Does MMoIP to VoIP work?
Answered Question
Jan 27th, 2012
Using a SMTP request and the following TCL script: app_voicemail_offramp.2.0.0.0.tcl I'm able to generate a call.
We have a Cisco 3825 and a Cisco 3925. The first one uses a SIP trunk and the latter uses ISDN. The 3825 obviously uses a VoIP dialpeer. My question is: does MMoIP to VoIP work? Because the configurations in both the Ciscos are the same except for the dialpeers. On the 3825 I cant get a call to be generated.
application
  service offramp flash:app_voicemail_offramp.2.0.0.0.tcl
     param mail-script playSound
dial-peer voice 4002 mmoip
service offramp
incoming called-number ..........
dial-peer voice 1000 pots
description Outgoing ISDN
destination-pattern 0T
port 0/3/0:15
Correct Answer by Paolo Bevilacqua about 5 years 1 month ago
No.
T.37 to SIP trunk is not supported. The reason is that there is no DSP involved to make a fax call.
Overall Rating: 5 (1 ratings)
Correct Answer
Paolo Bevilacqua Fri, 01/27/2012 - 04:54
No.
