Warning message
Cisco 2801 as a PBX/VXML Gateway?
Jan 20th, 2012
Hi Folks,
I want to set up a small proof of concept IP-PBX system for R&D purposes. Specifically, I'm aiming to setup a mini Cisco PBX, and configure one of the extensions to be an IVR, calling onto our own custom dynamically-JSP-generated VXML applications.
At the moment all of our custom VXML apps are Genesys GVP friendly, however I'm curious to find out if there's much work involved with re-factoring them to play nice with Cisco's VXML browser and associated ASR/TTS engines.
My question - I have an old CISCO2801 sitting in the office (order description "2801 ROUTER/PWR 2FE 4SLOT 2HWICS 2AIMS IP BASE 64F/128D UK"). Is it possible to purchase an expansion module for this and configure it as an IP-PBX with VXML capabilities (including support for third party TTS/ASR engines)?
If so, I'll then purchase a single Cisco IP desk phone and register it against the 2801, call in and see if I can interact with our VXML apps.
Many thanks,
Alistair
paolo bevilacqua Fri, 01/20/2012 - 07:22
  • Hall of Fame,
    Founding Member
Yes, that can be done. You just need a RAM and Flash upgrade to support recent IOS.
Related Content
