problem in the network
Jan 19th, 2012
Hello, I have problems in the following scenario. I attached an image with a summary diagram of the network in question.
The  problem is that on the 3rd floor of the site users connect via wireless  fail to connect and receive an IP. But they can not navigate. The  second and first floor itself.
As you see in the diagram are 3  routers, one per floor. The first is the only router that provides DHCP  the other two routers are as simple Access Points.
All comments will be helpful to me. thanks
Go here to view the post in the forum spanish of support of cisco :
https://supportforums.cisco.com/message/3532352#3532352
Neeraj Arora Fri, 01/20/2012 - 03:44
Hi Marcus,
Although the information provided above is not enough to give proper suggestions, still I would like to know if you have configured "ip helper-address" command on Router2 & Router3 pointing towards Router1 (which as per the description is the DHCP server)
This "ip helper-address" command need to be configured on the Vlan/Interface assigned for third Floor users having an ip address for which there is a DHCP pool on Router 1.
For better solution, please provide more info about the profile and configuration of the routers
Hope it helps
Neeraj
