ASA 8.3 real Ip address in ACL
Answered Question
Jan 16th, 2012
if ASA 8.3 uses real IP address in ACL, why in this example "ASA 8.3 and Later: Mail (SMTP) Server Access on Inside Network Configuration Example" uses the public (natted) ip address for the smtp server ACL?
Correct Answer by ajay chauhan about 5 years 7 months ago
I agree !!
pre-8.3 Configuration
static (inside,outside) 209.165.201.15 10.1.1.6 netmask 255.255.255.255
access-list outside_in extended permit tcp any host 209.165.201.15
access-group outside_in in interface outside
8.3 Configuration
object network obj-10.1.1.6
  host 10.1.1.6
  nat (inside,outside) static 209.165.201.15
access-list outside_in extended permit tcp any host 10.1.1.6
Overall Rating: 4 (4 ratings)
ajay chauhan Mon, 01/16/2012 - 05:20
  • Silver, 250 points or more
Whatever will be the SMTP server IP on internet will have to add that IP on outside ACL to allow on port 25. It could be NAT IP or Public IP as well.
Can you post the statement from configuration where you have doubt?
Ajay
jmprats Mon, 01/16/2012 - 05:24
In the example:
access−list smtp extended permit tcp any host 209.164.3.5 eq smtp
object network obj−192.168.2.0
subnet 192.168.2.0 255.255.255.0
nat (inside,outside) dynamic 209.164.3.129
Why doesn't use the real ip address in the acl?
ajay chauhan Mon, 01/16/2012 - 05:31
Ok.
That traffic is originated from inside hosts. You should focus on -
object network obj-192.168.2.57
  host 192.168.2.57
  nat (inside,outside) static 209.164.3.5
For your SMTP question SMTP server is mapped one to one NAT so public identity would be 209.164.3.5 so ofcourse that is allowed in ACL.
Regarding configuration you have post has nothing to do with SMTP server that have mentioned the whole subnet /24 for outbound traffic.
NAT has order to process - nonat >static nat > dynamic nat> static pat >dynamic pat > like this.
Hope this help.
Ajay
jmprats Tue, 01/17/2012 - 00:53
OK, sorry, of course, the smtp-server nat was:
object network obj−192.168.2.57
host 192.168.2.57
But in the ACL is using public IP, not the real ip address as announces Release Notes or migration guide, which states:
"For example, formerly if you wanted to allow an outside host to access an inside host that used NAT, you
applied an inbound access list on the outside interface using the access-group command. In this
scenario, you needed to specify the mapped address of the inside host in the access list because that
address was the address that can be used on the outside network. Starting in 8.3, you need to specify the
real address in the access list."
In this Cisco Support Channel video (minute 3), the outside ACL uses the real ip address, not the public-natted one
http://www.youtube.com/watch?v=R6TMlH9U2pE&feature=plcp&context=C34bcf43UDOEgsToPDskINRv5_oXhrk7jRahbPD_Em
So my question is:
In the ACL, do I have to use the real ip (like the video) or the natted-ip (like the smtp example)?
EliasTlou Tue, 01/17/2012 - 01:01
Use real IP address:
e.g.
access−list smtp extended permit tcp any host 192.168.2.57 eq smtp
Correct Answer
ajay chauhan Tue, 01/17/2012 - 01:18
I agree !!
8.3 Configuration
  host 10.1.1.6
Related Content
