01-26-2012 05:12 AM - edited 03-16-2019 09:13 AM
I have configured an H323 gateway and all incoming call receive the following -
I have attached the config, but the dial-peers seem to be matched, so l am not sure why the incoming calls fail.
Jan 26 13:02:49.176: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0001
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Calling Party Number i = 0x2180, '1383413747'
Plan:ISDN, Type:National
Called Party Number i = 0x81, '427199'
Plan:ISDN, Type:Unknown
Jan 26 13:02:49.176: ISDN Se0/0/0:15 Q931: Received SETUP callref = 0x8001 callID = 0x0061 switch = primary-net5 interface = User
Jan 26 13:02:49.176: ASSERTION FAILED : ../voip/cctsp/tsp_cdapi.c: tsp_cdb_assert_check: 9517
Jan 26 13:02:53.156: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0001
Sending Complete
Standard = CCITT
Jan 26 13:02:53.156: ISDN Se0/0/0:15 **ERROR**: L3_GetUser_NLCB: DUPLICATE SETUP, message ignored.
Jan 26 13:02:56.328: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x0001
Cause i = 0x8090 - Normal call clearing
Jan 26 13:02:56.328: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x8001
Jan 26 13:02:56.392: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x0001
FCBC-POR-R01#
Jan 26 13:04:42.400: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=1383413747, Called Number=427199, Voice-Interface=0x2B675B6C,
Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=802
Jan 26 13:04:42.400: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
Calling Number=1383413747, Called Number=427199, Voice-Interface=0x0,
Peer Info Type=DIALPEER_INFO_FAX
Result=NO_MATCH(-1) After All Match Rules Attempt
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
Jan 26 13:04:42.400: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=, Called Number=427199, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=427199
Result=Success(0) after DP_MATCH_DEST
Jan 26 13:04:42.400: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=1
2: Dial-peer Tag=2
Jan 26 13:04:42.400: ASSERTION FAILED : ../voip/cctsp/tsp_cdapi.c: tsp_cdb_assert_check: 9517
James
01-26-2012 06:38 AM
James,
Looks like you are hitting a bug
CSCsm31235
Check IOS and up or downgrade
Alex
Please rate useful posts
01-30-2012 08:16 AM
Alex,
Thanks for getting back to me on this.
I had logged a TAC case at the same time of creating this on the forums. Cisco TAC advised me that they have a number of internal notes highlighting the a reboot of the ISR router was required for the H323 incoming call leg to be functional.
I scheduled a reload for that evening, and after the router was back online, l could make calls into the CUCM system.
Thanks for getting back to me.
James
