How do you send a "Break" on puTTY to a cisco 2600 Terminal server
michaelseare
I have a cisco 2621XM Terminal server connected to A router.  The Terminal server has 32 ports and connected to 32 cisco deviceses. I was trying to login one of my Router which is cisco router 7609 that has a sup-720. The sup-720 failed and I was trying to upgrade the IOS on the sup-720. when I reload it and send a "BREAK" from the puTTY it didn't work.  Is there any way I can send a BREAK from the puTTY or push any key that works.
Thanks.
22 Replies 22
Rozsa Illes
If the standard break sequences do not work, you can try the special commands: right click on the header of putty / Special Commands / Break.
Cheers,
Rose
In PuTTY, you can use the key combination of CTRL+Break.
Don R. Crawley, Linux+, CCNA Security
Author and speaker for the IT industry
Author of The Accidental Administrator:  Cisco ASA Security Appliance Step-by-Step Configuration Guide
www.soundtraining.net/bookstore
Don R. Crawley, DTM, CSP
Author of The Compassionate Geek and Accidental Administrator series of books for I.T. professionals.
http://amazon.com/author/doncrawley
What is the difference between sending a standard break sequence using Control+Break and a special break command using  PuTTY?
The reason for asking is that my colleague could not send a break using the Control+Break keyboard keys but was able to interrupt to booting of an ME3600-X switch using the special break command from the PuTTY menu, which I find rather weird.
Tom
YEAH!!!!  you  are the best,   nothing else worked Much Thanks
dolahadad
use "CTRL + SHIFT + 6 + X"
as far as I know..
and also there is command to enable break on boot.
But, I forgot... try to read IOS command guide.
Not to ressurect a dead thread, but you guys are referencing break sequences for a computer directly connected to a console. All attempts I've tried for these sequences when doing reverse telnet through a terminal server (in my case a 3725) are completely ignored. To my knowledge there's no way to correct this issue.
Yes it's possible. Configure telnet break-on-ip. Then send Interrupt Process signal with Putty Special Command menu.
http://www.cisco.com/en/US/docs/ios/termserv/configuration/guide/tsv_dialin_term_svcs_ps10591_TSD_Products_Configuration_Guide_Chapter.html
You, sir, are my new best friend. I wish I could mark this question as answered.
Thank you for the nice rating and good luck!
Man!! you're the MAN
Also from me Paolo: Thank you!
worked for me! thanks Paolo!
this is the new link:
http://www.cisco.com/c/en/us/td/docs/ios/termserv/configuration/guide/15-mt/tsv-15-MT-book/tsv_dialin_term_svcs.html
don't forget to remove the "telnet break-on-ip" command when you're done.
that worked thanks
crtl+Shfit+6+x
Enter
Ravi Singh
Level 7
Level 7
Standard Break Key Sequence Combinations During Password Recovery
or
