UCS FC Port-Channel to MDS Failing
Jan 20th, 2012
Hello all, I'm attempting to create an FC port-channel from my 6120XP to an MDS 9148. I have NPIV as well as F-Port-Channel-Trunking features enabled. Right now I'm just trying to get the port-channel itself working and not worrying about the trunking aspect just yet (uplink trunking is turned off on the FI). The MDS is running 5.0(1a) and the FIs are on 2.1t. I have confirmed that single uplinks do come up, but whenever I try to bind them into a port-channel, the links themselves go into an "error disabled" state. I've gone over previous articles and docs on here and haven't been able to shed any light on why this isn't working. Any assistance would be greatly appreciated. Uplink error and MDS configs below. Thanks!
feature npiv
feature fport-channel-trunk
interface port-channel 4
  channel mode active
  switchport mode auto
  switchport rate-mode dedicated
  switchport trunk mode off
interface fc1/13
  port-license acquire
  channel-group 4 force
  no shutdown
interface fc1/14
  no shutdown
padramas Fri, 01/20/2012 - 09:30
  • Cisco Employee,
Does VSAN configuration on both ends match ?
On UCS FI
connect nxos
show int san-port-channel X
MDS
show int port-channel X
Padma
ufjp Fri, 01/20/2012 - 09:42
Hi Padma, thanks for the response. It appears so, I'm using the default VSAN (1) for both ends, which seems to work for single links. Here's the output from both ends:
MDS:
HSANSW1# sh int port-channel 4
port-channel 4 is down (No operational members)
    Hardware is Fibre Channel
    Port WWN is 24:04:64:00:f1:2e:d2:f8
    Admin port mode is auto, trunk mode is off
    snmp link state traps are enabled
    Port vsan is 1
    5 minutes input rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
    5 minutes output rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
      54 frames input, 6152 bytes
        0 discards, 0 errors
        0 CRC,  0 unknown class
        0 too long, 0 too short
      50 frames output, 5908 bytes
      88 input OLS, 30 LRR, 18 NOS, 0 loop inits
      61 output OLS, 4 LRR, 64 NOS, 32 loop inits
    Member[1] : fc1/13
    Member[2] : fc1/14
FI:
UFAB1-B(nxos)# show int san-port-channel 4
san-port-channel 4 is down (No operational members)
    Port WWN is 24:04:54:7f:ee:1f:89:80
    Admin port mode is NP, trunk mode is off
    Port vsan is 1
    1 minute input rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
    1 minute output rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
      62 frames input, 8104 bytes
      60 frames output, 6524 bytes
      1 input OLS, 1 LRR, 1 NOS, 0 loop inits
      43 output OLS, 21 LRR, 1 NOS, 0 loop inits
    last clearing of "show interface" counters never
    Member[1] : fc2/1
    Member[2] : fc2/2
David McFarland Fri, 01/20/2012 - 09:58
  • Cisco Employee,
Would you provide the output of the interface configs
show run interf fc 1/13-14
show run interf san-port-channel 4
Dave
ufjp Fri, 01/20/2012 - 10:01
Sure, thanks Dave:
HSANSW1# sh run int fc1/13-14
!Command: show running-config interface fc1/13-14
!Time: Fri Jan 20 10:01:40 2012
version 5.0(1a)
interface fc1/13
  no shutdown
interface fc1/14
  no shutdown
UFAB1-B(nxos)# sh run inter san-port-channel 4
!Command: show running-config interface san-port-channel 4
!Time: Fri Jan 20 18:02:39 2012
version 5.0(3)N2(2.1t)
  channel mode active
  switchport mode NP
David McFarland Fri, 01/20/2012 - 10:14
  • Cisco Employee,
Sorry, one more thing, The output of show vsan memebership from UCS and MDS, you can trim to just the fc and san-port-channels if you want.
Being in non-trunk mode, VSAN membership of all interfaces fc and port-channel must match
Dave
ufjp Fri, 01/20/2012 - 10:18
Not a problem:
MDS:
HSANSW1# sh vsan membership int fc1/13-14
fc1/13
        vsan:1
        allowed list:1-4078,4080-4093
fc1/14
        vsan:1
FI:
UFAB1-B(nxos)# sh vsan membership int fc2/1-2
fc2/1
        vsan:1
fc2/2
        vsan:1
ufjp Fri, 01/20/2012 - 12:10
Well I guess there's an issue with the 9148. We have a 9124 that had a single free port so I configured the PC on it maching what the 9148 had and it came up immediatley. Both MDSs are on the same NX-OS version 5.0(1a). Any config ideas (I'm comparing the configs now) or maybe a bug?
ufjp Thu, 02/02/2012 - 13:20
Thanks, I've been meaning to update, but the issue still isn't resolved. We're hitting bug: CSCtq08625
The switch also has a field notice for incorrect MAC programming. The new OUIs were included in FM 5.0(4d) and later I believe (we're running 5.0(4d) and no problems with it). Right now TAC is escalating to development.......
Related Content
