Enabling the Directory Phone service for a single phone only.
Answered Question
Jan 17th, 2012
Good Day All,
We are in the process of migrating from Call Manager 5 to Call Manager 8.
Up until now,  we have been using the Corporate Directory under call manager 5 via a URL.
http://x.x.x.x:8080/ccmcip/xmldirectoryinput.jsp
I would like to enable the Call Manager 8 Corporate directory under Device>Device Settings>Phone Services; but I will need to limit the acccess to the service to my telephone only during the testing.
http://y.y.y.y:8080/ccmcip/xmldirectory.jsp
Does anyone know how I can do this or point me to the correct document?
Thanks in advance for any assistance.
Amanda
Correct Answer by Carlo Poggiarelli about 5 years 7 months ago
Hi Amanda.
If you want to enable just one phone to view te corporate directory, you have to modify the "URL Directory" value under enterprise parameter with an invalid destination (eg. if your cucm is 10.10.10.10 you can modify with 10.10.10.11) and under phone configuration page , you can specify the right url directory in order to enable that phone to view the Corporate directory of the CUCM.
Carlo
Overall Rating: 5 (1 ratings)
Correct Answer
Carlo Poggiarelli Tue, 01/17/2012 - 01:24
  • Green, 3000 points or more
Hi Amanda.
Carlo
