Can Cisco 2925 be converted to an SRST Router?
Vishal Bhardwaj
Customer has an existing Cisco 2925 Router and he wants to make it SRST Router. I tried to find something on 2925 but I am not able to find anything so I am assuming it is end of life. So, question is if I send him the SRST licensing, would he be able to make it work?
Vishal
2 Accepted Solutions
paolo bevilacqua
Cisco never made a router model 2925.
Take "show version" to know what model is that, or read the label below or on the back of the unit.
It's a typo in the doc, there are no 2925, only 3925s.
Chris
6 Replies 6
paolo bevilacqua
Hi Paolo,
First of all thanks for replying so quick ..
Now, First i thought that too but when I saw the following link and mention of Cisco 2925 router in there I talked to myself and said I might be wrong . .that's when i posted here.. but yes I will ask for Show run and then I can search more..
But just to know..to make a Simple Router as either CME or SRST.. Can a FL-CME or -SRST is enough? or there's something else I should keep in mind?
Chris
Cool, Thanks Chris.. that really helps.
For SRST you also need voice interfaces, PVDM modules, UC license..Is not that simple really.
Thanks for the nice rating and good luck!
