MSTP L2 VLAN Databse Query !
Vaibhava Varma
Level 4
Level 4
Dear All
Regarding the MSTP configuration is it mandatory to create all the L2 VLANs in the VLAN Database for which we creating instance-to-vlan mapping.
In a bigger network with lots of switches why do we need to create
those L2 VLANS on a Switch for which its not catering any traffic.
Please help to confirm the same.
Varma
Peter Paluch
Hello Varma,
No, creating the VLANs is not required at all. What is required is to have the VLANs mapped into individual instances, and have the mapping (along with the MST region name and revision number) identical throughout the MST region.
Mapping an VLAN into an MST instance and creating that VLAN are two independent things. You can map non-existent VLANs into MST instances beforehand, and create them later (or never create them, according to your needs).
There is a different issue not related to MSTP at all - if a switch is a transit switch for a VLAN, then this VLAN must be created on this switch if even if there are no access ports configured for that VLAN. A switch will not accept frames in VLANs (on trunks) that are not created on the switch itself.
Best regards,
Peter
Peter Paluch
Hello Varma,
Best regards,
Peter
Hi Peter
Thanks a lot for the quick response and clarifications. Thus helps in my current network scenario.
Varma
Varma,
You're very much welcome.
Best regards,
Peter
Hi Varma,
just to add to my Master(Peter)'s comments. the default MST instance 0 has all the vlans mapped to it. Does it mean that we create all the vlans in the database and on every transit switch? NO. We only create the ones we using and we create them on the switches transiting those vlans. see below what i mean.
S1(config)# spanning-tree mst configuration
S1(config-mst)# show current
Current MST configuration
Name      []
Revision  0     Instances configured 1
Instance  Vlans mapped
0         1-4094
S1(config-mst)# instance 1 vlan 20,40
S1(config-mst)# show pending
Pending MST configuration
Name      []
Revision  0     Instances configured 2
0         1-19,21-39,41-4094
1         20,40
Kishore
