Published VODs No Longer Playable
Jan 20th, 2012
Just ran into this weird problem with our Show & Share (v.5.3). When I upload videos to the server everything looks fine but as soon as I publish those video they are unplayable. No error or anything the video just wont start. Any help would be appreciated
Average Rating: 0 (0 ratings)
mcassini Thu, 02/23/2012 - 08:54
Hi Steven,
I assume you have an external server that you have defined in the Show and share config to store the published videos, correct?
When you upload the video on the Show and Share and try a preview, the video would be playing from the Show and Share device itself. When you publish the video, it is then deployed to the external server you have defined (unless you selected the "publish locally" option). At that point, when you try to play the video, it will be accessed using the base URL for the external server you have defined in your Show and share config.
I would double check if the extenal server location and base URLs used to reach it haven't changed after you had set it up.
Marco
Login or Register to take actions
Posted January 20, 2012 at 9:03 AM
Stats:
Replies:1 Avg. Rating:
Views:559 Votes:0
Shares:0
Related Content
Discussions Leaderboard
