01-16-2012 02:54 AM - edited 03-04-2019 02:55 PM
Hi All,
I have a requirement where HSRP is running on the LAN side and IPSEC VPN is established with the remote site CPE. HSRP is trakcing the WAN interface status. How can I track the IPSEC VPN status also for HSRP failover.
I can see there are many documents in Internet showing how to track HSRP and IPSEC running on the same Interface.But in this case HSRP is on the LAN and IPSEC is established on from the WAN interface.
Diagram showing only one CPE in each site just for simplicity).IPSEC is estalished fomr CPE to CPE for encrypting the VPN traffic.There is no routing protocol running over IPSEC peers.
LAN----------------CPE------------------------PE------------------------PE--------------CPE-----------------LAN
<-HSRP-> <-BGP-> <-MPLS-> <-BGP-> <-HSRP->
<---------------------------------IPSEC-------------------------->
Please help !!
Cheers,
A
Solved! Go to Solution.
01-16-2012 08:26 AM
A
I wonder if it would work to set up IP SLA to track availability of some address reached through the VPN and to have your HSRP track that.
Rick
01-16-2012 12:42 PM
Is there a route that's specific to your IPSec tunnel? If so, you could use SLA to track the route. When it falls out of the table, you could fail over to your other standby device...
01-16-2012 08:26 AM
A
Rick
01-16-2012 09:56 AM
Hi Rick,
Thanks Rick, i thought about the object tracking as you said. Was searching for some thing better so that HSRP can track the ISAKMP SA session . May be such feature does't exist !!
Cheers,
Anil.
01-16-2012 12:42 PM
01-16-2012 12:53 PM
Yes, i am going to do that only now. Object tracking with HSRP.
Anil.
