Canno't delete a serverfarm
Answered Question
Jan 16th, 2012
Hi all.
I'm working on an ACE and I have to delete a server farm.
As soon I try to delet the server farm I get the following error message:
Error: serverfarm 'xxxxxx' is in use. Cannot delete!
The software version is Version A2(3.4).
Any idea??
Thanks for your support.
Reagrds, Fabio.
Correct Answer by Francesco Casotto about 5 years 5 months ago
Salve Fabio,
it means that the serverfarm is being currently used, so you should first remove the reference to it in the existing loadbalance policies and/or in sticky groups, then remove the serverfarm config.
Useful commands:
show run policy-map
show run sticky
show run | i
If after the cleanup still the error persists let us know.
Saluti,
Francesco
Overall Rating: 5 (1 ratings)
Correct Answer
Francesco Casotto Mon, 01/16/2012 - 03:15
  • Cisco Employee,
Salve Fabio,
Useful commands:
show run policy-map
show run sticky
show run | i
Saluti,
Francesco
fabio.marino Mon, 01/16/2012 - 04:43
Ciao Francesco,
you right I thought that loadbalance polices were already deleted. Now I fixed the problem.
Many thanks.
Ciao, Fabio.
Juraj Podhajecky Fri, 02/24/2012 - 01:02
Hi Francesco,
I have similar problem - I can not delete couple of serverfarms. Serverfarms are not used and there are no rservers in the serverfarms. Interesting is, that I can delete some other serverfarms. Thanks in advance.
Software
  loader:    Version 12.2[121]
  system:    Version A2(3.3) [build 3.0(0)A2(3.3)]
Hardware
  Product Number: ACE20-MOD-K9
ACE/XXX# sh serverfarm Wxxx
serverfarm     : Wxxx, type: HOST
total rservers : 0
ACE/XXX# sh run | i Wxxx
Generating configuration....
serverfarm host Wxxx
ACE/XXX# sh conn serverfarm Wxxx
conn-id    np dir proto vlan source                destination           state
ACE/XXX# sh sticky database | i Wxxx
ACE/XXX(config)# no serverfarm host Wxxx
Error: serverfarm 'Wxxx' is in use. Cannot delete!
