Warning message
Call Flow information
Answered Question
Jan 26th, 2012
Where can i find info on how call flow works on CUCM?
For example, i want to know the info bellow, where can i find it?
User A calls User B. They are using G729 because they region config.
Then User B transfer the call to User C, so User A and User C start talking... but they region's config is to use G711... so they will use G711, right?
Where can i find a Cisco Doc about how will this (and others) call flow work??
Correct Answer by Jaime Valencia about 5 years 6 months ago
this might help, but honestly, the best way to learn that is to actually pull some traces out from a successfull call (whatever you're trying to figure out how it works) and read them to understand how they should look
SCCP Call Flows
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cata/186_188/2_15_ms/english/administration/guide/sccp/sccpaaph.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (1 ratings)
Chris Deren Thu, 01/26/2012 - 08:56
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
This is all based on how you configure CUCM, for best practice design check out Cisco Communications Manager SRND doc for your CUCM version.
HTH,
Chris
Chris Deren Thu, 01/26/2012 - 09:12
  • Hall of Fame,
Well, SRND is a guidance on what you might want to use, but ultimately it is the design engineer's job to design it to use proper codecs and build respective Regions.  By default this CUCM service parameters define that intra-region calls will use G711/G722 and inter-region calls will use G729, you can either uses these defaults and not make any changes to Regions as you build them, or you can define other codecs within and between regions.
Chris
josepaulopetry Thu, 01/26/2012 - 09:20
ok..
but do you know any doc that says how are the call flow??
I mean in the case of a transfer call... something that says:
Rings User C phone
Check Region config
Negotiate Codec
User C answers
Start Media
etc etc etc
Having this info (how thing should works) turn easier the troubleshooting process when analyzing debugs for example..
Correct Answer
Jaime Valencia Thu, 01/26/2012 - 09:25
  • Cisco Employee,
  • Hall of Fame,
    2011
SCCP Call Flows
java
Leonardo Tadeu Thu, 01/26/2012 - 09:16
  • Blue, 1500 points or more
Hello Jose,
For example if you want to know this you need to see the SRND, if you want no know about location and regions see the section about CAC..
Chris Deren Thu, 01/26/2012 - 09:24
  • Hall of Fame,
Sure, this is controlled by the protocol you are using, i.e. SIP or SCCP, all media capabilities, etc are negotiated between the phone and CUCM via INVITE message for example with capabilities defined in SDP message with SIP. So, if you understand SCCP and/or SIP call flows you understand how this works.
HTH,
Chris
