svcdisabled (nodemgr) from a failed hard disk
Jan 18th, 2012
Hello
I'm seeing the following services disabled on a WAE-574 device (4.4.1). This started happening after replacing a failed hard disk. I tried doing a disk delete-data-partition but I'm still getting the alarms below.
How can I restart the nodemgr svc? The CIFS AO won't come up, tried restarting it. Do I need to wait until the disk completely rebuilds itself? The partitions are still synchronizing which takes all day to finish.
Critical Alarms:
        Alarm ID                 Module/Submodule               Instance
   1 svcdisabled               nodemgr                      device_mgr
   2 svcdisabled               nodemgr                      actastor_watchdog
Major Alarms:
None
Minor Alarms:
   1 primary_interface         CIFS_AO/primary_interface    CIFS_AO      <--  The primary interface is set to standby 1. don't know why it thinks it's not set.
how disk det
Physical disk information:
  disk00: Present    9WJ1NY25   (h00 c00 i00 l00 - Int DAS-SATA)
          476937MB(465.8GB)
  disk01: Present    9WJ1NXR1   (h01 c00 i00 l00 - Int DAS-SATA)
          476937MB(465.8GB)
Mounted file systems:
MOUNT POINT      TYPE       DEVICE                SIZE     INUSE      FREE USE%
/sw              internal   /dev/md0             991MB     710MB     281MB  71%
/swstore         internal   /dev/md1             991MB     477MB     514MB  48%
/state           internal   /dev/md2            5951MB     173MB    5778MB   2%
/local/local1    SYSFS      /dev/md4           14878MB     132MB   14746MB   0%
/vbspace         GUEST      /dev/data1/vbsp   188467MB     128MB  188339MB   0%
.../local1/spool PRINTSPOOL /dev/data1/spool     991MB      32MB     959MB   3%
/obj1            CONTENT    /dev/data1/obj    121015MB     128MB  120887MB   0%
/ackq1           internal   /dev/data1/ackq     1189MB       0MB    1189MB   0%
/plz1            internal   /dev/data1/plz      2379MB       1MB    2378MB   0%
/dre1            CONTENT    /dev/data1/dre    119031MB  116977MB    2054MB  98%
Software RAID devices:
  DEVICE NAME  TYPE     STATUS                PHYSICAL DEVICES AND STATUS
  /dev/md0     RAID-1   NORMAL OPERATION      disk00/00[GOOD]  disk01/00[GOOD]
  /dev/md1     RAID-1   REBUILDING (0.0%)     disk00/01[GOOD]  disk01/01[!!NOT UP TO DATE!!]
  /dev/md2     RAID-1   NORMAL OPERATION      disk00/02[GOOD]  disk01/02[GOOD]
  /dev/md3     RAID-1   NORMAL OPERATION      disk00/03[GOOD]  disk01/03[GOOD]
  /dev/md4     RAID-1   REBUILDING (0.0%)     disk00/04[GOOD]  disk01/04[!!NOT UP TO DATE!!]
  /dev/md5     RAID-1   REBUILDING (52.3%)    disk00/05[GOOD]  disk01/05[!!NOT UP TO DATE!!]
  *** NOTE ***
  One or more RAID constituent disk partitions appear to be abnormal.
  This could be because of
  problem in drive's partition(s) and it is being rebuilt
  Possible I/O errors on a disk drive
  Please run "show alarms critical detail support"
  to check any critical disk errors.
  RAID-1 volumes will continue to operate on the remaining disk drive.
  Please refer to the product documentation for further
  information on how to handle this situation.
Disk encryption feature is disabled.
