NTP Issue
Jan 17th, 2012
I am needing a NTP Server in "Windows Server" in such a way to use the NTP in my infrastructure with cisco routers with authentication supports.
I'm testing with "NTP 4.X". The application works without authentication but I can not run with authentication required.
Someone has already gone through this need?
Help me please.
Edgar Servín
Edgar Servin Thu, 01/19/2012 - 15:19
Hi Tkatsiaounis,
Meinberg NTP 4.X is the software I am using.
Its documentation is not very understandable to me.
I can't make it work correctly with authentication.
I set up in my "Cisco router" with the command "ntp authenticate". The "NTP server" continues to operate but by entering the command: "show ntp asso detail" don't shows me the message "authenticated".
Do you have a sample configuration? Could you guide me in my setup, please?
Leo Laohoo Thu, 01/19/2012 - 20:24
Ok then.  It's either you let the routers go out to the net for an authoritative NTP source or you can purchase a "true" NTP server.
When I mean a "true" NTP server, it's not the kind which has to go out to the internet and to get an authoritative source.  I mean the ones with built-in GPS receivers.
Edgar Servin Fri, 01/20/2012 - 13:13
I think it's very difficult to add a GPS for NTP on our infrastructure.
Although I think would be good.
I need an example of configuration of meinberg NTP.
Edgar
Leo Laohoo Fri, 01/20/2012 - 22:47
You don't need to install the NTP server inside the DC.  Find a cabinet that's closest to the ceiling and it'll do fine.  The servers normally come with a magnetic antenna.
Edgar Servin Mon, 01/23/2012 - 03:45
Hi Leo,
We didn't planning an acquisition of a GPS for NTP.
Just for that I'm looking for the solution through the Meinberg NTP.
It is not necessary for our infrastructure a NTP server so specialized.
Only one that allows us to maintain uniform time in the network of PCs and routers, that provides NTP authentication.
Edgar
Gerardo Marcial... Sun, 04/08/2012 - 10:12
Hello, I was looking for a solution between many devices on my networks, finally I find a option, use a border router like a NTP Proxy.
I try many setting between MS Windows like a NTP Server over other devices no PCs, in my case don't work, but I try with a Router like NTP Server, perfect work.
Other good practice is send params over DHCP sending to the clients option 42.
Let the commands and screens:
NTP Server ~ Client on the Router:
ntp logging
ntp clock-period 17179973
ntp master
ntp update-calendar
ntp server 129.6.15.29 source FastEthernet1
ntp server 129.6.15.28 source FastEthernet0
Config NTP on DHCP Server:
ip dhcp pool LAN
   network 172.16.1.0 255.255.255.192
   update dns both
   domain-name example.ext
   default-router 172.16.1.1
   dns-server 172.16.1.58
   netbios-node-type b-node
   option 42 ip 172.16.1.1
   lease 0 0 5
   update arp
Analyzing DHCP behavior with Wireshark:
Set on MS Windows:
Depend of MS Windows behaviour, Windows Domain (atomically) Vs Workgroup (set in MS Clients IP or Router FQDN Master NTP)
Cheers!
Related Content
