USB wireless capture
Adnan Khan
Level 4
Level 4
Which device is good to capture wireless beacon frames.
AirPcap or Linksys WUSB600N ver 1, ver 2 (Dual-band USB adapter)
I want to check whether AP sending WME values or not.
6 Replies 6
George Stefanick
Your adapter selection will be driven by what software you select to sniff the traffic.
Both are good.
What software are you looking at ?
Omnipeek, airmagnet, wireshark ??
Omnipeak and wireshark both have
Will it shows WME, 802.11e parameters. 4 Qos Queues?
Stephen Rodriguez
From my own experience, I would go with the 600N and Omnipeek. It will show you the WMM and 802.11e QoS values.
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Which Omnipeak can capture. I have  Linksys WUSB600N ver 1, ver 2 (Dual-band USB adapter)
but I tried on wireshark It doesn;'t show any 802.11 protocoal or beacon frames. Please suggest
I want to capture 802.11 frames using Linksys WUSB600N ver 1, ver 2 (Dual-band USB adapter and Omnipeak
Please guide me how i can do that?
