:24:02: [rv220w][IKE] INFO: [ident_i1send:184]: XXX: setting vendorid: 8
2012-01-14 09:24:02: [rv220w][IKE] INFO: [ident_i1send:184]: XXX: setting vendorid: 9
2012-01-14 09:24:02: [rv220w][IKE] INFO: Received Vendor ID: RFC 3947
2012-01-14 09:24:02: [rv220w][IKE] INFO: Received Vendor ID: DPD
2012-01-14 09:24:02: [rv220w][IKE] INFO: Received Vendor ID: KAME/racoon
2012-01-14 09:24:02: [rv220w][IKE] INFO: For 197.143.198.1[500], Selected NAT-T version: RFC 3947
2012-01-14 09:24:03: [rv220w][IKE] INFO: Received Vendor ID: KAME/racoon
2012-01-14 09:24:03: [rv220w][IKE] INFO: NAT-D payload matches for 197.127.128.1[500]
2012-01-14 09:24:03: [rv220w][IKE] INFO: NAT-D payload matches for 197.143.198.1[500]
2012-01-14 09:24:03: [rv220w][IKE] INFO: NAT not detected
2012-01-14 09:24:03: [rv220w][IKE] INFO: ISAKMP-SA established for 197.127.128.1[500]-197.143
.198.1[500
] with spi:3e55c80741ba280c:dd313
67ffdf353b
8
2012-01-14 09:24:03: [rv220w][IKE] INFO: Sending Informational Exchange: notify payload[INITIAL-CONTACT]
2012-01-14 09:24:03: [rv220w][IKE] INFO: ISAKMP-SA expired 197.127.128.1[500]-197.143
.198.1[500
] spi:3e55c80741ba280c:dd313
67ffdf353b
8
2012-01-14 09:24:03: [rv220w][IKE] INFO: Sending Informational Exchange: delete payload[]
2012-01-14 09:24:04: [rv220w][IKE] INFO: ISAKMP-SA deleted for 197.127.128.1[500]-197.143
.198.1[500
67ffdf353b
8
2012-01-14 09:24:27: [rv220w][IKE] INFO: remote configuration for identifier "router1.vpn.com" found
2012-01-14 09:24:27: [rv220w][IKE] INFO: Received request for new phase 1 negotiation: 197.127.128.1[500]<=>197.1
43.198.1[5
00]
2012-01-14 09:24:27: [rv220w][IKE] INFO: Beginning Identity Protection mode.
2012-01-14 09:24:27: [rv220w][IKE] INFO: Received Vendor ID: RFC XXXX
2012-01-14 09:24:27: [rv220w][IKE] INFO: Received Vendor ID: draft-ietf-ipsec-nat-t-ike
-02
2012-01-14 09:24:27: [rv220w][IKE] INFO: Received Vendor ID: RFC 3947
2012-01-14 09:24:27: [rv220w][IKE] INFO: Received Vendor ID: DPD
2012-01-14 09:24:27: [rv220w][IKE] INFO: For 197.143.198.1[500], Selected NAT-T version: RFC 3947
2012-01-14 09:24:27: [rv220w][IKE] INFO: Received Vendor ID: KAME/racoon
2012-01-14 09:24:27: [rv220w][IKE] INFO: NAT-D payload matches for 197.127.128.1[500]
2012-01-14 09:24:27: [rv220w][IKE] INFO: NAT-D payload matches for 197.143.198.1[500]
2012-01-14 09:24:27: [rv220w][IKE] INFO: NAT not detected
2012-01-14 09:24:27: [rv220w][IKE] INFO: ISAKMP-SA established for 197.127.128.1[500]-197.143
.198.1[500
] with spi:bf736f5e71444cab:30d24
12dc75cb60
2012-01-14 09:24:27: [rv220w][IKE] INFO: Sending Informational Exchange: notify payload[INITIAL-CONTACT]
2012-01-14 09:24:27: [rv220w][IKE] INFO: ISAKMP-SA expired 197.127.128.1[500]-197.143
.198.1[500
] spi:bf736f5e71444cab:30d24
12dc75cb60
2012-01-14 09:24:27: [rv220w][IKE] INFO: Sending Informational Exchange: delete payload[]
2012-01-14 09:24:28: [rv220w][IKE] INFO: ISAKMP-SA deleted for 197.127.128.1[500]-197.143
.198.1[500
12dc75cb60
2012-01-14 09:24:33: [rv220w][IKE] ERROR: Phase 2 negotiation failed due to time up waiting for phase1. ESP 197.143.198.1->197.127.128
.1
2012-01-14 09:24:43: [rv220w][IKE] INFO: Using IPsec SA configuration: 10.0.0.0/24<->192.168.100.
0/24
2012-01-14 09:24:43: [rv220w][IKE] INFO: remote configuration for identifier "router1.vpn.com" found
2012-01-14 09:24:43: [rv220w][IKE] INFO: Initiating new phase 1 negotiation: 197.127.128.1[500]<=>197.1
43.198.1[5
00]
2012-01-14 09:24:43: [rv220w][IKE] INFO: Beginning Identity Protection mode.
2012-01-14 09:24:43: [rv220w][IKE] INFO: [ident_i1send:180]: XXX: NUMNATTVENDORIDS: 3
2012-01-14 09:24:43: [rv220w][IKE] INFO: [ident_i1send:184]: XXX: setting vendorid: 4
2012-01-14 09:24:43: [rv220w][IKE] INFO: [ident_i1send:184]: XXX: setting vendorid: 8
2012-01-14 09:24:43: [rv220w][IKE] INFO: [ident_i1send:184]: XXX: setting vendorid: 9
2012-01-14 09:24:43: [rv220w][IKE] INFO: Received Vendor ID: RFC 3947
2012-01-14 09:24:43: [rv220w][IKE] INFO: Received Vendor ID: DPD
2012-01-14 09:24:43: [rv220w][IKE] INFO: Received Vendor ID: KAME/racoon
2012-01-14 09:24:43: [rv220w][IKE] INFO: For 197.143.198.1[500], Selected NAT-T version: RFC 3947
2012-01-14 09:24:43: [rv220w][IKE] INFO: NAT-D payload matches for 197.127.128.1[500]
2012-01-14 09:24:43: [rv220w][IKE] INFO: NAT-D payload matches for 197.143.198.1[500]
2012-01-14 09:24:43: [rv220w][IKE] INFO: NAT not detected
2012-01-14 09:24:44: [rv220w][IKE] INFO: ISAKMP-SA established for 197.127.128.1[500]-197.143
.198.1[500
] with spi:01055a0e8b3c2d3c:ecbef
bd9ed57340
2012-01-14 09:24:44: [rv220w][IKE] INFO: Sending Informational Exchange: notify payload[INITIAL-CONTACT]
2012-01-14 09:24:44: [rv220w][IKE] INFO: ISAKMP-SA expired 197.127.128.1[500]-197.143
.198.1[500
] spi:01055a0e8b3c2d3c:ecbef
bd9ed57340
2012-01-14 09:24:44: [rv220w][IKE] INFO: Sending Informational Exchange: delete payload[]
2012-01-14 09:24:45: [rv220w][IKE] INFO: ISAKMP-SA deleted for 197.127.128.1[500]-197.143
.198.1[500
bd9ed57340
2012-01-14 09:25:14: [rv220w][IKE] ERROR: Phase 2 negotiation failed due to time up waiting for phase1. ESP 197.143.198.1->197.127.128
.1
2012-01-14 09:26:02: [rv220w][IKE] INFO: Using IPsec SA configuration: 10.0.0.0/24<->192.168.100.
0/24
2012-01-14 09:26:02: [rv220w][IKE] INFO: remote configuration for identifier "router1.vpn.com" found
2012-01-14 09:26:02: [rv220w][IKE] INFO: Initiating new phase 1 negotiation: 197.127.128.1[500]<=>197.1
43.198.1[5
00]
2012-01-14 09:26:02: [rv220w][IKE] INFO: Beginning Identity Protection mode.
2012-01-14 09:26:02: [rv220w][IKE] INFO: [ident_i1send:180]: XXX: NUMNATTVENDORIDS: 3
2012-01-14 09:26:02: [rv220w][IKE] INFO: [ident_i1send:184]: XXX: setting vendorid: 4
2012-01-14 09:26:02: [rv220w][IKE] INFO: [ident_i1send:184]: XXX: setting vendorid: 8
2012-01-14 09:26:02: [rv220w][IKE] INFO: [ident_i1send:184]: XXX: setting vendorid: 9
2012-01-14 09:26:02: [rv220w][IKE] INFO: Received Vendor ID: RFC 3947
2012-01-14 09:26:02: [rv220w][IKE] INFO: Received Vendor ID: DPD
2012-01-14 09:26:02: [rv220w][IKE] INFO: Received Vendor ID: KAME/racoon
2012-01-14 09:26:02: [rv220w][IKE] INFO: For 197.143.198.1[500], Selected NAT-T version: RFC 3947
2012-01-14 09:26:03: [rv220w][IKE] INFO: Received Vendor ID: KAME/racoon
2012-01-14 09:26:03: [rv220w][IKE] INFO: NAT-D payload matches for 197.127.128.1[500]
2012-01-14 09:26:03: [rv220w][IKE] INFO: NAT-D payload matches for 197.143.198.1[500]
2012-01-14 09:26:03: [rv220w][IKE] INFO: NAT not detected
2012-01-14 09:26:03: [rv220w][IKE] INFO: ISAKMP-SA established for 197.127.128.1[500]-197.143
.198.1[500
] with spi:bee67d28e1abcb44:8154b
5e19a4d737
f
2012-01-14 09:26:03: [rv220w][IKE] INFO: Sending Informational Exchange: notify payload[INITIAL-CONTACT]
2012-01-14 09:26:03: [rv220w][IKE] INFO: ISAKMP-SA expired 197.127.128.1[500]-197.143
.198.1[500
] spi:bee67d28e1abcb44:8154b
5e19a4d737
f
2012-01-14 09:26:03: [rv220w][IKE] INFO: Sending Informational Exchange: delete payload[]
2012-01-14 09:26:04: [rv220w][IKE] INFO: ISAKMP-SA deleted for 197.127.128.1[500]-197.143
.198.1[500
5e19a4d737
f
2012-01-14 09:26:22: [rv220w][IKE] INFO: remote configuration for identifier "router1.vpn.com" found
2012-01-14 09:26:22: [rv220w][IKE] INFO: Received request for new phase 1 negotiation: 197.127.128.1[500]<=>197.1
43.198.1[5
00]
2012-01-14 09:26:22: [rv220w][IKE] INFO: Beginning Identity Protection mode.
2012-01-14 09:26:22: [rv220w][IKE] INFO: Received Vendor ID: RFC XXXX
2012-01-14 09:26:22: [rv220w][IKE] INFO: Received Vendor ID: draft-ietf-ipsec-nat-t-ike
-02
2012-01-14 09:26:22: [rv220w][IKE] INFO: Received Vendor ID: RFC 3947
2012-01-14 09:26:22: [rv220w][IKE] INFO: Received Vendor ID: DPD
2012-01-14 09:26:22: [rv220w][IKE] INFO: For 197.143.198.1[500], Selected NAT-T version: RFC 3947
2012-01-14 09:26:22: [rv220w][IKE] INFO: Received Vendor ID: KAME/racoon
2012-01-14 09:26:22: [rv220w][IKE] INFO: NAT-D payload matches for 197.127.128.1[500]
2012-01-14 09:26:22: [rv220w][IKE] INFO: NAT-D payload matches for 197.143.198.1[500]
2012-01-14 09:26:22: [rv220w][IKE] INFO: NAT not detected
2012-01-14 09:26:22: [rv220w][IKE] INFO: ISAKMP-SA established for 197.127.128.1[500]-197.143
.198.1[500
] with spi:8608af37edbabe3c:7c9a4
0fe6f8c5a1
d
2012-01-14 09:26:22: [rv220w][IKE] INFO: Sending Informational Exchange: notify payload[INITIAL-CONTACT]
2012-01-14 09:26:22: [rv220w][IKE] INFO: ISAKMP-SA expired 197.127.128.1[500]-197.143
.198.1[500
] spi:8608af37edbabe3c:7c9a4
0fe6f8c5a1
d
2012-01-14 09:26:22: [rv220w][IKE] INFO: Sending Informational Exchange: delete payload[]
2012-01-14 09:26:23: [rv220w][IKE] INFO: ISAKMP-SA deleted for 197.127.128.1[500]-197.143
.198.1[500
0fe6f8c5a1
d
2012-01-14 09:26:33: [rv220w][IKE] ERROR: Phase 2 negotiation failed due to time up waiting for phase1. ESP 197.143.198.1->197.127.128
.1
2012-01-14 09:28:13: [rv220w][IKE] INFO: Using IPsec SA configuration: 10.0.0.0/24<->192.168.100.
0/24
2012-01-14 09:28:13: [rv220w][IKE] INFO: remote configuration for identifier "router1.vpn.com" found
2012-01-14 09:28:13: [rv220w][IKE] INFO: Initiating new phase 1 negotiation: 197.127.128.1[500]<=>197.1
43.198.1[5
00]
2012-01-14 09:28:13: [rv220w][IKE] INFO: Beginning Identity Protection mode.
2012-01-14 09:28:13: [rv220w][IKE] INFO: [ident_i1send:180]: XXX: NUMNATTVENDORIDS: 3
2012-01-14 09:28:13: [rv220w][IKE] INFO: [ident_i1send:184]: XXX: setting vendorid: 4
2012-01-14 09:28:13: [rv220w][IKE] INFO: [ident_i1send:184]: XXX: setting vendorid: 8
2012-01-14 09:28:13: [rv220w][IKE] INFO: [ident_i1send:184]: XXX: setting vendorid: 9
2012-01-14 09:28:14: [rv220w][IKE] INFO: Received Vendor ID: RFC 3947
2012-01-14 09:28:14: [rv220w][IKE] INFO: Received Vendor ID: DPD
2012-01-14 09:28:14: [rv220w][IKE] INFO: Received Vendor ID: KAME/racoon
2012-01-14 09:28:14: [rv220w][IKE] INFO: For 197.143.198.1[500], Selected NAT-T version: RFC 3947
2012-01-14 09:28:14: [rv220w][IKE] INFO: NAT-D payload matches for 197.127.128.1[500]
2012-01-14 09:28:14: [rv220w][IKE] INFO: NAT-D payload matches for 197.143.198.1[500]
2012-01-14 09:28:14: [rv220w][IKE] INFO: NAT not detected
2012-01-14 09:28:14: [rv220w][IKE] INFO: ISAKMP-SA established for 197.127.128.1[500]-197.143
.198.1[500
] with spi:6e3e37112f726505:d538c
7b380d1bb7
b
2012-01-14 09:28:14: [rv220w][IKE] INFO: Sending Informational Exchange: notify payload[INITIAL-CONTACT]
2012-01-14 09:28:14: [rv220w][IKE] INFO: ISAKMP-SA expired 197.127.128.1[500]-197.143
.198.1[500
] spi:6e3e37112f726505:d538c
7b380d1bb7
b
2012-01-14 09:28:14: [rv220w][IKE] INFO: Sending Informational Exchange: delete payload[]
2012-01-14 09:28:15: [rv220w][IKE] INFO: ISAKMP-SA deleted for 197.127.128.1[500]-197.143
.198.1[500
7b380d1bb7
b
2012-01-14 09:28:44: [rv220w][IKE] ERROR: Phase 2 negotiation failed due to time up waiting for phase1. ESP 197.143.198.1->197.127.128
.1
2012-01-14 09:29:01: [rv220w][IKE] INFO: Using IPsec SA configuration: 10.0.0.0/24<->192.168.100.
0/24
2012-01-14 09:29:01: [rv220w][IKE] INFO: remote configuration for identifier "router1.vpn.com" found
2012-01-14 09:29:01: [rv220w][IKE] INFO: Initiating new phase 1 negotiation: 197.127.128.1[500]<=>197.1
43.198.1[5
00]
2012-01-14 09:29:01: [rv220w][IKE] INFO: Beginning Identity Protection mode.
2012-01-14 09:29:01: [rv220w][IKE] INFO: [ident_i1send:180]: XXX: NUMNATTVENDORIDS: 3
2012-01-14 09:29:01: [rv220w][IKE] INFO: [ident_i1send:184]: XXX: setting vendorid: 4
2012-01-14 09:29:01: [rv220w][IKE] INFO: [ident_i1send:184]: XXX: setting vendorid: 8
2012-01-14 09:29:01: [rv220w][IKE] INFO: [ident_i1send:184]: XXX: setting vendorid: 9
2012-01-14 09:29:01: [rv220w][IKE] INFO: Received Vendor ID: RFC 3947
2012-01-14 09:29:01: [rv220w][IKE] INFO: Received Vendor ID: DPD
2012-01-14 09:29:01: [rv220w][IKE] INFO: Received Vendor ID: KAME/racoon
2012-01-14 09:29:01: [rv220w][IKE] INFO: For 197.143.198.1[500], Selected NAT-T version: RFC 3947
2012-01-14 09:29:02: [rv220w][IKE] INFO: Received Vendor ID: KAME/racoon
2012-01-14 09:29:02: [rv220w][IKE] INFO: NAT-D payload matches for 197.127.128.1[500]
2012-01-14 09:29:02: [rv220w][IKE] INFO: NAT-D payload matches for 197.143.198.1[500]
2012-01-14 09:29:02: [rv220w][IKE] INFO: NAT not detected
2012-01-14 09:29:02: [rv220w][IKE] INFO: ISAKMP-SA established for 197.127.128.1[500]-197.143
.198.1[500
] with spi:ed4a08158ec9e2d6:728b8
2b6fd1f4ac
8
2012-01-14 09:29:02: [rv220w][IKE] INFO: Sending Informational Exchange: notify payload[INITIAL-CONTACT]
2012-01-14 09:29:02: [rv220w][IKE] INFO: ISAKMP-SA expired 197.127.128.1[500]-197.143
.198.1[500
] spi:ed4a08158ec9e2d6:728b8
2b6fd1f4ac
8
2012-01-14 09:29:02: [rv220w][IKE] INFO: Sending Informational Exchange: delete payload[]
2012-01-14 09:29:03: [rv220w][IKE] INFO: ISAKMP-SA deleted for 197.127.128.1[500]-197.143
.198.1[500
2b6fd1f4ac
8
2012-01-14 09:29:32: [rv220w][IKE] ERROR: Phase 2 negotiation failed due to time up waiting for phase1. ESP 197.143.198.1->197.127.128
.1
2012-01-14 09:29:53: [rv220w][IKE] INFO: Using IPsec SA configuration: 10.0.0.0/24<->192.168.100.
0/24
2012-01-14 09:29:53: [rv220w][IKE] INFO: remote configuration for identifier "router1.vpn.com" found
2012-01-14 09:29:53: [rv220w][IKE] INFO: Initiating new phase 1 negotiation: 197.127.128.1[500]<=>197.1
43.198.1[5
00]
2012-01-14 09:29:53: [rv220w][IKE] INFO: Beginning Identity Protection mode.
2012-01-14 09:29:53: [rv220w][IKE] INFO: [ident_i1send:180]: XXX: NUMNATTVENDORIDS: 3
2012-01-14 09:29:53: [rv220w][IKE] INFO: [ident_i1send:184]: XXX: setting vendorid: 4
2012-01-14 09:29:53: [rv220w][IKE] INFO: [ident_i1send:184]: XXX: setting vendorid: 8
2012-01-14 09:29:53: [rv220w][IKE] INFO: [ident_i1send:184]: XXX: setting vendorid: 9
2012-01-14 09:29:53: [rv220w][IKE] INFO: Received Vendor ID: RFC 3947
2012-01-14 09:29:53: [rv220w][IKE] INFO: Received Vendor ID: DPD
2012-01-14 09:29:53: [rv220w][IKE] INFO: Received Vendor ID: KAME/racoon
2012-01-14 09:29:53: [rv220w][IKE] INFO: For 197.143.198.1[500], Selected NAT-T version: RFC 3947
2012-01-14 09:29:53: [rv220w][IKE] INFO: NAT-D payload matches for 197.127.128.1[500]
2012-01-14 09:29:53: [rv220w][IKE] INFO: NAT-D payload matches for 197.143.198.1[500]
2012-01-14 09:29:53: [rv220w][IKE] INFO: NAT not detected
2012-01-14 09:29:53: [rv220w][IKE] INFO: ISAKMP-SA established for 197.127.128.1[500]-197.143
.198.1[500
] with spi:d18758312c138e74:463cf
cd4bc16eb8
9
2012-01-14 09:29:53: [rv220w][IKE] INFO: Sending Informational Exchange: notify payload[INITIAL-CONTACT]
2012-01-14 09:29:53: [rv220w][IKE] INFO: ISAKMP-SA expired 197.127.128.1[500]-197.143
.198.1[500
] spi:d18758312c138e74:463cf
cd4bc16eb8
9
2012-01-14 09:29:53: [rv220w][IKE] INFO: Sending Informational Exchange: delete payload[]
2012-01-14 09:29:54: [rv220w][IKE] INFO: ISAKMP-SA deleted for 197.127.128.1[500]-197.143
.198.1[500
cd4bc16eb8
9
2012-01-14 09:30:24: [rv220w][IKE] ERROR: Phase 2 negotiation failed due to time up waiting for phase1. ESP 197.143.198.1->197.127.128
.1
2012-01-14 09:31:00: [rv220w][IKE] INFO: Using IPsec SA configuration: 10.0.0.0/24<->192.168.100.
0/24
2012-01-14 09:31:00: [rv220w][IKE] INFO: remote configuration for identifier "router1.vpn.com" found
2012-01-14 09:31:00: [rv220w][IKE] INFO: Initiating new phase 1 negotiation: 197.127.128.1[500]<=>197.1
43.198.1[5
00]
2012-01-14 09:31:00: [rv220w][IKE] INFO: Beginning Identity Protection mode.
2012-01-14 09:31:00: [rv220w][IKE] INFO: [ident_i1send:180]: XXX: NUMNATTVENDORIDS: 3
2012-01-14 09:31:00: [rv220w][IKE] INFO: [ident_i1send:184]: XXX: setting vendorid: 4
2012-01-14 09:31:00: [rv220w][IKE] INFO: [ident_i1send:184]: XXX: setting vendorid: 8
2012-01-14 09:31:00: [rv220w][IKE] INFO: [ident_i1send:184]: XXX: setting vendorid: 9
2012-01-14 09:31:00: [rv220w][IKE] INFO: Received Vendor ID: RFC 3947
2012-01-14 09:31:00: [rv220w][IKE] INFO: Received Vendor ID: DPD
2012-01-14 09:31:00: [rv220w][IKE] INFO: Received Vendor ID: KAME/racoon
2012-01-14 09:31:00: [rv220w][IKE] INFO: For 197.143.198.1[500], Selected NAT-T version: RFC 3947
2012-01-14 09:31:00: [rv220w][IKE] INFO: NAT-D payload matches for 197.127.128.1[500]
2012-01-14 09:31:00: [rv220w][IKE] INFO: NAT-D payload matches for 197.143.198.1[500]
2012-01-14 09:31:00: [rv220w][IKE] INFO: NAT not detected
2012-01-14 09:31:01: [rv220w][IKE] INFO: ISAKMP-SA established for 197.127.128.1[500]-197.143
.198.1[500
] with spi:037f625ec85cd352:36ffa
9dd66151db
2012-01-14 09:31:01: [rv220w][IKE] INFO: Sending Informational Exchange: notify payload[INITIAL-CONTACT]
2012-01-14 09:31:01: [rv220w][IKE] INFO: ISAKMP-SA expired 197.127.128.1[500]-197.143
.198.1[500
] spi:037f625ec85cd352:36ffa
9dd66151db
2012-01-14 09:31:01: [rv220w][IKE] INFO: Sending Informational Exchange: delete payload[]
2012-01-14 09:31:02: [rv220w][IKE] INFO: ISAKMP-SA deleted for 197.127.128.1[500]-197.143
.198.1[500
9dd66151db
2012-01-14 09:31:31: [rv220w][IKE] ERROR: Phase 2 negotiation failed due to time up waiting for phase1. ESP 197.143.198.1->197.127.128
.1
2012-01-14 09:31:51: [rv220w][IKE] INFO: remote configuration for identifier "router1.vpn.com" found
2012-01-14 09:31:51: [rv220w][IKE] INFO: Received request for new phase 1 negotiation: 197.127.128.1[500]<=>197.1
43.198.1[5
00]
2012-01-14 09:31:51: [rv220w][IKE] INFO: Beginning Identity Protection mode.
2012-01-14 09:31:51: [rv220w][IKE] INFO: Received Vendor ID: RFC XXXX
2012-01-14 09:31:51: [rv220w][IKE] INFO: Received Vendor ID: draft-ietf-ipsec-nat-t-ike
-02
I
caveatsolicitors Sat, 01/14/2012 - 15:42
Router 2 Log
2012-01-14 09:23:04: [rv220w][IKE] INFO: ISAKMP-SA deleted for 197.143.198.1[500]-197.127
.128.1[500
c5c6660437
f
2012-01-14 09:23:12: [rv220w][IKE] INFO: Using IPsec SA configuration: 192.168.100.0/24<->10.0.0.
0/24
2012-01-14 09:23:12: [rv220w][IKE] INFO: remote configuration for identifier "router2.vpn.com" found
2012-01-14 09:23:12: [rv220w][IKE] INFO: Initiating new phase 1 negotiation: 197.143.198.1[500]<=>197.1
27.128.1[5
00]
2012-01-14 09:23:12: [rv220w][IKE] INFO: [ident_i1send:180]: XXX: NUMNATTVENDORIDS: 3
2012-01-14 09:23:12: [rv220w][IKE] INFO: [ident_i1send:184]: XXX: setting vendorid: 4
2012-01-14 09:23:12: [rv220w][IKE] INFO: [ident_i1send:184]: XXX: setting vendorid: 8
2012-01-14 09:23:12: [rv220w][IKE] INFO: [ident_i1send:184]: XXX: setting vendorid: 9
2012-01-14 09:23:13: [rv220w][IKE] INFO: Received Vendor ID: RFC 3947
2012-01-14 09:23:13: [rv220w][IKE] INFO: Received Vendor ID: DPD
2012-01-14 09:23:13: [rv220w][IKE] INFO: For 197.127.128.1[500], Selected NAT-T version: RFC 3947
2012-01-14 09:23:13: [rv220w][IKE] INFO: ISAKMP-SA established for 197.143.198.1[500]-197.127
.128.1[500
360776508e
9
2012-01-14 09:23:13: [rv220w][IKE] INFO: ISAKMP-SA expired 197.143.198.1[500]-197.127
.128.1[500
360776508e
9
2012-01-14 09:23:14: [rv220w][IKE] INFO: ISAKMP-SA deleted for 197.143.198.1[500]-197.127
.128.1[500
360776508e
9
2012-01-14 09:23:43: [rv220w][IKE] ERROR: Phase 2 negotiation failed due to time up waiting for phase1. ESP 197.127.128.1->197.143.198
.1
2012-01-14 09:24:02: [rv220w][IKE] INFO: remote configuration for identifier "router2.vpn.com" found
2012-01-14 09:24:02: [rv220w][IKE] INFO: Received request for new phase 1 negotiation: 197.143.198.1[500]<=>197.1
27.128.1[5
00]
2012-01-14 09:24:02: [rv220w][IKE] INFO: Received Vendor ID: RFC XXXX
2012-01-14 09:24:02: [rv220w][IKE] INFO: Received Vendor ID: draft-ietf-ipsec-nat-t-ike
-02
2012-01-14 09:24:02: [rv220w][IKE] INFO: For 197.127.128.1[500], Selected NAT-T version: RFC 3947
2012-01-14 09:24:02: [rv220w][IKE] INFO: NAT-D payload matches for 197.143.198.1[500]
2012-01-14 09:24:02: [rv220w][IKE] INFO: NAT-D payload matches for 197.127.128.1[500]
2012-01-14 09:24:02: [rv220w][IKE] INFO: NAT not detected
2012-01-14 09:24:03: [rv220w][IKE] INFO: ISAKMP-SA established for 197.143.198.1[500]-197.127
.128.1[500
67ffdf353b
8
2012-01-14 09:24:03: [rv220w][IKE] INFO: ISAKMP-SA expired 197.143.198.1[500]-197.127
.128.1[500
67ffdf353b
8
2012-01-14 09:24:04: [rv220w][IKE] INFO: ISAKMP-SA deleted for 197.143.198.1[500]-197.127
.128.1[500
67ffdf353b
8
2012-01-14 09:24:27: [rv220w][IKE] INFO: Using IPsec SA configuration: 192.168.100.0/24<->10.0.0.
0/24
2012-01-14 09:24:27: [rv220w][IKE] INFO: remote configuration for identifier "router2.vpn.com" found
2012-01-14 09:24:27: [rv220w][IKE] INFO: Initiating new phase 1 negotiation: 197.143.198.1[500]<=>197.1
27.128.1[5
00]
2012-01-14 09:24:27: [rv220w][IKE] INFO: [ident_i1send:180]: XXX: NUMNATTVENDORIDS: 3
2012-01-14 09:24:27: [rv220w][IKE] INFO: [ident_i1send:184]: XXX: setting vendorid: 4
2012-01-14 09:24:27: [rv220w][IKE] INFO: [ident_i1send:184]: XXX: setting vendorid: 8
2012-01-14 09:24:27: [rv220w][IKE] INFO: [ident_i1send:184]: XXX: setting vendorid: 9
2012-01-14 09:24:27: [rv220w][IKE] INFO: For 197.127.128.1[500], Selected NAT-T version: RFC 3947
2012-01-14 09:24:27: [rv220w][IKE] INFO: ISAKMP-SA established for 197.143.198.1[500]-197.127
.128.1[500
12dc75cb60
2012-01-14 09:24:27: [rv220w][IKE] INFO: ISAKMP-SA expired 197.143.198.1[500]-197.127
.128.1[500
12dc75cb60
2012-01-14 09:24:28: [rv220w][IKE] INFO: ISAKMP-SA deleted for 197.143.198.1[500]-197.127
.128.1[500
12dc75cb60
2012-01-14 09:24:43: [rv220w][IKE] INFO: remote configuration for identifier "router2.vpn.com" found
2012-01-14 09:24:43: [rv220w][IKE] INFO: Received request for new phase 1 negotiation: 197.143.198.1[500]<=>197.1
27.128.1[5
00]
2012-01-14 09:24:43: [rv220w][IKE] INFO: Received Vendor ID: RFC XXXX
2012-01-14 09:24:43: [rv220w][IKE] INFO: Received Vendor ID: draft-ietf-ipsec-nat-t-ike
-02
2012-01-14 09:24:43: [rv220w][IKE] INFO: For 197.127.128.1[500], Selected NAT-T version: RFC 3947
2012-01-14 09:24:44: [rv220w][IKE] INFO: ISAKMP-SA established for 197.143.198.1[500]-197.127
.128.1[500
bd9ed57340
2012-01-14 09:24:44: [rv220w][IKE] INFO: ISAKMP-SA expired 197.143.198.1[500]-197.127
.128.1[500
bd9ed57340
2012-01-14 09:24:45: [rv220w][IKE] INFO: ISAKMP-SA deleted for 197.143.198.1[500]-197.127
.128.1[500
bd9ed57340
2012-01-14 09:24:58: [rv220w][IKE] ERROR: Phase 2 negotiation failed due to time up waiting for phase1. ESP 197.127.128.1->197.143.198
.1
2012-01-14 09:26:02: [rv220w][IKE] INFO: remote configuration for identifier "router2.vpn.com" found
2012-01-14 09:26:02: [rv220w][IKE] INFO: Received request for new phase 1 negotiation: 197.143.198.1[500]<=>197.1
27.128.1[5
00]
2012-01-14 09:26:02: [rv220w][IKE] INFO: Received Vendor ID: RFC XXXX
2012-01-14 09:26:02: [rv220w][IKE] INFO: Received Vendor ID: draft-ietf-ipsec-nat-t-ike
-02
2012-01-14 09:26:02: [rv220w][IKE] INFO: For 197.127.128.1[500], Selected NAT-T version: RFC 3947
2012-01-14 09:26:02: [rv220w][IKE] INFO: NAT-D payload matches for 197.143.198.1[500]
2012-01-14 09:26:02: [rv220w][IKE] INFO: NAT-D payload matches for 197.127.128.1[500]
2012-01-14 09:26:02: [rv220w][IKE] INFO: NAT not detected
2012-01-14 09:26:03: [rv220w][IKE] INFO: ISAKMP-SA established for 197.143.198.1[500]-197.127
.128.1[500
5e19a4d737
f
2012-01-14 09:26:03: [rv220w][IKE] INFO: ISAKMP-SA expired 197.143.198.1[500]-197.127
.128.1[500
5e19a4d737
f
2012-01-14 09:26:04: [rv220w][IKE] INFO: ISAKMP-SA deleted for 197.143.198.1[500]-197.127
.128.1[500
5e19a4d737
f
2012-01-14 09:26:22: [rv220w][IKE] INFO: Using IPsec SA configuration: 192.168.100.0/24<->10.0.0.
0/24
2012-01-14 09:26:22: [rv220w][IKE] INFO: remote configuration for identifier "router2.vpn.com" found
2012-01-14 09:26:22: [rv220w][IKE] INFO: Initiating new phase 1 negotiation: 197.143.198.1[500]<=>197.1
27.128.1[5
00]
2012-01-14 09:26:22: [rv220w][IKE] INFO: [ident_i1send:180]: XXX: NUMNATTVENDORIDS: 3
2012-01-14 09:26:22: [rv220w][IKE] INFO: [ident_i1send:184]: XXX: setting vendorid: 4
2012-01-14 09:26:22: [rv220w][IKE] INFO: [ident_i1send:184]: XXX: setting vendorid: 8
2012-01-14 09:26:22: [rv220w][IKE] INFO: [ident_i1send:184]: XXX: setting vendorid: 9
2012-01-14 09:26:22: [rv220w][IKE] INFO: For 197.127.128.1[500], Selected NAT-T version: RFC 3947
2012-01-14 09:26:22: [rv220w][IKE] INFO: ISAKMP-SA established for 197.143.198.1[500]-197.127
.128.1[500
0fe6f8c5a1
d
2012-01-14 09:26:22: [rv220w][IKE] INFO: ISAKMP-SA expired 197.143.198.1[500]-197.127
.128.1[500
0fe6f8c5a1
d
2012-01-14 09:26:23: [rv220w][IKE] INFO: ISAKMP-SA deleted for 197.143.198.1[500]-197.127
.128.1[500
0fe6f8c5a1
d
2012-01-14 09:26:53: [rv220w][IKE] ERROR: Phase 2 negotiation failed due to time up waiting for phase1. ESP 197.127.128.1->197.143.198
.1
2012-01-14 09:28:14: [rv220w][IKE] INFO: remote configuration for identifier "router2.vpn.com" found
2012-01-14 09:28:14: [rv220w][IKE] INFO: Received request for new phase 1 negotiation: 197.143.198.1[500]<=>197.1
27.128.1[5
00]
2012-01-14 09:28:14: [rv220w][IKE] INFO: Beginning Identity Protection mode.
2012-01-14 09:28:14: [rv220w][IKE] INFO: Received Vendor ID: RFC XXXX
2012-01-14 09:28:14: [rv220w][IKE] INFO: Received Vendor ID: draft-ietf-ipsec-nat-t-ike
-02
2012-01-14 09:28:14: [rv220w][IKE] INFO: For 197.127.128.1[500], Selected NAT-T version: RFC 3947
2012-01-14 09:28:14: [rv220w][IKE] INFO: ISAKMP-SA established for 197.143.198.1[500]-197.127
.128.1[500
7b380d1bb7
b
2012-01-14 09:28:14: [rv220w][IKE] INFO: ISAKMP-SA expired 197.143.198.1[500]-197.127
.128.1[500
7b380d1bb7
b
2012-01-14 09:28:15: [rv220w][IKE] INFO: ISAKMP-SA deleted for 197.143.198.1[500]-197.127
.128.1[500
7b380d1bb7
b
2012-01-14 09:29:01: [rv220w][IKE] INFO: remote configuration for identifier "router2.vpn.com" found
2012-01-14 09:29:01: [rv220w][IKE] INFO: Received request for new phase 1 negotiation: 197.143.198.1[500]<=>197.1
27.128.1[5
00]
2012-01-14 09:29:01: [rv220w][IKE] INFO: Received Vendor ID: RFC XXXX
2012-01-14 09:29:01: [rv220w][IKE] INFO: Received Vendor ID: draft-ietf-ipsec-nat-t-ike
-02
2012-01-14 09:29:01: [rv220w][IKE] INFO: For 197.127.128.1[500], Selected NAT-T version: RFC 3947
2012-01-14 09:29:01: [rv220w][IKE] INFO: NAT-D payload matches for 197.143.198.1[500]
2012-01-14 09:29:01: [rv220w][IKE] INFO: NAT-D payload matches for 197.127.128.1[500]
2012-01-14 09:29:01: [rv220w][IKE] INFO: NAT not detected
2012-01-14 09:29:02: [rv220w][IKE] INFO: ISAKMP-SA established for 197.143.198.1[500]-197.127
.128.1[500
2b6fd1f4ac
8
2012-01-14 09:29:02: [rv220w][IKE] INFO: ISAKMP-SA expired 197.143.198.1[500]-197.127
.128.1[500
2b6fd1f4ac
8
2012-01-14 09:29:03: [rv220w][IKE] INFO: ISAKMP-SA deleted for 197.143.198.1[500]-197.127
.128.1[500
2b6fd1f4ac
8
2012-01-14 09:29:53: [rv220w][IKE] INFO: remote configuration for identifier "router2.vpn.com" found
2012-01-14 09:29:53: [rv220w][IKE] INFO: Received request for new phase 1 negotiation: 197.143.198.1[500]<=>197.1
27.128.1[5
00]
2012-01-14 09:29:53: [rv220w][IKE] INFO: Received Vendor ID: RFC XXXX
2012-01-14 09:29:53: [rv220w][IKE] INFO: Received Vendor ID: draft-ietf-ipsec-nat-t-ike
-02
2012-01-14 09:29:53: [rv220w][IKE] INFO: For 197.127.128.1[500], Selected NAT-T version: RFC 3947
2012-01-14 09:29:53: [rv220w][IKE] INFO: ISAKMP-SA established for 197.143.198.1[500]-197.127
.128.1[500
cd4bc16eb8
9
2012-01-14 09:29:53: [rv220w][IKE] INFO: ISAKMP-SA expired 197.143.198.1[500]-197.127
.128.1[500
cd4bc16eb8
9
2012-01-14 09:29:54: [rv220w][IKE] INFO: ISAKMP-SA deleted for 197.143.198.1[500]-197.127
.128.1[500
cd4bc16eb8
9
2012-01-14 09:31:00: [rv220w][IKE] INFO: remote configuration for identifier "router2.vpn.com" found
2012-01-14 09:31:00: [rv220w][IKE] INFO: Received request for new phase 1 negotiation: 197.143.198.1[500]<=>197.1
27.128.1[5
00]
2012-01-14 09:31:00: [rv220w][IKE] INFO: Received Vendor ID: RFC XXXX
2012-01-14 09:31:00: [rv220w][IKE] INFO: Received Vendor ID: draft-ietf-ipsec-nat-t-ike
-02
2012-01-14 09:31:00: [rv220w][IKE] INFO: For 197.127.128.1[500], Selected NAT-T version: RFC 3947
2012-01-14 09:31:00: [rv220w][IKE] INFO: ISAKMP-SA established for 197.143.198.1[500]-197.127
.128.1[500
9dd66151db
2012-01-14 09:31:00: [rv220w][IKE] INFO: Sending Informational Exchange: notify payload[INITIAL-CONTACT]
2012-01-14 09:31:01: [rv220w][IKE] INFO: ISAKMP-SA expired 197.143.198.1[500]-197.127
.128.1[500
9dd66151db
2012-01-14 09:31:02: [rv220w][IKE] INFO: ISAKMP-SA deleted for 197.143.198.1[500]-197.127
.128.1[500
9dd66151db
2012-01-14 09:31:51: [rv220w][IKE] INFO: Using IPsec SA configuration: 192.168.100.0/24<->10.0.0.
0/24
2012-01-14 09:31:51: [rv220w][IKE] INFO: remote configuration for identifier "router2.vpn.com" found
2012-01-14 09:31:51: [rv220w][IKE] INFO: Initiating new phase 1 negotiation: 197.143.198.1[500]<=>197.1
27.128.1[5
00]
2012-01-14 09:31:51: [rv220w][IKE] INFO: [ident_i1send:180]: XXX: NUMNATTVENDORIDS: 3
2012-01-14 09:31:51: [rv220w][IKE] INFO: [ident_i1send:184]: XXX: setting vendorid: 4
2012-01-14 09:31:51: [rv220w][IKE] INFO: [ident_i1send:184]: XXX: setting vendorid: 8
2012-01-14 09:31:51: [rv220w][IKE] INFO: [ident_i1send:184]: XXX: setting vendorid: 9
2012-01-14 09:31:51: [rv220w][IKE] INFO: Received Vendor ID: RFC 3947
2012-01-14 09:31:51: [rv220w][IKE] INFO: Received Vendor ID: DPD
2012-01-14 09:31:51: [rv220w][IKE] INFO: Received Vendor ID: KAME/racoon
2012-01-14 09:31:51: [rv220w][IKE] INFO: For 197.127.128.1[500], Selected NAT-T version: RFC 3947
2012-01-14 09:31:51: [rv220w][IKE] INFO: NAT-D payload matches for 197.143.198.1[500]
2012-01-14 09:31:51: [rv220w][IKE] INFO: NAT-D payload matches for 197.127.128.1[500]
2012-01-14 09:31:51: [rv220w][IKE] INFO: NAT not detected
2012-01-14 09:31:51: [rv220w][IKE] INFO: ISAKMP-SA established for 197.143.198.1[500]-197.127
.128.1[500
] with spi:b53bcc4e7c091dea:8c46f
c704d34634
6
2012-01-14 09:31:51: [rv220w][IKE] INFO: Sending Informational Exchange: notify payload[INITIAL-CONTACT]
2012-01-14 09:31:51: [rv220w][IKE] INFO: ISAKMP-SA expired 197.143.198.1[500]-197.127
.128.1[500
] spi:b53bcc4e7c091dea:8c46f
c704d34634
6
2012-01-14 09:31:51: [rv220w][IKE] INFO: Sending Informational Exchange: delete payload[]
2012-01-14 09:31:52: [rv220w][IKE] INFO: ISAKMP-SA deleted for 197.143.198.1[500]-197.127
.128.1[500
c704d34634
6
2012-01-14 09:32:01: [rv220w][IKE] INFO: remote configuration for identifier "router2.vpn.com" found
2012-01-14 09:32:01: [rv220w][IKE] INFO: Received request for new phase 1 negotiation: 197.143.198.1[500]<=>197.1
27.128.1[5
00]
2012-01-14 09:32:01: [rv220w][IKE] INFO: Beginning Identity Protection mode.
2012-01-14 09:32:01: [rv220w][IKE] INFO: Received Vendor ID: RFC XXXX
2012-01-14 09:32:01: [rv220w][IKE] INFO: Received Vendor ID: draft-ietf-ipsec-nat-t-ike
-02
caveatsolicitors Sat, 01/14/2012 - 15:47
I have also attached the word format of both policies as copy and paste didnt paste the whole info I hope someone can help.
caveatsolicitors Sat, 01/14/2012 - 15:30
Router1 Ipsec Policies
IPsec Policies
Add / Edit IKE Policy Configuration
Policy Name:
Direction / Type:
InitiatorResponderBoth
Exchange Mode:
MainAggressive
Local
Identifier Type:
Local WAN IPFQDNUser-FQDNDER ASN1 DN
Identifier:
Remote
Identifier Type:
Remote WAN IPFQDNUser-FQDNDER ASN1 DN
Identifier:
IKE SA Parameters
Encryption Algorithm:
DES3DESAES-128AES-192AES-256
Authentication Algorithm:
MD5SHA-1SHA2-256SHA2-384SHA2-512
Authentication Method:
Pre-Shared KeyRSA-Signature
Pre-Shared Key:
Diffie-Hellman (DH) Group:
Group1 (768 bit)Group2 (1024 bit)Group5 (1536 bit)
SA-Lifetime:
Seconds
Dead Peer Detection:
Enable
Detection Period:
Reconnect after Failure Count:
Extended Authentication
XAUTH Type:
NoneEdge DeviceIPsec Host
Authentication Type:
User DatabaseRadius - PAPRadius - CHAP
Username:
Password:
caveatsolicitors Sat, 01/14/2012 - 15:32
Router1 VPN Policies
IPsec Policies
Add / Edit VPN Policy Configuration
Policy Name:
Policy Type:
Auto PolicyManual Policy
Remote Endpoint:
IP AddressFQDN
NETBIOS:
Enable
Local Traffic Selection
Local IP:
AnySingleRangeSubnet
Start Address:
End Address:
Subnet Mask:
Remote Traffic Selection
Remote IP:
Start Address:
End Address:
Subnet Mask:
Manual Policy Parameters
SPI-Incoming:
SPI-Outgoing:
3DESNoneDESAES-128AES-192AES-256AES-CCMAES-GCM
Key-In:
Key-Out:
Integrity Algorithm:
SHA-1SHA2-256SHA2-384SHA2-512MD5
Key-In:
Key-Out:
Auto Policy Parameters
SA-Lifetime:
SecondsKBytes
PFS Key Group:
Enable
DH-Group 1 (768 bit)DH-Group 2 (1024 bit)DH-Group 5 (1536 bit)
Select IKE Policy:
CAVEAT-VPN
caveatsolicitors Sat, 01/14/2012 - 15:35
Router 2 IPsec
IPsec Policies
Policy Name:
Direction / Type:
Exchange Mode:
MainAggressive
Local
Identifier Type:
Identifier:
Remote
Identifier Type:
Identifier:
IKE SA Parameters
Pre-Shared Key:
SA-Lifetime:
Seconds
Enable
Detection Period:
XAUTH Type:
Username:
Password:
caveatsolicitors Sat, 01/14/2012 - 15:37
Router 2 VPN
Policy Name:
Policy Type:
Remote Endpoint:
FQDN
NETBIOS:
Enable
Local IP:
Start Address:
End Address:
Subnet Mask:
Remote IP:
Start Address:
End Address:
Subnet Mask:
SPI-Incoming:
SPI-Outgoing:
Key-In:
Key-Out:
Key-In:
Key-Out:
SA-Lifetime:
SecondsKBytes
PFS Key Group:
Enable
Select IKE Policy:
CAVEAT-VPN
