OSPFand BGP on same router
Jan 18th, 2012
I'm hoping someone has come across this before and has the solution. I have a scenario with a Cisco 6506 and a 7206. The 6506 is running BGP and peers with our data center router. The 7206 is a stub router off the 6506 and is used as an edge router for customer T1 circuits. I want to use OSPF between the routers to exchange connected and static routes. The problem I have is that static BGP null routes on the 6506 are overriding the OSPF routes being received from the 7206.
Example:
The 6506 is advertising a class C network 192.168.1.0/24 to our data center. The 6506 does not utilize the 192.168.1.0/24 network. It is only used on the 7206 for customer T1 circuits and is carved up into /29 subnets. So the 6506 has a static route: ip route 192.168.1.0 255.255.255.0 null 0. Today the routing is accomplished with static routes on the 6506 for the 192.168.1.0 networks on the 7206. Using OSPF the 7206 advertises /29 links back to the 6506, but when I withdraw one of the /29 static routes from the 6506, the /24 null route takes precedence over the more specific /29 routes and the traffic is black-holed on the 6506.
So my question is - how can I get the OSPF routes to look preferable to the /24 null route on the 6506?
Thanks for the help and let me know if my example is not clear.
Konstantin Dunaev Wed, 01/18/2012 - 13:50
  • Bronze, 100 points or more
considering,  you have configured "ip classless" routing (meantime is default) then the routing decision process should look like
- most specific prefix is always preferable
- if there is a kind of "super-net" of those prefixes in a routing table and the most specific prefix is not there, then that super-net rouing entry will be followed
- if a prefix doesn't match any routing table entry then it uses "default" route if it presents or it will be dropped in other case.
You say that your routing table on c6500 prefers a /24 prefix to a /29? It can't be true. Are you sure that the routing entry for that /29 is "active" ?
danielboscia Wed, 01/18/2012 - 14:02
Thanks for the reply. I do have the "ip classless" statement in the config. The /29 subnets are active and I can also duplicate this behavior with a loopback interface on the 7206.
Please let me know if I can provide any additional information.
Konstantin Dunaev Wed, 01/18/2012 - 14:16
please post the "show ip route" for both /24 and /29 prefixes.
how do you configure the loopback? Do you redistrubute  it to OSPF or do you announce it to OSPF via "network" command?
Kishore Chennupati Thu, 01/19/2012 - 03:28
  • Gold, 750 points or more
Daniel,
So, the problem seems to be that when the more specific /29 is not available on the 6500 so the traffic coming from the Data centre is blackholed because you are advertising the 192.168.1.0 via BGP to the Data Center. because the network is always advertised to the Data centre via BGP.
The solution is not to advertise the network(192.168.1.0/24) when the /29 is not available on the 6500. Would that help?
If you do not want this to happen and advertise the network to the DC only when it is truly reachable, the config will be as follows
route-map Adv192.168.1.0 deny 10
match interface Null0
route-map Adv192.168.1.0 permit 20
router bgp
network 192.168.1.0 mask 255.255.255.0 route-map Adv192.168.1.0
Give it a try and let us know.
Kishore
Richard Burts Thu, 01/19/2012 - 06:50
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
I am confused about the symptoms and hope that the original poster can provide some clarification. He says:"
but when I withdraw one of the /29 static routes from the 6506, the /24  null route takes precedence over the more specific /29 routes and the  traffic is black-holed on the 6506."
In trying to understand this I am trying to construct an example in my mind. I am assuming that 192.168.1.64/29 might be one of the routes advertised by the 7206. So if he withdraws the advertisement of 192.168.1.64 is he saying that it impacts other parts of 192.168.1.0 (like maybe it impacts 192.168.1.128/29) or only that now traffic to 192.168.1.64 is blackholed?
Rick
axeleratorcisco Thu, 02/23/2012 - 08:12
same problem here, can someone help?
router is running ospf to r2 and r3, and bgp with r4 which is service provider
i made a static route to let's say the 30 network on r2 and r3, and under ospf i do a "redistribute subnets", to get the route in routing table of r1
on r1 i see these routes being learned, but i can not redistribute those learned routes into bgp
i thought the solution was to create a static route for the 30 network on r1, and then issue a "redistribute static" under the bgp process on r1
it does advertise the route to the provider, but it has also overwritten the ospf learned E2 routes
so the provider can send all the packets to r1, because the 30 network is being advertised via bgp, and they will end up on r1
but since there is no routes to the 30 network in my ip routing table (they are still there in the ospf database), how can i make this network available
redistributing ospf under bgp doesn't work, match external 2 doesn't work, route map doesn't work, network command doesn't work to advertise to provider
suggestions?
axeleratorcisco Fri, 02/24/2012 - 06:54
issue is solved
turns out bgp network command does work for me, as in my routing table on r1 i am getting ospf e2 routes to the 30 network, and thus i can advertise them into bgp
my prefix list out to the provider was blocking the 30 network, as i had a specific subnet mask allowed (/28) while the actual network was /29 and i had no le 32 option behind my prefix list
Related Content
