Chris Deren Sun, 01/22/2012 - 09:07
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
is it for the correct device type?
kevin.sullivan Sun, 01/22/2012 - 09:35
Yes it is the same device type. It will show up in find and list phone button templates but when I go to build a new phone or change the phone button template it does not show up in the drop down list.
Chris Deren Sun, 01/22/2012 - 09:44
  • Hall of Fame,
how is your database replication looking?
Rob Huffman Sun, 01/22/2012 - 10:07
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
    2017 IP Telephony, Unified Communications
Hi Kevin,
Can you please tell us the phone model you are trying to add a template for
and the exact CUCM version you are running??
Cheers!
Rob
