VOIP QoS over L2L VPN on a ASA5505
I have 4 remote sites that are using a ASA as thir firewall / router. I'm setting up a full mesh VPN between all the sites. One of the sites have a UC500 and the other sites access that UC over the VPN tunnels. I would like to set up some basic QoS for the VOIP traffic
Lets say a remote site has 10mb down / 1mb up and I use the following config
ASA(config)# priority-queue outside
ASA(config)# class-map TG1-voice-class
ASA(config-cmap)# match tunnel-group (VPN 2L2 TUNNLE NAME BACK TO UC)
ASA(config-cmap)# match dscp ef
ASA(config-cmap)# policy-map priority-policy
ASA(config-pmap)# class TG1-voice-class
ASA(config-pmap-c)# priority
ASA(config-pmap-c)# policy-map shape-priority-policy
ASA(config-pmap)# class class-default
ASA(config-pmap-c)# shape average 900000
ASA(config-pmap-c)# service-policy priority-policy
ASA(config-pmap-c)# service-policy shape-priority-policy interface outside
To me this would only limt the VPN to 900kb with 100kn reserved for VOIP but non VPN traffic would not be shapped
I would like to limit all traffic with some reserced space for VOIP and then give it priorty.
Second question:
The site that has the UC will have multiple vpn tunnles coming in from the remote sites. How will I do QoS with voice traffic on that site?
Overall Rating: 3.7 (3 ratings)
ajay chauhan Thu, 01/19/2012 - 06:25
  • Silver, 250 points or more
OK let me try to explain -
Here two service-policies are configured one is matching VPN voip traffic and another one is global .Inside global policy you have configured
shape average 900000  < This is for match class-default all the traffic which is not matching in any specific class will be matched here. Just in case of congestion remaining BW will be guaranteed for voice.
Ajay
ajay chauhan Thu, 01/19/2012 - 12:53
Hi Jason,
You can call multiple calss-map under same policy-map. Here it will be little tricky to allocate the required bandwidth.
So you need to adjust bandwidth for  traffic shape.
Ajay
Maybe I should ask the question this way.
I have 5 Site to Site VPN tunnels. I want to apply the QoS to all 5 tunnels to limit the speed to %85 and reserver %15 for VOIP.
With my example above I am able to do this if I have one tunnle but not sure how to make it work with more then one tunnel.
I was thinking I could use a match statment that uses a ACL to match all LAN traffic that would be going to the other remote sites but I get the following error:
ERROR: Multiple match commands are not supported except for the 'match tunnel-group or default-inspect-traffic' command.
ajay chauhan Wed, 02/01/2012 - 12:34
I would say you should calculate total BW required for VOIP and based on that configure shape . Ofcourse you wont like to drop voice calls. QOS will only work when there is congestion else all free to go.
How do you apply this type of QoS when there is more the one tunnel in place?
Do I need to make 5 policy maps such as (only made 2 as an example)
match tunnel-group AAA
match dscp ef
class-map TG2-voice-class
match tunnel-group BBB
match dscp ef
priority
class class-default
shape average 14256000
class TG2-voice-class
priority
class class-default
So this will limit the upload speed to 14256000 and allow the rest of the BW to VOIP?
ajay chauhan Wed, 02/01/2012 - 22:04
create multiple class-map like-
match dscp ef
call all of them under-
Ajay
Related Content
