Showing results forĀ
Search instead forĀ
Did you mean:Ā
DHCP Blocked by VLAN
airiedemann
We have a server that we remove from the rack. The only role it has is to give out DHCP on the wireless network. I tried enabling  the built in DHCP server on  the Airespace 4112, though a Catalyst 3750G, but I dont get an address when I'm connected to the wireless network even though the range is enabled. If I set an static IP on my wireless card I can access the network. I also tried enabling DHCP on a Sonicwall that is connected to the Catalyst 3750G.
Do I need to link the DHCP scope to the wireless network?
Is there anything on the switch that would be blocking DCHP since it on a VLAN?
I have the last four ports in a VLAN for the AP's and the internet connection to the Sonciwall.
Thanks fort the help.
go to the interface VLAN where your client are and modify the ip helper-address if necessary.
Regards.
Alain
6 Replies 6
sleepyshark
Did you delete the existing DHCP scopes on the server?  Also, what was the old IP of the server?  When you re-added it to the network did you use the same IP address?  Have you made any other changes to the server/network (particularly network/gateway/routing changes)?
Sean Brown
http://www.sleepyshark.com
I didnt delete the scope I just unplugged the server so it wouldnt give out DHCP.
I didnt re-add it since I want to use the Airespace built in DHCP server. For now we have the old server plugged in giving out DHCP till I can track down why the only thing that can give out DHCP is the server.
is the DHCP server on a different subnet than the clients? if so have you updated the ip helper-address to point to the new DHCP server? and also does the new DHCP server knows how to get to this subnet( with a static route for example)?
Regards.
Alain
Ill check the server but I'm pretty sure that its on the same subent.
Where do I update the ip helper-address?
Regards.
Alain
I ended up using the override DHCP option in the Airespace and pointing the ip to itself.
