ACE Licence installation failed with no space left on device
Jan 16th, 2012
The installation of an ACE-4710 throughput upgrade license licence (ACE-AP-02-UP1) failed with an error message :
CH01AC03/Admin#  license install disk0:ACE20111213081741975.lic
Installing license... failed: No space left on device
What could be the cause of such a message ?
Here is the disk:0 usage :
CH01AC03/Admin# dir disk0:
   891 Jun 16 2009 08:38:41 ACE20090616063133861.lic
   252 Nov 10 2009 16:52:45 ACE20091110071123557.lic
   245 Dec 14 2011 15:44:53 ACE20111213081235229.lic
   245 Dec 14 2011 15:44:28 ACE20111213081741975.lic
62333 Jan 09 2012 23:17:48 CH01AC03_2012_01_09_23_17_47.tgz
  1024 Apr 12 2007 22:26:05 cv/
     0 Oct 28 2011 20:33:14 kernel_log_messages1.txt
156554 Oct 28 2011 20:33:09 sysmgr_info
grep: write error: No space left on device
           Usage for disk0: filesystem
                -1213274808 bytes total used
                  139518072 bytes free
                -1073756736 bytes total
I am surprised to observe negative values in the byte total used and byte total !
Here is the ACE software version :
CH01AC03/Admin# sh ver
Cisco Application Control Software (ACSW)
TAC support: http://www.cisco.com/tac
Copyright (c) 1985-2011 by Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained herein are owned by
other third parties and are used and distributed under license.
Some parts of this software are covered under the GNU Public
License. A copy of the license is available at
http://www.gnu.org/licenses/gpl.html.
Software
  loader:    Version 0.95.1
  system:    Version A4(2.0) [build 3.0(0)A4(2.0) adbuild_19:35:12-2011/02/16_/a
uto/adbure_nightly4/renumber/rel_a4_2_0_throttle/REL_3_0_0_A4_2_0]
  system image file: (hd0,1)/c4710ace-t1k9-mz.A4_2_0.bin
  Device Manager version 4.2 (0) 20110201:0929
  installed license: ACE-AP-01-LIC ACE-AP-VIRT-020 ACE-AP-C-500-LIC ACE-AP-OPT-5
0-K9 ACE-AP-SSL-05K-K9
Hardware
  cpu info:
    Motherboard:
        number of cpu(s): 2
    Daughtercard:
        number of cpu(s): 16
  memory info:
    total: 6226372 kB, free: 3784772 kB
    shared: 0 kB, buffers: 26832 kB, cached 0 kB
  cf info:
    filesystem: /dev/hdb2
    total: 861668 kB, used: 742636 kB, available: 75260 kB
last boot reason:  reload command by admin
configuration register:  0x1
CH01AC03 kernel uptime is 79 days 18 hours 52 minute(s) 50 second(s)
Current licence usage :
CH01AC03/Admin# sh license usage
License                      Ins   Lic    Status   Expiry Date   Comments
                                  Count
ACE-AP-C-UP1                  No     -    Unused                 -
ACE-AP-C-UP2                  No     -    Unused                 -
ACE-AP-C-UP3                  No     -    Unused                 -
ACE-AP-01-LIC                 Yes    1    In use   never         -
ACE-AP-01-UP1                 No     -    Unused                 -
ACE-AP-02-LIC                 No     -    Unused                 -
ACE-AP-02-UP1                 No     -    Unused                 -
ACE-AP-04-LIC                 No     -    Unused                 -
ACE-AP-04-UP1                 No     -    Unused                 -
ACE-AP-04-UP2                 No     -    Unused                 -
ACE-AP-VIRT-5                 No     -    Unused                 -
ACE-AP-500M-LIC               No     -    Unused                 -
ACE-AP-VIRT-020               Yes    1    In use   never         -
ACE-AP-C-100-LIC              No     -    Unused                 -
ACE-AP-C-500-LIC              Yes    1    In use   never         -
ACE-AP-C-500-UP1              No     -    Unused                 -
ACE-AP-OPT-50-K9              Yes    1    In use   never         -
ACE-AP-C-1000-LIC             No     -    Unused                 -
ACE-AP-C-2000-LIC             No     -    Unused                 -
ACE-AP-OPT-LIC-K9             No     -    Unused                 -
ACE-AP-OPT-UP1-K9             No     -    Unused                 -
ACE-AP-SSL-05K-K9             Yes    1    In use   never         -
ACE-AP-SSL-07K-K9             No     -    Unused                 -
ACE-AP-SSL-100-K9             No     -    Unused                 -
ACE-AP-SSL-UP1-K9             No     -    Unused                 -
ACE-AP-SSLUP-5K-K9            No     -    Unused                 -
ACE-AP-VIRT-020-UP            No     -    Unused                 -
Thank you for any help
Yves
Borys Berlog Mon, 01/16/2012 - 07:16
  • Cisco Employee,
Hi Yves
Can you please check if in your accounting log (show accounting) in Admin context you see a lot of messages from user: anm ? (like "anm:0:xml-show on")
I'd suggest to open a TAC case for this issue.
Antonio Knox Mon, 09/24/2012 - 10:09
  • Silver, 250 points or more
Had this issue a month ago.  Try installing the license via GUI.
Cesar Roque Mon, 09/24/2012 - 10:37
  • Bronze, 100 points or more
Hello Yves,
This is actually a bug:
CSCtx03563
Open a TAC case to give you the script.  Dont save the running-config if you have to reboot the ACE
Cesar R
Antonio Knox Mon, 09/24/2012 - 11:11
I hit this bug a while back.  I tried loading the the CSCtx03563_workaround.bin file (after a reload) that Cisco provided, and it didn't work for me.  I was able to handle the task through the GUI, though.  Just trying to save Yves a little time .  Only difference was I was upgrading to 5(2.0), not installing a license.
Related Content
