stuck with nm-cue-ec and a 2851
I read so much stuf in the last weeks and still have no idea how to get the nm-cue-ec running on a Cisco 2851 router.
I can access the web interface of Unity Express and this ask for a username password to initialize the system. All commands I found to configure a username for that faild because the commands are unknown.
IOS is ipvoice 12.4-24 T6 and it seems that the CUE is running version 3.0
Callmanager is Version 7.1.3
Is there a different IOS needed?
interface Service-Engine1/0
ip unnumbered GigabitEthernet0/0
service-module ip address 10.10.10.21 255.255.255.0
service-module ip default-gateway 10.10.10.22
ip route 10.10.10.21 255.255.255.255 Service-Engine1/0
Anyone has an idea how to upgrade CUE or get into it?
any help is welcome...
Eike
barry
Level 7
Level 7
Hi Eike
Have you tried using the "service-engine" exec command on the 2851? You should be able to use this to run a local session onto the service module itself. From there, you should be able to define a new admin account, or even completely wipe and reimage the CUE module.
"service se1/0 session"
HTH. BArry
barry
Level 7
Level 7
Hi Eike
HTH. BArry
wow fast answer and perfect answer.. I didn't try that.
Now I'm in and will start over.
