01-22-2012 11:32 PM - edited 03-07-2019 04:29 AM
Is there any issue , if OQD is high on particular interfaces, if so what need to be done ?
INHY_MFVS#sh int summ
INHY_MFVS#sh int summary
*: interface is up
IHQ: pkts in input hold queue IQD: pkts dropped from input queue
OHQ: pkts in output hold queue OQD: pkts dropped from output queue
RXBS: rx rate (bits/sec) RXPS: rx rate (pkts/sec)
TXBS: tx rate (bits/sec) TXPS: tx rate (pkts/sec)
TRTL: throttle count
Interface IHQ IQD OHQ OQD RXBS RXPS TXBS TXPS TRTL
Vlan1 0 0 0 0 0 0 0 0 0
* Vlan105 0 0 0 0 4000 7 4000 5 0
FastEthernet0 0 0 0 0 0 0 0 0 0
* GigabitEthernet1/0/1 0 0 0 24210 875000 63 46000 50 0
* GigabitEthernet1/0/2 0 0 0 0 0 0 1000 2 0
GigabitEthernet1/0/3 0 0 0 0 0 0 0 0 0
* GigabitEthernet1/0/4 0 0 0 0 0 0 1000 2 0
* GigabitEthernet1/0/5 0 0 0 5154 1000 0 32000 4 0
* GigabitEthernet1/0/6 0 0 0 0 0 0 1000 2 0
* GigabitEthernet1/0/7 0 0 0 0 0 0 1000 2 0
* GigabitEthernet1/0/8 0 0 0 0 4000 3 5000 5 0
* GigabitEthernet1/0/9 0 0 0 0 3000 2 5000 5 0
* GigabitEthernet1/0/10 0 0 0 0 0 0 1000 3 0
* GigabitEthernet1/0/11 0 0 0 637 1444000 269 3104000 743 0
* GigabitEthernet1/0/12 0 0 0 0 2818000 329 0 0 0
* GigabitEthernet1/0/13 0 0 0 0 763000 224 97000 66 0
* GigabitEthernet1/0/14 0 0 0 34 27000 21 19000 15 0
* GigabitEthernet1/0/15 0 0 0 0 0 0 0 0 0
Thanks in advacne !!
Thanks & Regards ,
T Rajneesh R
01-27-2012 05:05 AM
Output queue drops means the interface is congested (its receiving more information than it can send). If the interface is at its maximum speed (in this case, gigabit) and operating in full duplex mode, there is not much more you can do besides increasing the receiving capacity of the other end of the output queue dropping interfaces. If these are workstations or uplinks to other switches, a low amount (which it is, in your case) of OQD's are normal.
01-27-2012 05:13 AM
Maybe check the end device that is connected to that port.
