Warning message
crisalex Thu, 01/19/2012 - 14:37
  • Cisco Employee,
HI,
I'm not entirely sure that I fully understand this scenario, but are you trying to disable the audio stream on the system ?
Kindly asked if posssible to provide us few more details about this request
Thanks in advance
Cristian
Jens Didriksen Thu, 01/19/2012 - 17:17
  • Blue, 1500 points or more
The C20 allows for one additional phone call to be added to an existing video call, I suspect he wants to disable that particular function.
cheers jens
hunkw Thu, 01/19/2012 - 18:26
Hi, Cristian,
It's known that c20 with version tc 4.x can be connected to a site with video and audio, meanwhile it can be connected to another audio site. You could say it's a multipoint ability. But we want to forbid this feature in order to avoid some troubles of faulty operation by users. How should we do?
I know there are two method, one is downgrade it to tc3.1.3, and the other is setup the multiway function.
Can you help me to find a kind of api or command way to handle this problem?
Thanks!
Han
Teck Chye Tang Mon, 02/06/2012 - 00:34
  • Cisco Employee,
In the upcoming TC5.1 release, you will be able to use the API command to prevent the second call (audio) from coming in when you are already in a point to point call.
heathrw Tue, 09/18/2012 - 20:17
  • Bronze, 100 points or more
I am also interested in disabling and additional audio call while already in a call/video conference. Is there any direction that can be provided on the new release to disable this.
heathrw Tue, 09/18/2012 - 22:03
I found the release notes for TC5.1.4 and tested the "xConfiguration Conference 1 Multipoint Mode: Off" this does not appear to prevent connecting an audio call while still in a video call.
Teck Chye Tang Wed, 09/19/2012 - 01:20
  • Cisco Employee,
you should be able to use this command to stop any incoming call when you are already in a point to point call.
xConfiguration Conference [1..1] IncomingMultisiteCall Mode:
However, currently there is no command to disable making a second audio call out.
heathrw Wed, 09/19/2012 - 17:06
I need the outbound blocked as users have been known to accidently make a second call. Just need to lock it down as it is an environment that has a high level of confidentiality and this is a risk.
Teck Chye Tang Wed, 09/19/2012 - 21:25
  • Cisco Employee,
not possible currently.  You might want to consider working with your cisco representative to put up a feature request for that.
