Warning message
configure 7921
Jan 26th, 2012
I have a 7921 wireless ip phone. I downloaded and installed the 7921 usb install tool, followed directions exact, tried it on 2 different PCs, it wont connect or even ping the phone  at designated ip 192.168.1.100.   Is there another method?    the only missing instruction was the default gateway, but I expect that isnt needed if all on same net.  They had a contractor setup their cisco system but no notes or howtos.
craig
mcecilia Fri, 01/27/2012 - 03:11
You can always configure manually. Remember that when you go into the config, you have to open the lock pressing **# and then make the changes, apply, and so on.
hope this helps
craign1143 Fri, 01/27/2012 - 19:57
Manual worked perfect
Thx
