Packet drops in HQF class !
Jan 24th, 2012
Hello!
The following part of policy-map shows  there are dropped packet in class ( WAN_DSCP_CS1 drop rate 3000 bps )
The actually rate is lowest as target shape rate and the no-buffer drops counter is zero!
The full config contains appr. 100 branch-class and every branch-class call the WAN_OUTPUT_V.1 policy.
We applied the service-policy on GigabitEthernet 0/3.
The hardware is 7206VXR-G1 the softver is 12.4.20.T advanced ip services
How it is possible to find it how the router throws away the packets why?
Class-map: debrecen (match-any)
      6100639 packets, 2386603748 bytes
      30 second offered rate 1179000 bps, drop rate 3000 bps
      Match: access-group name debrecen
        30 second rate 1179000 bps
      Queueing
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/26308/0
      (pkts output/bytes output) 3024421/1270775183
      shape (average) cir 1900000, bc 7600, be 7600
      target shape rate 1900000
      Service-policy : WAN-OUTPUT-V.1
        queue stats for all priority classes:
          Queueing
          (queue depth/total drops/no-buffer drops) 0/0/0
          (pkts output/bytes output) 661602/88789612
        Class-map: WAN_DSCP_EF (match-all)
          1323206 packets, 143171814 bytes
          30 second offered rate 2000 bps, drop rate 0 bps
          Match: ip dscp ef (46)
          Priority: 17% (323 kbps), burst bytes 8050, b/w exceed drops: 0
          QoS Set
            cos 5
              Packets marked 661602
        Class-map: WAN_DSCP_CS3 (match-any)
          16294 packets, 8056869 bytes
          30 second offered rate 0 bps, drop rate 0 bps
          Match: ip dscp cs3 (24)
            0 packets, 0 bytes
            30 second rate 0 bps
          Match: ip dscp af41 (34)
            0 packets, 0 bytes
          Queueing
          (pkts output/bytes output) 8147/4249838
          bandwidth 3% (57 kbps)
        Class-map: WAN_DSCP_CS1 (match-any)
          1244538 packets, 279892316 bytes
          30 second offered rate 109000 bps, drop rate 3000 bps
          Match: ip dscp cs1 (8)
            0 packets, 0 bytes
          Match: protocol eigrp
            0 packets, 0 bytes
          Queueing
          queue limit 128 packets
          (pkts output/bytes output) 596188/153156045
          bandwidth 40% (760 kbps)
GigabitEthernet0/3 is up, line protocol is up
  Hardware is MV64460 Internal MAC, address is 0019.56b2.c419 (bia 0019.56b2.c419)
  Description: INTERLINK Multiflex
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
     reliability 255/255, txload 2/255, rxload 1/255
  Encapsulation 802.1Q Virtual LAN, Vlan ID  1., loopback not set
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is RJ45
  output flow-control is XON, input flow-control is XON
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 19:18:51
  Input queue: 0/300/669/0 (size/max/drops/flushes); Total output drops: 275049
  Queueing strategy: Class-based queueing
  Output queue: 102/1500/0 (size/max total/drops)
  30 second input rate 5518000 bits/sec, 3183 packets/sec
  30 second output rate 9701000 bits/sec, 3662 packets/sec
     120693102 packets input, 4292419309 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     1 input errors, 0 CRC, 0 frame, 0 overrun, 1 ignored
     0 watchdog, 19340047 multicast, 0 pause input
     128241462 packets output, 4017681995 bytes, 0 underruns
Joseph W. Doherty Tue, 01/24/2012 - 07:10
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
Might be insufficient queue space for bursts.
Joseph W. Doherty Wed, 01/25/2012 - 02:11
Disclaimer
Posting
KAROLY KOHEGYI wrote:
The no-buffer drops is zero!
How can i check the queue space?
If I remember correctly, no-buffer drops being zero just means you did not run out of physical buffer space.  The drops you're seeing, I believe, are you're just hitting your logical queue depths.  The queue limits are what might be increased.
Joseph W. Doherty Wed, 01/25/2012 - 07:06
Disclaimer
Posting
The queue-depth is zero also!
it is confuse!
Queue-depth is number of packets in queue at time of snapshot - not uncommon to get drops and not "catch" packets in queue in cases of transient bursts.
KAROLY KOHEGYI Wed, 01/25/2012 - 03:20
Here is the newest confuse issue!
The offered rate is higher than shap rate and no drops ! (close to  shape peak !!! )
sho policy-map interface output class pecs
GigabitEthernet0/1
GigabitEthernet0/3
  Service-policy output: MF
    Class-map: pecs (match-any)
      46762967 packets, 21107524803 bytes
      30 second offered rate 3665000 bps, drop rate 0 bps
      Match: access-group name pecs
        46762968 packets, 21107524681 bytes
        30 second rate 3665000 bps
      Queueing
      (queue depth/total drops/no-buffer drops) 166/155121/0
      (pkts output/bytes output) 23505715/11060330966
          Queueing
          (pkts output/bytes output) 3019213/402263119
          6027535 packets, 646795939 bytes
          30 second offered rate 43000 bps, drop rate 0 bps
          QoS Set
            cos 5
              Packets marked 3019213
          81716 packets, 73702102 bytes
          30 second offered rate 4000 bps, drop rate 0 bps
            0 packets, 0 bytes
            0 packets, 0 bytes
          Queueing
          (queue depth/total drops/no-buffer drops) 0/83/0
          (pkts output/bytes output) 40779/37813432
          2480434 packets, 382699335 bytes
            0 packets, 0 bytes
            0 packets, 0 bytes
          Queueing
          (queue depth/total drops/no-buffer drops) 0/33688/0
          (pkts output/bytes output) 1345706/227547725
        Class-map: WAN_DSCP_CS2 (match-all)
          512708 packets, 73151425 bytes
          Match: ip dscp cs2 (16)
          Queueing
          (pkts output/bytes output) 256354/43483468
          bandwidth 15% (285 kbps)
        Class-map: WAN_DSCP_AF11 (match-all)
          20029430 packets, 2618963100 bytes
          30 second offered rate 166000 bps, drop rate 0 bps
          Match: ip dscp af11 (10)
          Queueing
          (queue depth/total drops/no-buffer drops) 0/1929/0
          (pkts output/bytes output) 10117875/1580628559
          bandwidth 5% (95 kbps)
        Class-map: class-default (match-any)
          17631141 packets, 17312212798 bytes
          30 second offered rate 3448000 bps, drop rate 0 bps
          Match: any
          Queueing
          queue limit 256 packets
          (queue depth/total drops/no-buffer drops) 165/119421/0
          (pkts output/bytes output) 8725788/8768594663
          bandwidth 20% (380 kbps)
mmihalyf Tue, 01/24/2012 - 09:31
  • Cisco Employee,
Can you please try increasing the BC and BE values after your shape command?
Joseph W. Doherty Tue, 01/24/2012 - 10:05
Disclaimer
Posting
An interesting suggestion.  Newer IOS seem to default to a 4 ms Tc rather than 25 ms Tc.  What you thinking for Tc, maybe 10 ms (19,000 Bc)?
