Warning message
ASA5505 SSL VPN Licensing
Jan 24th, 2012
Hi All,
I like to know whether I will need to get the Security Plus license "ASA5505-SEC-PL=" for my ASA5505-50-BUN-K9, if I intend to support 25 concurrent SSL VPN user connecting to this ASA? Or I just need to purchase either the 25 SSL VPN Premiun User license "L-ASA-SSL-25=" or the SSL VPN Essential license "ASA-AC-E-5505=" will do?
Best regards,
Jonathan Ng
jonathan_ng Tue, 01/24/2012 - 23:40
Hi kmccourt,
Thanks for the info. So if I only need to enable the ASA5505 to support more than 10 IPsec VPN session and not SSL VPN seesion, I should go for the Security Plus license, right?
kmccourt Tue, 01/24/2012 - 23:49
  • Bronze, 100 points or more
Correct. For more than 10 IPsec v1 connections you would need a Sec Plus license.
I think that you need Anyconnect licenses for IPsec v2.
