Cannot enable Span to PC port on IP Phone
Answered Question
Jan 17th, 2012
Hi all,
I have enabled the "Span to PC Port" in CUCM8.5.1,
but when I press the IP Phone 7970 > Setting > Device Configuration > Ethernet Configuration
It shows the "Span to PC Port" is "No"
Any one know what is the problem ? and how can I enable the Span to PC Port on hard phone?
IP Phone 7970
Load File SCCP70.9-1-1SR1S
Sam
Correct Answer by Aaron Harrison about 5 years 6 months ago
I never use 'apply config'. When I do, I always doubt that it did the right thing, and end up resetting anyway just to make sure.
Most people find a reset pretty unintrusive (it won't interrupt a call for example) and for users it does disrupt a little (e.g. Agent Desktop users) an apply will often do the same anyway. I prefer to know mu changes have definately applied.
Aaron
Correct Answer by yahsiel2004 about 5 years 6 months ago
Did you reset the phone?
Yosh
Overall Rating: 5 (2 ratings)
Correct Answer
yahsiel2004 Tue, 01/17/2012 - 19:19
  • Gold, 750 points or more
Yosh
samhopealpha Tue, 01/17/2012 - 21:24
thanks, it works now after reset the phone, i thought the "Apply Config" work the same way... but actually it's not
Correct Answer
Aaron Harrison Tue, 01/17/2012 - 23:26
  • Community Spotlight Award,
    Member's Choice, May 2015
Aaron
Related Content
