Warning message
ATA187 and CCM4.1
Jan 16th, 2012
Hi Expert,
I need to order ATA 186 but this model already end so i have to order ATA 187 instead. Anyway, i use CCM version 4.1(3) so can i register ATA to CCM? Pls let me know if upgrade CCM to new version (I think version 8) is only way for solution. Thank you
Overall Rating: 5 (1 ratings)
Jonathan Schulenberg Mon, 01/16/2012 - 03:23
  • Cisco Designated VIP,
    2017 IP Telephony
You must upgrade to CUCM 7.1(5) or later for the ATA187 to work. The short answer is that it uses SIP which CCM 4.1 had no support of on the line-side of the system.
acampbell Mon, 01/16/2012 - 03:27
  • Green, 3000 points or more
According to the SW download page
You can run an187 on CUCM 6.1.5 +
You need to load
cmterm-ata187-qed.9-2-3-1.cop.sgn first to allow the device type part
of the CUCM device lists on the PUB only
See readme
http://www.cisco.com/web/software/282074215/64021/cmterm-ata187-9-2-3-1-readme.html
Then you load cmterm-ata187.9-2-3-1.cop.sgn
For upgrading and usage on all servers
So 4.1 to 6.1.5 should allow you to proceed
Alex
