Warning message
Qos and routing on a stick
Jan 17th, 2012
guys just a quick question: i have configured router on a stick with various vlans routing on a single router fast ethernet port. if i apply a QOS service policy to the actual physical interface instead of the logical interfaces, will everything still work the same as applying the Service-policies to the individual logical interface of the vlan eg fa0/0.50
rsimoni Wed, 01/18/2012 - 01:37
  • Cisco Employee,
well it depends on what you configure on your service policy.
If, for instance, you apply on it a cumulatice policer after a certain threshold is passed, you will be potentially affecting all the flows, even the ones which consume limited bandwidth.
If on the contrary you classify based on vlan tags (if your platform allows that) or base on flows, in principle a phisical level policy can have the same effect of multiplan vlan policies. But again it all depends on what you actually configure.
regards,
Riccardo
