Warning message
switchport port-security on Routers ?
Jan 17th, 2012
Hi All,
Wanting to restrict LAN ports on a 857 router to particular MAC addresses.
But the router doesn’t support the switchport command at all.
So tried on 1800 series and though it does support "switchport”, it doesn’t support "switchport port-security"
Is there a particular router model that does or any other way around implementing a solution where if a rogue device plugs into the router the port shuts down?
thanks,
Ivan
