AP1131 does not associates to WLC??
Answered Question
Jan 27th, 2012
I just converted one AP to LWAPP (CAPWAP) it worked at the first time. But when I tried to convert the second one it was succesful but it never associated to the WLC. Then tried with a different AP but same model and the same problem.
These are the logs I get:
(Cisco Controller) debug> capwap detail enable
*Jan 27 18:42:03.223: 68:ef:bd:1c:14:22 LWAPP Discovery Request AP Software Version: 0x3003300
*Jan 27 18:42:03.224: 68:ef:bd:1c:14:22 Received a Discover Request from 68:EF:BD:1C:14:22 via IP broadcast address but the source IP address (10.84.2.77) is not in any of the configured subnets. Rejecting the
From AP console:
*Mar  1 00:29:42.706: LWAPP_CLIENT_ERROR: lwapp_name_lookup - Could Not resolve CISCO-LWAPP-CONTROLLER.comercio.fne
Translating "CISCO-LWAPP-CONTROLLER.comercio.fne"...domain server (10.80.1.58)
I am running 6.0.202.0 and it is an AIR-WLC4402-50-K9 and there are still 4 licenses available.
I'd appraciate any comments that would help to fix this out.
Kind regards!
Correct Answer by George Stefanick about 5 years 5 months ago
Rguzman,
So you know if you ONLY have 1 AP manager interface configured on your WLC you will only ever get 48 access points on your controller even if its a 50 controller. You will need to add another AP manager OR configure in LAG.
JUST AN FYI
Overall Rating: 5 (3 ratings)
Stephen Rodriguez Fri, 01/27/2012 - 11:18
  • Purple, 4500 points or more
can you capture the following debugs on the WLC for two boot cycles of the AP?
debug mac-address 68:EF:BD:1C:14:22
debug capwap events enable
debug capwap errors enable
Steve
rguzman.plannet Fri, 01/27/2012 - 13:37
Hi Steve,
These are the debugs but the debug mac-address 68:EF:BD:1C:14:22 was not accepted by the WLC.
Wasn't there an option to attach files? I had to copy/paste in this post.
(Cisco Controller) >debug capwap errors enable
(Cisco Controller) >*Jan 27 21:03:17.593: 00:26:0b:4b:73:40 Echo Response sent to 10.84.4.57:6570
*Jan 27 21:06:47.505: 68:ef:bd:1c:14:22 Join Priority Processing status = 0, Incoming Ap's Priority 0, MaxLrads = 50,joined Aps =46
*Jan 27 21:07:06.494: 68:ef:bd:1c:14:22 Join Priority Processing status = 0, Incoming Ap's Priority 0, MaxLrads = 50,joined Aps =46
*Jan 27 21:07:25.483: 68:ef:bd:1c:14:22 Join Priority Processing status = 0, Incoming Ap's Priority 0, MaxLrads = 50,joined Aps =46
*Jan 27 21:07:44.473: 68:ef:bd:1c:14:22 Join Priority Processing status = 0, Incoming Ap's Priority 0, MaxLrads = 50,joined Aps =46
*Jan 27 21:08:03.462: 68:ef:bd:1c:14:22 Join Priority Processing status = 0, Incoming Ap's Priority 0, MaxLrads = 50,joined Aps =46
*Jan 27 21:08:22.455: 68:ef:bd:1c:14:22 Join Priority Processing status = 0, Incoming Ap's Priority 0, MaxLrads = 50,joined Aps =46
*Jan 27 21:08:41.440: 68:ef:bd:1c:14:22 Join Priority Processing status = 0, Incoming Ap's Priority 0, MaxLrads = 50,joined Aps =46
*Jan 27 21:09:00.430: 68:ef:bd:1c:14:22 Join Priority Processing status = 0, Incoming Ap's Priority 0, MaxLrads = 50,joined Aps =46
*Jan 27 21:09:19.419: 68:ef:bd:1c:14:22 Join Priority Processing status = 0, Incoming Ap's Priority 0, MaxLrads = 50,joined Aps =46
*Jan 27 21:09:38.408: 68:ef:bd:1c:14:22 Join Priority Processing status = 0, Incoming Ap's Priority 0, MaxLrads = 50,joined Aps =46
*Jan 27 21:09:57.398: 68:ef:bd:1c:14:22 Join Priority Processing status = 0, Incoming Ap's Priority 0, MaxLrads = 50,joined Aps =46
*Jan 27 21:10:16.387: 68:ef:bd:1c:14:22 Join Priority Processing status = 0, Incoming Ap's Priority 0, MaxLrads = 50,joined Aps =46
*Jan 27 21:10:35.377: 68:ef:bd:1c:14:22 Join Priority Processing status = 0, Incoming Ap's Priority 0, MaxLrads = 50,joined Aps =46
*Jan 27 21:10:54.366: 68:ef:bd:1c:14:22 Join Priority Processing status = 0, Incoming Ap's Priority 0, MaxLrads = 50,joined Aps =46
*Jan 27 21:11:13.355: 68:ef:bd:1c:14:22 Join Priority Processing status = 0, Incoming Ap's Priority 0, MaxLrads = 50,joined Aps =46
_______________________________________________________________________________________________
(Cisco Controller) >debug capwap events enable
(Cisco Controller) >*Jan 27 18:42:21.905: 00:3a:98:f8:e7:90 Releasing WTP
*Jan 27 21:03:04.489: 00:3a:98:f4:7b:90 Successful transmission of LWAPP Add-Mobile to AP 00:3a:98:f4:7b:90
*Jan 27 21:03:04.489: 00:3a:98:f4:7b:90 Setting ADD_MOBILE ack state for STA c0:f8:da:73:7e:45 (idx 56), seqno 149 action 2
*Jan 27 21:03:04.493: 00:3a:98:f4:7b:90 Configuration Update Response from 10.84.4.83:37889
*Jan 27 21:03:04.743: e8:40:40:cd:8b:70 Successful transmission of LWAPP Add-Mobile to AP e8:40:40:cd:8b:70
*Jan 27 21:03:04.743: e8:40:40:cd:8b:70 Setting ADD_MOBILE ack state for STA 00:27:10:58:82:40 (idx 3), seqno 244 action 1
*Jan 27 21:03:04.745: e8:40:40:cd:8b:70 Configuration Update Response from 10.84.2.111:23844
*Jan 27 21:03:04.771: 00:18:74:d0:32:40 Successful transmission of LWAPP Add-Mobile to AP 00:18:74:d0:32:40
*Jan 27 21:03:04.773: 00:18:74:d0:32:40 Configuration Update Response from 10.84.4.33:61585
*Jan 27 21:03:04.923: e8:40:40:cd:8b:70 Successful transmission of LWAPP Add-Mobile to AP e8:40:40:cd:8b:70
*Jan 27 21:03:04.923: e8:40:40:cd:8b:70 Setting ADD_MOBILE ack state for STA 00:27:10:58:82:40 (idx 4), seqno 245 action 2
*Jan 27 21:03:04.925: e8:40:40:cd:8b:70 Configuration Update Response from 10.84.2.111:23844
*Jan 27 21:03:04.946: 00:18:74:4b:ee:40 Echo Request from 10.84.4.42:61448
*Jan 27 21:03:04.946: 00:18:74:4b:ee:40 Echo Response sent to 10.84.4.42:61448
*Jan 27 21:03:05.000: 00:3a:98:f8:f3:e0 Configuration update request for delete station sent to 10.84.2.11:11243
*Jan 27 21:03:05.001: 00:18:74:d0:30:f0 Successful transmission of LWAPP Add-Mobile to AP 00:18:74:d0:30:f0
*Jan 27 21:03:05.001: 00:18:74:d0:30:f0 Setting ADD_MOBILE ack state for STA 00:26:c6:81:30:7c (idx 58), seqno 7 action 1
*Jan 27 21:03:05.002: 00:3a:98:f8:f3:e0 Configuration Update Response from 10.84.2.11:11243
*Jan 27 21:03:05.003: 00:18:74:d0:30:f0 Configuration Update Response from 10.84.4.38:61581
*Jan 27 21:03:05.015: 00:18:74:d0:32:40 Successful transmission of LWAPP Add-Mobile to AP 00:18:74:d0:32:40
*Jan 27 21:03:05.015: 00:18:74:d0:32:40 Setting ADD_MOBILE ack state for STA 00:24:d6:9c:53:d4 (idx 64), seqno 173 action 2
*Jan 27 21:03:05.017: 00:18:74:d0:32:40 Configuration Update Response from 10.84.4.33:61585
*Jan 27 21:03:05.053: 00:3a:98:f8:e6:70 Configuration update request for delete station sent to 10.84.4.74:11216
*Jan 27 21:03:05.053: 00:18:74:4b:60:40 Successful transmission of LWAPP Add-Mobile to AP 00:18:74:4b:60:40
*Jan 27 21:03:05.053: 00:18:74:4b:60:40 Setting ADD_MOBILE ack state for STA 00:1c:bf:ba:f5:16 (idx 75), seqno 216 action 1
*Jan 27 21:03:05.056: 00:3a:98:f8:e6:70 Configuration Update Response from 10.84.4.74:11216
*Jan 27 21:03:05.056: 00:18:74:4b:60:40 Configuration Update Response from 10.84.4.34:13148
*Jan 27 21:03:05.082: 00:18:74:4b:77:b0 Echo Request from 10.84.16.202:13195
*Jan 27 21:03:05.082: 00:18:74:4b:77:b0 Echo Response sent to 10.84.16.202:13195
*Jan 27 21:03:05.112: 1c:aa:07:22:fb:30 Echo Request from 10.84.2.110:42971
*Jan 27 21:03:05.112: 1c:aa:07:22:fb:30 Echo Response sent to 10.84.2.110:42971
*Jan 27 21:03:05.202: 00:18:74:4b:60:40 Successful transmission of LWAPP Add-Mobile to AP 00:18:74:4b:60:40
*Jan 27 21:03:05.202: 00:18:74:4b:60:40 Setting ADD_MOBILE ack state for STA 00:1c:bf:ba:f5:16 (idx 76), seqno 217 action 2
*Jan 27 21:03:05.204: 00:18:74:4b:60:40 Configuration Update Response from 10.84.4.34:13148
*Jan 27 21:03:05.565: 00:3a:98:d6:e4:80 Echo Request from 10.84.2.10:62171
*Jan 27 21:03:05.565: 00:3a:98:d6:e4:80 Echo Response sent to 10.84.2.10:62171
*Jan 27 21:03:05.675: 00:3a:98:f8:f3:e0 Successful transmission of LWAPP Add-Mobile to AP 00:3a:98:f8:f3:e0
*Jan 27 21:03:05.677: 00:3a:98:f8:f3:e0 Configuration Update Response from 10.84.2.11:11243
*Jan 27 21:03:05.935: 00:1f:9e:80:72:b0 WTP Event Request from 10.84.4.55:22431
*Jan 27 21:03:05.935: 00:1f:9e:80:72:b0 WTP Event Response sent to 10.84.4.55:22431
*Jan 27 21:03:06.002: 00:3a:98:f4:77:80 Configuration update request for delete station sent to 10.84.4.77:37881
*Jan 27 21:03:06.002: 00:18:74:4a:a6:80 Successful transmission of LWAPP Add-Mobile to AP 00:18:74:4a:a6:80
*Jan 27 21:03:06.002: 00:18:74:4a:a6:80 Setting ADD_MOBILE ack state for STA 08:11:96:5d:cc:dc (idx 38), seqno 107 action 1
*Jan 27 21:03:06.002: 00:18:74:d0:40:b0 Echo Request from 10.84.4.44:61613
*Jan 27 21:03:06.003: 00:18:74:d0:40:b0 Echo Response sent to 10.84.4.44:61613
*Jan 27 21:03:06.003: 00:3a:98:f4:77:80 Configuration Update Response from 10.84.4.77:37881
*Jan 27 21:03:06.004: 00:18:74:4a:a6:80 Configuration Update Response from 10.84.4.52:12775
*Jan 27 21:03:06.166: 00:3a:98:f8:e0:b0 Echo Request from 10.84.4.89:11205
*Jan 27 21:03:06.166: 00:3a:98:f8:e0:b0 Echo Response sent to 10.84.4.89:11205
*Jan 27 21:03:06.211: 00:3a:98:f8:e6:20 Successful transmission of LWAPP Add-Mobile to AP 00:3a:98:f8:e6:20
*Jan 27 21:03:06.211: 00:3a:98:f8:e6:20 Setting ADD_MOBILE ack state for STA 00:26:c7:83:99:a6 (idx 69), seqno 94 action 2
*Jan 27 21:03:06.214: 00:3a:98:f8:e6:20 Configuration Update Response from 10.84.4.75:11215
*Jan 27 21:03:06.220: 00:3a:98:f8:e6:20 Successful transmission of LWAPP Add-Mobile to AP 00:3a:98:f8:e6:20
*Jan 27 21:03:06.220: 00:3a:98:f8:e6:20 Setting ADD_MOBILE ack state for STA 00:26:c6:86:78:6e (idx 70), seqno 95 action 2
*Jan 27 21:03:06.243: 00:3a:98:f8:e6:20 Configuration Update Response from 10.84.4.75:11215
*Jan 27 21:03:06.414: 00:3a:98:f8:e6:20 Successful transmission of LWAPP Add-Mobile to AP 00:3a:98:f8:e6:20
*Jan 27 21:03:06.414: 00:3a:98:f8:e6:20 Setting ADD_MOBILE ack state for STA a0:88:b4:c8:06:ec (idx 71), seqno 96 action 2
*Jan 27 21:03:06.417: 00:3a:98:f8:e6:20 Configuration Update Response from 10.84.4.75:11215
*Jan 27 21:03:06.524: 1c:aa:07:42:f6:30 WTP Event Request from 10.84.2.112:57954
*Jan 27 21:03:06.525: 1c:aa:07:42:f6:30 WTP Event Response sent to 10.84.2.112:57954
*Jan 27 21:03:06.629: 00:3a:98:f8:e6:20 Successful transmission of LWAPP Add-Mobile to AP 00:3a:98:f8:e6:20
*Jan 27 21:03:06.629: 00:3a:98:f8:e6:20 Setting ADD_MOBILE ack state for STA a0:88:b4:3f:ba:50 (idx 72), seqno 97 action 2
*Jan 27 21:03:06.632: 00:3a:98:f8:e6:20 Configuration Update Response from 10.84.4.75:11215
*Jan 27 21:03:06.658: 00:3a:98:f8:e7:90 WTP Event Request from 10.84.4.79:11218
*Jan 27 21:03:06.658: 00:3a:98:f8:e7:90 WTP Event Response sent to 10.84.4.79:11218
*Jan 27 21:03:06.839: 00:3a:98:f8:e6:20 Successful transmission of LWAPP Add-Mobile to AP 00:3a:98:f8:e6:20
*Jan 27 21:03:06.839: 00:3a:98:f8:e6:20 Setting ADD_MOBILE ack state for STA 00:1c:bf:83:3b:c2 (idx 73), seqno 98 action 2
*Jan 27 21:03:06.842: 00:3a:98:f8:e6:20 Configuration Update Response from 10.84.4.75:11215
*Jan 27 21:03:06.877: 00:3a:98:f8:e6:20 Successful transmission of LWAPP Add-Mobile to AP 00:3a:98:f8:e6:20
*Jan 27 21:03:06.877: 00:3a:98:f8:e6:20 Setting ADD_MOBILE ack state for STA 00:1c:bf:a3:84:da (idx 74), seqno 99 action 2
*Jan 27 21:03:06.881: 00:3a:98:f8:e6:20 Configuration Update Response from 10.84.4.75:11215
*Jan 27 21:03:06.994: 00:3a:98:f8:e6:20 Successful transmission of LWAPP Add-Mobile to AP 00:3a:98:f8:e6:20
*Jan 27 21:03:06.994: 00:3a:98:f8:e6:20 Setting ADD_MOBILE ack state for STA 00:1f:3c:24:8e:46 (idx 75), seqno 100 action 2
*Jan 27 21:03:06.997: 00:3a:98:f8:e6:20 Configuration Update Response from 10.84.4.75:11215
*Jan 27 21:03:07.036: 00:18:74:4b:ee:40 WTP Event Request from 10.84.4.42:61448
*Jan 27 21:03:07.036: 00:18:74:4b:ee:40 WTP Event Response sent to 10.84.4.42:61448
*Jan 27 21:03:07.063: 00:3a:98:f8:e6:70 Echo Request from 10.84.4.74:11216
*Jan 27 21:03:07.064: 00:3a:98:f8:e6:70 Echo Response sent to 10.84.4.74:11216
*Jan 27 21:03:07.406: 00:3a:98:f8:e6:20 Successful transmission of LWAPP Add-Mobile to AP 00:3a:98:f8:e6:20
*Jan 27 21:03:07.406: 00:3a:98:f8:e6:20 Setting ADD_MOBILE ack state for STA 24:77:03:28:42:58 (idx 76), seqno 101 action 2
*Jan 27 21:03:07.409: 00:3a:98:f8:e6:20 Configuration Update Response from 10.84.4.75:11215
*Jan 27 21:03:07.457: 1c:aa:07:42:f6:30 Configuration update request for delete station sent to 10.84.2.112:57954
*Jan 27 21:03:07.459: 1c:aa:07:42:f6:30 Configuration Update Response from 10.84.2.112:57954
*Jan 27 21:03:07.637: 00:3a:98:f8:e6:20 Successful transmission of LWAPP Add-Mobile to AP 00:3a:98:f8:e6:20
*Jan 27 21:03:07.637: 00:3a:98:f8:e6:20 Setting ADD_MOBILE ack state for STA 00:21:5c:27:1e:21 (idx 77), seqno 102 action 2
*Jan 27 21:03:07.640: 00:3a:98:f8:e6:20 Configuration Update Response from 10.84.4.75:11215
*Jan 27 21:03:07.853: 00:3a:98:f8:e6:20 Successful transmission of LWAPP Add-Mobile to AP 00:3a:98:f8:e6:20
*Jan 27 21:03:07.853: 00:3a:98:f8:e6:20 Setting ADD_MOBILE ack state for STA 00:1e:65:22:12:e8 (idx 78), seqno 103 action 2
*Jan 27 21:03:07.856: 00:3a:98:f8:e6:20 Configuration Update Response from 10.84.4.75:11215
*Jan 27 21:03:08.257: 00:18:74:4b:60:40 Configuration update request for delete station sent to 10.84.4.34:13148
*Jan 27 21:03:08.259: 00:18:74:4b:60:40 Configuration Update Response from 10.84.4.34:13148
*Jan 27 21:03:08.309: 00:18:74:d0:43:d0 WTP Event Request from 10.84.4.37:61619
*Jan 27 21:03:08.309: 00:18:74:d0:43:d0 WTP Event Response sent to 10.84.4.37:61619
*Jan 27 21:03:08.311: 00:18:74:d0:43:d0 WTP Event Request from 10.84.4.37:61619
*Jan 27 21:03:08.311: 00:18:74:d0:43:d0 WTP Event Response sent to 10.84.4.37:61619
*Jan 27 21:03:08.359: 00:3a:98:f8:e6:70 Successful transmission of LWAPP Add-Mobile to AP 00:3a:98:f8:e6:70
*Jan 27 21:03:08.360: 00:3a:98:f8:e6:70 Setting ADD_MOBILE ack state for STA 00:1f:3c:9d:c2:2f (idx 59), seqno 188 action 2
*Jan 27 21:03:08.362: 00:3a:98:f8:e6:70 Configuration Update Response from 10.84.4.74:11216
*Jan 27 21:03:08.471: 00:3a:98:f8:e6:20 Successful transmission of LWAPP Add-Mobile to AP 00:3a:98:f8:e6:20
*Jan 27 21:03:08.471: 00:3a:98:f8:e6:20 Setting ADD_MOBILE ack state for STA 00:26:c6:77:b5:b2 (idx 79), seqno 104 action 2
d*Jan 27 21:03:08.474: 00:3a:98:f8:e6:20 Configuration Update Response from 10.84.4.75:11215
*Jan 27 21:03:08.626: 00:18:74:d0:30:f0 WTP Event Request from 10.84.4.38:61581
*Jan 27 21:03:08.627: 00:18:74:d0:30:f0 WTP Event Response sent to 10.84.4.38:61581
*Jan 27 21:03:08.629: 00:18:74:d0:30:f0 WTP Event Request from 10.84.4.38:61581
ebu*Jan 27 21:03:08.629: 00:18:74:d0:30:f0 WTP Event Response sent to 10.84.4.38:61581
*Jan 27 21:03:08.975: 00:3a:98:f8:e6:70 Successful transmission of LWAPP Add-Mobile to AP 00:3a:98:f8:e6:70
*Jan 27 21:03:08.975: 00:3a:98:f8:e6:70 Setting ADD_MOBILE ack state for STA 00:22:fb:1a:7d:c4 (idx 60), seqno 189 action 2
*Jan 27 21:03:08.978: 00:3a:98:f8:e6:70 Configuration Update Response from 10.84.4.74:11216
*Jan 27 21:03:09.194: 00:18:74:4b:ee:00 Successful transmission of LWAPP Add-Mobile to AP 00:18:74:4b:ee:00
*Jan 27 21:03:09.194: 00:18:74:4b:ee:00 Setting ADD_MOBILE ack state for STA 00:23:14:54:56:80 (idx 98), seqno 55 action 2
*Jan 27 21:03:09.196: 00:18:74:4b:ee:00 Configuration Update Response from 10.84.6.207:61448
*Jan 27 21:03:09.262: 00:18:74:d0:32:40 Echo Request from 10.84.4.33:61585
g *Jan 27 21:03:09.262: 00:18:74:d0:32:40 Echo Response sent to 10.84.4.33:61585
*Jan 27 21:03:09.387: 00:18:74:d0:43:d0 Primary Discovery Request from 10.84.4.37:61619
*Jan 27 21:03:09.388: 00:18:74:d0:43:d0 Primary Discovery Response sent to  10.84.4.37:61619
*Jan 27 21:03:09.388: 00:18:74:d0:43:d0 Received LWAPP PRIMARY_DISCOVERY_REQ from AP
*Jan 27 21:03:09.388: 00:19:06:cf:0b:20 Successful transmission of LWAPP Primary Discovery Response to AP 00:19:06:cf:0b:20
*Jan 27 21:03:09.431: 00:3a:98:f4:7a:10 Configuration update request for delete station sent to 10.84.5.95:37884
*Jan 27 21:03:09.431: 00:18:74:4b:ee:40 Successful transmission of LWAPP Add-Mobile to AP 00:18:74:4b:ee:40
*Jan 27 21:03:09.431: 00:18:74:4b:ee:40 Setting ADD_MOBILE ack state for STA 00:1f:3c:27:e5:3a (idx 22), seqno 87 action 1
*Jan 27 21:03:09.432: 00:3a:98:f4:7a:10 Configuration Update Response from 10.84.5.95:37884
*Jan 27 21:03:09.433: 00:18:74:4b:ee:40 Configuration Update Response from 10.84.4.42:61448
*Jan 27 21:03:09.457: 1c:aa:07:22:fb:30 Configuration update request for delete station sent to 10.84.2.110:42971
*Jan 27 21:03:09.459: 1c:aa:07:22:fb:30 Configuration Update Response from 10.84.2.110:42971
*Jan 27 21:03:09.714: 1c:aa:07:22:fb:30 Successful transmission of LWAPP Add-Mobile to AP 1c:aa:07:22:fb:30
*Jan 27 21:03:09.716: 1c:aa:07:22:fb:30 Configuration Update Response from 10.84.2.110:42971
*Jan 27 21:03:10.040: 00:26:0b:4b:73:40 WTP Event Request from 10.84.4.57:6570
*Jan 27 21:03:10.040: 00:26:0b:4b:73:40 WTP Event Response sent to 10.84.4.57:6570
*Jan 27 21:03:10.263: 00:3a:98:f4:79:e0 Echo Request from 10.84.4.92:37885
*Jan 27 21:03:10.264: 00:3a:98:f4:79:e0 Echo Response sent to 10.84.4.92:37885
*Jan 27 21:03:10.489: 00:3a:98:f8:e6:20 Successful transmission of LWAPP Add-Mobile to AP 00:3a:98:f8:e6:20
*Jan 27 21:03:10.489: 00:3a:98:f8:e6:20 Setting ADD_MOBILE ack state for STA 00:1f:3b:39:22:23 (idx 80), seqno 105 action 2
*Jan 27 21:03:10.492: 00:3a:98:f8:e6:20 Configuration Update Response from 10.84.4.75:11215
*Jan 27 21:03:10.796: 00:3a:98:f8:e8:80 WTP Event Request from 10.84.4.91:11221
*Jan 27 21:03:10.796: 00:3a:98:f8:e8:80 WTP Event Response sent to 10.84.4.91:11221
*Jan 27 21:03:11.072: 00:3a:98:d6:e4:80 Successful transmission of LWAPP Add-Mobile to AP 00:3a:98:d6:e4:80
*Jan 27 21:03:11.072: 00:3a:98:d6:e4:80 Setting ADD_MOBILE ack state for STA 00:1f:3c:9d:c7:2c (idx 32), seqno 201 action 2
*Jan 27 21:03:11.075: 00:3a:98:d6:e4:80 Configuration Update Response from 10.84.2.10:62171
*Jan 27 21:03:11.269: e8:40:40:cd:8b:70 Echo Request from 10.84.2.111:23844
*Jan 27 21:03:11.269: e8:40:40:cd:8b:70 Echo Response sent to 10.84.2.111:23844
*Jan 27 21:03:11.438: 00:21:a0:f9:f1:80 Echo Request from 10.84.4.64:31412
*Jan 27 21:03:11.439: 00:21:a0:f9:f1:80 Echo Response sent to 10.84.4.64:31412
de*Jan 27 21:03:11.899: 00:18:74:d0:43:d0 Echo Request from 10.84.4.37:61619
*Jan 27 21:03:11.899: 00:18:74:d0:43:d0 Echo Response sent to 10.84.4.37:61619
u*Jan 27 21:03:12.210: 00:18:74:4b:60:40 Successful transmission of LWAPP Add-Mobile to AP 00:18:74:4b:60:40
*Jan 27 21:03:12.210: 00:18:74:4b:60:40 Setting ADD_MOBILE ack state for STA 18:3d:a2:7e:de:c8 (idx 78), seqno 219 action 2
*Jan 27 21:03:12.213: 00:18:74:4b:60:40 Configuration Update Response from 10.84.4.34:13148
*Jan 27 21:03:12.454: 00:3a:98:f8:e6:20 Successful transmission of LWAPP Add-Mobile to AP 00:3a:98:f8:e6:20
*Jan 27 21:03:12.454: 00:3a:98:f8:e6:20 Setting ADD_MOBILE ack state for STA 00:21:5c:27:1e:19 (idx 81), seqno 106 action 2
*Jan 27 21:03:12.457: 00:3a:98:f8:e6:20 Configuration Update Response from 10.84.4.75:11215
*Jan 27 21:03:12.583: 00:3a:98:f4:77:a0 Successful transmission of LWAPP Add-Mobile to AP 00:3a:98:f4:77:a0
*Jan 27 21:03:12.586: 00:3a:98:f4:77:a0 Configuration Update Response from 10.84.4.88:37881
*Jan 27 21:03:12.744: 00:3a:98:f8:f3:e0 Echo Request from 10.84.2.11:11243
*Jan 27 21:03:12.744: 00:3a:98:f8:f3:e0 Echo Response sent to 10.84.2.11:11243
*Jan 27 21:03:12.856: 00:3a:98:f8:e6:20 Configuration update request for delete station sent to 10.84.4.75:11215
*Jan 27 21:03:12.857: 00:18:74:4b:60:40 Successful transmission of LWAPP Add-Mobile to AP 00:18:74:4b:60:40
*Jan 27 21:03:12.857: 00:18:74:4b:60:40 Setting ADD_MOBILE ack state for STA 58:94:6b:8e:bd:38 (idx 79), seqno 220 action 1
*Jan 27 21:03:12.858: 00:3a:98:f8:e6:20 Configuration Update Response from 10.84.4.75:11215
*Jan 27 21:03:12.859: 00:18:74:4b:60:40 Configuration Update Response from 10.84.4.34:13148
*Jan 27 21:03:13.069: 00:3a:98:f8:e6:20 Echo Request from 10.84.4.75:11215
*Jan 27 21:03:13.069: 00:3a:98:f8:e6:20 Echo Response sent to 10.84.4.75:11215
*Jan 27 21:03:13.128: 00:3a:98:f4:77:60 Echo Request from 10.84.4.73:37880
deug*Jan 27 21:03:13.128: 00:3a:98:f4:77:60 Echo Response sent to 10.84.4.73:37880
*Jan 27 21:03:14.009: 00:18:74:4b:60:40 Successful transmission of LWAPP Add-Mobile to AP 00:18:74:4b:60:40
*Jan 27 21:03:14.011: 00:18:74:4b:60:40 Configuration Update Response from 10.84.4.34:13148
*Jan 27 21:03:14.235: 00:3a:98:f8:ea:80 Echo Request from 10.84.4.78:11224
*Jan 27 21:03:14.235: 00:3a:98:f8:ea:80 Echo Response sent to 10.84.4.78:11224
*Jan 27 21:03:14.546: 00:18:74:4b:d5:80 Echo Request from 10.84.4.35:13382
*Jan 27 21:03:14.546: 00:18:74:4b:d5:80 Echo Response sent to 10.84.4.35:13382
*Jan 27 21:03:15.432: 00:18:74:4b:e4:c0 Echo Request from 10.84.4.82:61430
*Jan 27 21:03:15.433: 00:18:74:4b:e4:c0 Echo Response sent to 10.84.4.82:61430
*Jan 27 21:03:15.599: 00:3a:98:f8:e6:f0 WTP Event Request from 10.84.4.76:11217
*Jan 27 21:03:15.599: 00:3a:98:f8:e6:f0 WTP Event Response sent to 10.84.4.76:11217
*Jan 27 21:03:15.673: 00:3a:98:f8:e6:f0 WTP Event Request from 10.84.4.76:11217
*Jan 27 21:03:15.674: 00:3a:98:f8:e6:f0 WTP Event Response sent to 10.84.4.76:11217
*Jan 27 21:03:15.675: 00:3a:98:f8:e6:f0 WTP Event Request from 10.84.4.76:11217
*Jan 27 21:03:15.675: 00:3a:98:f8:e6:f0 WTP Event Response sent to 10.84.4.76:11217
*Jan 27 21:03:15.677: 00:3a:98:f8:e6:f0 WTP Event Request from 10.84.4.76:11217
*Jan 27 21:03:15.677: 00:3a:98:f8:e6:f0 WTP Event Response sent to 10.84.4.76:11217
*Jan 27 21:03:15.721: 00:3a:98:f4:77:80 WTP Event Request from 10.84.4.77:37881
*Jan 27 21:03:15.722: 00:3a:98:f4:77:80 WTP Event Response sent to 10.84.4.77:37881
*Jan 27 21:03:15.741: 00:18:74:4a:a6:80 WTP Event Request from 10.84.4.52:12775
*Jan 27 21:03:15.741: 00:18:74:4a:a6:80 WTP Event Response sent to 10.84.4.52:12775
*Jan 27 21:03:15.743: 00:18:74:4a:a6:80 WTP Event Request from 10.84.4.52:12775
d*Jan 27 21:03:15.744: 00:18:74:4a:a6:80 WTP Event Response sent to 10.84.4.52:12775
*Jan 27 21:03:15.780: 00:3a:98:f4:77:80 WTP Event Request from 10.84.4.77:37881
*Jan 27 21:03:15.781: 00:3a:98:f4:77:80 WTP Event Response sent to 10.84.4.77:37881
*Jan 27 21:03:15.782: 00:3a:98:f4:77:80 WTP Event Request from 10.84.4.77:37881
*Jan 27 21:03:15.782: 00:3a:98:f4:77:80 WTP Event Response sent to 10.84.4.77:37881
*Jan 27 21:03:15.784: 00:3a:98:f8:f3:e0 Successful transmission of LWAPP Add-Mobile to AP 00:3a:98:f8:f3:e0
*Jan 27 21:03:15.784: 00:3a:98:f4:77:80 WTP Event Request from 10.84.4.77:37881
*Jan 27 21:03:15.785: 00:3a:98:f4:77:80 WTP Event Response sent to 10.84.4.77:37881
*Jan 27 21:03:15.787: 00:3a:98:f4:77:80 WTP Event Request from 10.84.4.77:37881
*Jan 27 21:03:15.787: 00:3a:98:f4:77:80 WTP Event Response sent to 10.84.4.77:37881
e*Jan 27 21:03:15.788: 00:3a:98:f8:f3:e0 Configuration Update Response from 10.84.2.11:11243
*Jan 27 21:03:15.938: 00:18:74:4a:a6:80 Primary Discovery Request from 10.84.4.52:12775
*Jan 27 21:03:15.938: 00:18:74:4a:a6:80 Primary Discovery Response sent to  10.84.4.52:12775
*Jan 27 21:03:15.938: 00:18:74:4a:a6:80 Received LWAPP PRIMARY_DISCOVERY_REQ from AP
bug di*Jan 27 21:03:15.938: 00:19:06:73:1e:6c Successful transmission of LWAPP Primary Discovery Response to AP 00:19:06:73:1e:6c
*Jan 27 21:03:17.180: 00:26:0b:15:d4:60 WTP Event Request from 10.84.4.81:62863
*Jan 27 21:03:17.181: 00:26:0b:15:d4:60 WTP Event Response sent to 10.84.4.81:62863
*Jan 27 21:03:17.183: 00:26:0b:15:d4:60 WTP Event Request from 10.84.4.81:62863
*Jan 27 21:03:17.183: 00:26:0b:15:d4:60 WTP Event Response sent to 10.84.4.81:62863
*Jan 27 21:03:17.187: 00:26:0b:15:d4:60 WTP Event Request from 10.84.4.81:62863
*Jan 27 21:03:17.187: 00:26:0b:15:d4:60 WTP Event Response sent to 10.84.4.81:62863
*Jan 27 21:03:17.190: 00:26:0b:15:d4:60 WTP Event Request from 10.84.4.81:62863
*Jan 27 21:03:17.190: 00:26:0b:15:d4:60 WTP Event Response sent to 10.84.4.81:62863
*Jan 27 21:03:17.193: 00:26:0b:15:d4:60 WTP Event Request from 10.84.4.81:62863
*Jan 27 21:03:17.193: 00:26:0b:15:d4:60 WTP Event Response sent to 10.84.4.81:62863
*Jan 27 21:03:17.196: 00:26:0b:15:d4:60 WTP Event Request from 10.84.4.81:62863
sable-all *Jan 27 21:03:17.196: 00:26:0b:15:d4:60 WTP Event Response sent to 10.84.4.81:62863
*Jan 27 21:03:17.450: 00:3a:98:f8:e4:e0 WTP Event Request from 10.84.4.94:11213
*Jan 27 21:03:17.451: 00:3a:98:f8:e4:e0 WTP Event Response sent to 10.84.4.94:11213
*Jan 27 21:03:17.453: 00:3a:98:f8:e4:e0 WTP Event Request from 10.84.4.94:11213
*Jan 27 21:03:17.453: 00:3a:98:f8:e4:e0 WTP Event Response sent to 10.84.4.94:11213
*Jan 27 21:03:17.593: 00:26:0b:4b:73:40 Echo Request from 10.84.4.57:6570
George Stefanick Fri, 01/27/2012 - 13:56
  • Community Spotlight Award,
    Best Publication, October 2015
Are you using LAG or is your controller configured as ports, just curious ...
Stephen Rodriguez Fri, 01/27/2012 - 14:01
Apologize, that should have been:
debug mac address 68:EF:BD:1C:14:22
The debugs should be run concurrently.  The first limits the output to just the stuff pertaining to the mac you specifiy.
Steve
rguzman.plannet Fri, 01/27/2012 - 14:13
debug mac address, either case it didnt work
here is what I just caputered again.
(Cisco Controller) >debug mac address 68:ef:bd:1c:14:22
Incorrect usage.  Use the '?' or key to list commands.
(Cisco Controller) >*Jan 27 22:08:03.776: 00:18:74:4b:ee:40 Echo Response sent to 10.84.4.42:61448
*Jan 27 22:09:41.285: 00:3a:98:f4:77:a0 WTP Event Request from 10.84.4.88:37881
*Jan 27 22:09:41.285: 00:3a:98:f4:77:a0 WTP Event Response sent to 10.84.4.88:37881
*Jan 27 22:09:41.318: 00:3a:98:f8:ea:80 Configuration update request for RRM Neighbour Ctrl List sent to 10:84:4:78
*Jan 27 22:09:41.320: 00:3a:98:f8:ea:80 Configuration Update Response from 10.84.4.78:11224
*Jan 27 22:09:41.355: e8:40:40:cd:8b:70 Echo Request from 10.84.2.111:23844
*Jan 27 22:09:41.355: e8:40:40:cd:8b:70 Echo Response sent to 10.84.2.111:23844
*Jan 27 22:09:41.370: 00:18:74:4b:ee:00 Successful transmission of LWAPP Add-Mobile to AP 00:18:74:4b:ee:00
*Jan 27 22:09:41.370: 00:18:74:4b:ee:00 Setting ADD_MOBILE ack state for STA 00:27:10:c4:99:90 (idx 59), seqno 60 action 2
*Jan 27 22:09:41.373: 00:18:74:4b:ee:00 Configuration Update Response from 10.84.6.207:61448
*Jan 27 22:09:41.648: 00:3a:98:f8:f3:e0 Echo Request from 10.84.2.11:11243
*Jan 27 22:09:41.649: 00:3a:98:f8:f3:e0 Echo Response sent to 10.84.2.11:11243
*Jan 27 22:09:41.916: 00:3a:98:f8:e6:20 Echo Request from 10.84.4.75:11215
*Jan 27 22:09:41.917: 00:3a:98:f8:e6:20 Echo Response sent to 10.84.4.75:11215
*Jan 27 22:09:41.960: 00:3a:98:f8:e5:50 WTP Event Request from 10.84.4.85:11215
*Jan 27 22:09:41.960: 00:3a:98:f8:e5:50 WTP Event Response sent to 10.84.4.85:11215
*Jan 27 22:09:42.064: 00:18:74:4b:cc:10 WTP Event Request from 10.84.4.41:13363
*Jan 27 22:09:42.064: 00:18:74:4b:cc:10 WTP Event Response sent to 10.84.4.41:13363
*Jan 27 22:09:42.150: 1c:aa:07:42:f6:30 Successful transmission of LWAPP Add-Mobile to AP 1c:aa:07:42:f6:30
*Jan 27 22:09:42.150: 1c:aa:07:42:f6:30 Setting ADD_MOBILE ack state for STA 00:1c:bf:bc:d6:3c (idx 3), seqno 96 action 2
*Jan 27 22:09:42.153: 1c:aa:07:42:f6:30 Configuration Update Response from 10.84.2.112:57954
*Jan 27 22:09:42.214: 00:3a:98:f4:77:60 Echo Request from 10.84.4.73:37880
*Jan 27 22:09:42.215: 00:3a:98:f4:77:60 Echo Response sent to 10.84.4.73:37880
*Jan 27 22:09:42.271: 00:18:74:4b:60:40 WTP Event Request from 10.84.4.34:13148
d*Jan 27 22:09:42.271: 00:18:74:4b:60:40 WTP Event Response sent to 10.84.4.34:13148
*Jan 27 22:09:42.406: 00:1f:9e:41:b9:80 WTP Event Request from 10.84.4.56:57785
eb*Jan 27 22:09:42.406: 00:1f:9e:41:b9:80 WTP Event Response sent to 10.84.4.56:57785
*Jan 27 22:09:42.646: 00:3a:98:f4:77:80 Primary Discovery Request from 10.84.4.77:37881
*Jan 27 22:09:42.647: 00:3a:98:f4:77:80 Primary Discovery Response sent to  10.84.4.77:37881
*Jan 27 22:09:42.647: 00:3a:98:f4:77:80 Received LWAPP PRIMARY_DISCOVERY_REQ from AP
ug *Jan 27 22:09:42.647: d0:d0:fd:a9:3f:7e Successful transmission of LWAPP Primary Discovery Response to AP d0:d0:fd:a9:3f:7e
*Jan 27 22:09:42.886: 00:12:44:b2:31:00 WTP Event Request from 10.84.4.32:55403
*Jan 27 22:09:42.886: 00:12:44:b2:31:00 WTP Event Response sent to 10.84.4.32:55403
*Jan 27 22:09:42.981: 00:18:74:4b:cc:10 Configuration update request for delete station sent to 10.84.4.41:13363
*Jan 27 22:09:42.983: 00:18:74:4b:cc:10 Configuration Update Response from 10.84.4.41:13363
*Jan 27 22:09:43.121: 00:3a:98:f8:ea:80 Echo Request from 10.84.4.78:11224
*Jan 27 22:09:43.121: 00:3a:98:f8:ea:80 Echo Response sent to 10.84.4.78:11224
*Jan 27 22:09:43.238: 00:18:74:d0:40:b0 WTP Event Request from 10.84.4.44:61613
*Jan 27 22:09:43.238: 00:18:74:d0:40:b0 WTP Event Response sent to 10.84.4.44:61613
*Jan 27 22:09:43.240: 00:18:74:d0:40:b0 WTP Event Request from 10.84.4.44:61613
*Jan 27 22:09:43.240: 00:18:74:d0:40:b0 WTP Event Response sent to 10.84.4.44:61613
*Jan 27 22:09:43.241: 00:18:74:d0:40:b0 WTP Event Request from 10.84.4.44:61613
*Jan 27 22:09:43.242: 00:18:74:d0:40:b0 WTP Event Response sent to 10.84.4.44:61613
*Jan 27 22:09:43.243: 00:18:74:d0:40:b0 WTP Event Request from 10.84.4.44:61613
*Jan 27 22:09:43.243: 00:18:74:d0:40:b0 WTP Event Response sent to 10.84.4.44:61613
*Jan 27 22:09:43.244: 00:18:74:d0:40:b0 WTP Event Request from 10.84.4.44:61613
*Jan 27 22:09:43.245: 00:18:74:d0:40:b0 WTP Event Response sent to 10.84.4.44:61613
*Jan 27 22:09:43.345: 00:18:74:4b:d5:80 Echo Request from 10.84.4.35:13382
cap*Jan 27 22:09:43.346: 00:18:74:4b:d5:80 Echo Response sent to 10.84.4.35:13382
*Jan 27 22:09:44.138: 00:18:74:4b:e4:c0 Echo Request from 10.84.4.82:61430
wap *Jan 27 22:09:44.138: 00:18:74:4b:e4:c0 Echo Response sent to 10.84.4.82:61430
*Jan 27 22:09:44.451: 00:18:74:4b:ee:00 Successful transmission of LWAPP Add-Mobile to AP 00:18:74:4b:ee:00
*Jan 27 22:09:44.454: 00:18:74:4b:ee:00 Configuration Update Response from 10.84.6.207:61448
*Jan 27 22:09:44.581: 00:18:74:4b:60:40 Configuration update request for RRM Neighbour Ctrl List sent to 10:84:4:34
*Jan 27 22:09:44.583: 00:18:74:4b:60:40 Configuration Update Response from 10.84.4.34:13148
*Jan 27 22:09:44.748: 00:21:a0:f9:f1:80 Successful transmission of LWAPP Add-Mobile to AP 00:21:a0:f9:f1:80
*Jan 27 22:09:44.748: 00:21:a0:f9:f1:80 Setting ADD_MOBILE ack state for STA 08:11:96:32:bb:80 (idx 98), seqno 103 action 1
*Jan 27 22:09:44.749: 00:21:a0:f9:f1:80 Configuration Update Response from 10.84.4.64:31412
*Jan 27 22:09:44.920: 00:21:a0:f9:f1:80 Successful transmission of LWAPP Add-Mobile to AP 00:21:a0:f9:f1:80
*Jan 27 22:09:44.920: 00:21:a0:f9:f1:80 Setting ADD_MOBILE ack state for STA 08:11:96:32:bb:80 (idx 99), seqno 104 action 2
*Jan 27 22:09:44.922: 00:21:a0:f9:f1:80 Configuration Update Response from 10.84.4.64:31412
*Jan 27 22:09:46.339: 00:26:0b:4b:73:40 Echo Request from 10.84.4.57:6570
*Jan 27 22:09:46.340: 00:26:0b:4b:73:40 Echo Response sent to 10.84.4.57:6570
*Jan 27 22:09:46.374: 68:ef:bd:1c:14:22 Received LWAPP DISCOVERY REQUEST to ff:ff:ff:ff:ff:ff on port '1'
er*Jan 27 22:09:46.777: 00:3a:98:f8:e8:80 Echo Request from 10.84.4.91:11221
*Jan 27 22:09:46.777: 00:3a:98:f8:e8:80 Echo Response sent to 10.84.4.91:11221
rors *Jan 27 22:09:47.488: 00:3a:98:f8:e5:50 Configuration update request for delete station sent to 10.84.4.85:11215
*Jan 27 22:09:47.488: 00:18:74:4b:79:40 Successful transmission of LWAPP Add-Mobile to AP 00:18:74:4b:79:40
*Jan 27 22:09:47.488: 00:18:74:4b:79:40 Setting ADD_MOBILE ack state for STA a0:88:b4:c8:d6:d8 (idx 32), seqno 105 action 1
*Jan 27 22:09:47.491: 00:3a:98:f8:e5:50 Configuration Update Response from 10.84.4.85:11215
*Jan 27 22:09:47.491: 00:18:74:4b:79:40 Configuration Update Response from 10.84.4.46:13197
*Jan 27 22:09:47.573: 00:1f:9e:41:b9:80 Echo Request from 10.84.4.56:57785
*Jan 27 22:09:47.573: 00:1f:9e:41:b9:80 Echo Response sent to 10.84.4.56:57785
*Jan 27 22:09:47.599: 00:3a:98:f8:e7:90 Echo Request from 10.84.4.79:11218
*Jan 27 22:09:47.599: 00:3a:98:f8:e7:90 Echo Response sent to 10.84.4.79:11218
*Jan 27 22:09:47.630: 00:12:44:b2:31:00 Echo Request from 10.84.4.32:55403
*Jan 27 22:09:47.631: 00:12:44:b2:31:00 Echo Response sent to 10.84.4.32:55403
*Jan 27 22:09:47.631: 00:18:74:4b:79:40 Successful transmission of LWAPP Add-Mobile to AP 00:18:74:4b:79:40
*Jan 27 22:09:47.631: 00:18:74:4b:79:40 Setting ADD_MOBILE ack state for STA a0:88:b4:c8:d6:d8 (idx 33), seqno 106 action 2
*Jan 27 22:09:47.634: 00:18:74:4b:79:40 Configuration Update Response from 10.84.4.46:13197
*Jan 27 22:09:47.667: 00:3a:98:f8:e5:50 Echo Request from 10.84.4.85:11215
*Jan 27 22:09:47.667: 00:3a:98:f8:e5:50 Echo Response sent to 10.84.4.85:11215
*Jan 27 22:09:47.816: 00:3a:98:f8:e6:f0 WTP Event Request from 10.84.4.76:11217
*Jan 27 22:09:47.816: 00:3a:98:f8:e6:f0 WTP Event Response sent to 10.84.4.76:11217
*Jan 27 22:09:47.818: 00:3a:98:f8:e6:f0 WTP Event Request from 10.84.4.76:11217
*Jan 27 22:09:47.818: 00:3a:98:f8:e6:f0 WTP Event Response sent to 10.84.4.76:11217
en*Jan 27 22:09:48.142: 00:3a:98:f4:77:80 Configuration update request for delete station sent to 10.84.4.77:37881
*Jan 27 22:09:48.142: 1c:aa:07:42:f6:30 Successful transmission of LWAPP Add-Mobile to AP 1c:aa:07:42:f6:30
*Jan 27 22:09:48.142: 1c:aa:07:42:f6:30 Setting ADD_MOBILE ack state for STA 00:23:14:54:fa:f8 (idx 4), seqno 97 action 1
*Jan 27 22:09:48.144: 00:3a:98:f4:77:80 Configuration Update Response from 10.84.4.77:37881
able *Jan 27 22:09:48.145: 1c:aa:07:42:f6:30 Configuration Update Response from 10.84.2.112:57954
*Jan 27 22:09:48.319: 1c:aa:07:42:f6:30 Successful transmission of LWAPP Add-Mobile to AP 1c:aa:07:42:f6:30
*Jan 27 22:09:48.319: 1c:aa:07:42:f6:30 Setting ADD_MOBILE ack state for STA 00:23:14:54:fa:f8 (idx 5), seqno 98 action 2
*Jan 27 22:09:48.321: 1c:aa:07:42:f6:30 Configuration Update Response from 10.84.2.112:57954
*Jan 27 22:09:48.362: 00:18:74:4b:cc:10 Echo Request from 10.84.4.41:13363
*Jan 27 22:09:48.362: 00:18:74:4b:cc:10 Echo Response sent to 10.84.4.41:13363
*Jan 27 22:09:48.581: 00:18:74:d0:43:d0 Configuration update request for RRM Neighbour Ctrl List sent to 10:84:4:37
*Jan 27 22:09:48.583: 00:18:74:d0:43:d0 Configuration Update Response from 10.84.4.37:61619
*Jan 27 22:09:48.826: 00:3a:98:f4:77:c0 Echo Request from 10.84.4.93:37881
*Jan 27 22:09:48.827: 00:3a:98:f4:77:c0 Echo Response sent to 10.84.4.93:37881
(Cisco Controller) >*Jan 27 22:09:48.970: 00:18:74:d0:34:70 Configuration update request for RRM Neighbour Ctrl List sent to 10:84:4:40
*Jan 27 22:09:48.972: 00:18:74:d0:34:70 Configuration Update Response from 10.84.4.40:61589
*Jan 27 22:09:49.032: 00:3a:98:f4:77:c0 WTP Event Request from 10.84.4.93:37881
*Jan 27 22:09:49.032: 00:3a:98:f4:77:c0 WTP Event Response sent to 10.84.4.93:37881
*Jan 27 22:09:49.043: 00:18:74:d0:32:40 WTP Event Request from 10.84.4.33:61585
*Jan 27 22:09:49.043: 00:18:74:d0:32:40 WTP Event Response sent to 10.84.4.33:61585
*Jan 27 22:09:49.883: 00:3a:98:f8:e6:70 Successful transmission of LWAPP Add-Mobile to AP 00:3a:98:f8:e6:70
*Jan 27 22:09:49.883: 00:3a:98:f8:e6:70 Setting ADD_MOBILE ack state for STA 78:e4:00:33:49:34 (idx 51), seqno 224 action 1
*Jan 27 22:09:49.885: 00:3a:98:f8:e6:70 Configuration Update Response from 10.84.4.74:11216
*Jan 27 22:09:49.981: 00:18:74:d0:32:40 Configuration update request for delete station sent to 10.84.4.33:61585
*Jan 27 22:09:49.984: 00:18:74:d0:32:40 Configuration Update Response from 10.84.4.33:61585
*Jan 27 22:09:50.343: 00:18:74:4b:ee:00 Echo Request from 10.84.6.207:61448
*Jan 27 22:09:50.343: 00:18:74:4b:ee:00 Echo Response sent to 10.84.6.207:61448
*Jan 27 22:09:50.381: 00:3a:98:f4:77:c0 Configuration update request for delete station sent to 10.84.4.93:37881
*Jan 27 22:09:50.384: 00:3a:98:f4:77:c0 Configuration Update Response from 10.84.4.93:37881
*Jan 27 22:09:50.627: 00:3a:98:f8:e6:70 Successful transmission of LWAPP Add-Mobile to AP 00:3a:98:f8:e6:70
*Jan 27 22:09:50.629: 00:3a:98:f8:e6:70 Configuration Update Response from 10.84.4.74:11216
*Jan 27 22:09:50.786: 00:18:74:d0:34:70 WTP Event Request from 10.84.4.40:61589
*Jan 27 22:09:50.786: 00:18:74:d0:34:70 WTP Event Response sent to 10.84.4.40:61589
*Jan 27 22:09:50.815: 00:18:74:d0:34:70 WTP Event Request from 10.84.4.40:61589
*Jan 27 22:09:50.815: 00:18:74:d0:34:70 WTP Event Response sent to 10.84.4.40:61589
*Jan 27 22:09:50.817: 00:18:74:d0:34:70 WTP Event Request from 10.84.4.40:61589
*Jan 27 22:09:50.817: 00:18:74:d0:34:70 WTP Event Response sent to 10.84.4.40:61589
*Jan 27 22:09:50.819: 00:18:74:d0:34:70 WTP Event Request from 10.84.4.40:61589
*Jan 27 22:09:50.819: 00:18:74:d0:34:70 WTP Event Response sent to 10.84.4.40:61589
*Jan 27 22:09:50.820: 00:18:74:d0:34:70 WTP Event Request from 10.84.4.40:61589
*Jan 27 22:09:50.820: 00:18:74:d0:34:70 WTP Event Response sent to 10.84.4.40:61589
*Jan 27 22:09:50.822: 00:18:74:d0:34:70 WTP Event Request from 10.84.4.40:61589
*Jan 27 22:09:50.822: 00:18:74:d0:34:70 WTP Event Response sent to 10.84.4.40:61589
*Jan 27 22:09:50.947: 00:3a:98:f4:7b:90 Echo Request from 10.84.4.83:37889
*Jan 27 22:09:50.948: 00:3a:98:f4:7b:90 Echo Response sent to 10.84.4.83:37889
*Jan 27 22:09:50.952: 00:12:44:b2:31:00 Primary Discovery Request from 10.84.4.32:55403
*Jan 27 22:09:50.952: 00:12:44:b2:31:00 Primary Discovery Response sent to  10.84.4.32:55403
*Jan 27 22:09:50.952: 00:12:44:b2:31:00 Received LWAPP PRIMARY_DISCOVERY_REQ from AP
*Jan 27 22:09:50.953: 00:12:80:ad:86:a4 Successful transmission of LWAPP Primary Discovery Response to AP 00:12:80:ad:86:a4
*Jan 27 22:09:51.015: 00:3a:98:f4:77:80 Successful transmission of LWAPP Add-Mobile to AP 00:3a:98:f4:77:80
*Jan 27 22:09:51.016: 00:3a:98:f4:77:80 Configuration Update Response from 10.84.4.77:37881
*Jan 27 22:09:51.410: 00:18:74:4b:ee:00 Configuration update request for delete station sent to 10.84.6.207:61448
*Jan 27 22:09:51.411: 00:26:0b:15:d4:60 Successful transmission of LWAPP Add-Mobile to AP 00:26:0b:15:d4:60
*Jan 27 22:09:51.411: 00:26:0b:15:d4:60 Setting ADD_MOBILE ack state for STA 10:0b:a9:33:af:d4 (idx 20), seqno 25 action 1
*Jan 27 22:09:51.412: 00:18:74:4b:ee:00 Configuration Update Response from 10.84.6.207:61448
*Jan 27 22:09:51.412: 00:26:0b:15:d4:60 Configuration Update Response from 10.84.4.81:62863
*Jan 27 22:09:51.449: 00:3a:98:f8:e8:b0 Echo Request from 10.84.4.86:11221
*Jan 27 22:09:51.449: 00:3a:98:f8:e8:b0 Echo Response sent to 10.84.4.86:11221
*Jan 27 22:09:52.098: 00:3a:98:f4:7a:10 Primary Discovery Request from 10.84.5.95:37884
*Jan 27 22:09:52.098: 00:3a:98:f4:7a:10 Primary Discovery Response sent to  10.84.5.95:37884
*Jan 27 22:09:52.098: 00:3a:98:f4:7a:10 Received LWAPP PRIMARY_DISCOVERY_REQ from AP
*Jan 27 22:09:52.098: d0:d0:fd:a9:3f:b8 Successful transmission of LWAPP Primary Discovery Response to AP d0:d0:fd:a9:3f:b8
*Jan 27 22:09:52.246: 00:3a:98:f8:e6:20 WTP Event Request from 10.84.4.75:11215
*Jan 27 22:09:52.246: 00:3a:98:f8:e6:20 WTP Event Response sent to 10.84.4.75:11215
*Jan 27 22:09:52.314: 00:3a:98:f8:e6:20 WTP Event Request from 10.84.4.75:11215
*Jan 27 22:09:52.314: 00:3a:98:f8:e6:20 WTP Event Response sent to 10.84.4.75:11215
*Jan 27 22:09:52.316: 00:3a:98:f8:e6:20 WTP Event Request from 10.84.4.75:11215
*Jan 27 22:09:52.316: 00:3a:98:f8:e6:20 WTP Event Response sent to 10.84.4.75:11215
*Jan 27 22:09:52.318: 00:3a:98:f8:e6:20 WTP Event Request from 10.84.4.75:11215
*Jan 27 22:09:52.318: 00:3a:98:f8:e6:20 WTP Event Response sent to 10.84.4.75:11215
*Jan 27 22:09:52.320: 00:3a:98:f8:e6:20 WTP Event Request from 10.84.4.75:11215
*Jan 27 22:09:52.320: 00:3a:98:f8:e6:20 WTP Event Response sent to 10.84.4.75:11215
*Jan 27 22:09:52.322: 00:3a:98:f8:e6:20 WTP Event Request from 10.84.4.75:11215
*Jan 27 22:09:52.322: 00:3a:98:f8:e6:20 WTP Event Response sent to 10.84.4.75:11215
*Jan 27 22:09:52.335: 00:3a:98:f8:e6:20 WTP Event Request from 10.84.4.75:11215
*Jan 27 22:09:52.336: 00:3a:98:f8:e6:20 WTP Event Response sent to 10.84.4.75:11215
*Jan 27 22:09:52.338: 00:3a:98:f8:e6:20 WTP Event Request from 10.84.4.75:11215
*Jan 27 22:09:52.338: 00:3a:98:f8:e6:20 WTP Event Response sent to 10.84.4.75:11215
*Jan 27 22:09:52.354: 00:18:74:d0:30:f0 Echo Request from 10.84.4.38:61581
*Jan 27 22:09:52.354: 00:18:74:d0:30:f0 Echo Response sent to 10.84.4.38:61581
*Jan 27 22:09:52.372: 00:3a:98:f4:7a:10 Echo Request from 10.84.5.95:37884
*Jan 27 22:09:52.373: 00:3a:98:f4:7a:10 Echo Response sent to 10.84.5.95:37884
*Jan 27 22:09:52.492: 00:26:99:10:1f:40 WTP Event Request from 10.84.4.36:1279
*Jan 27 22:09:52.492: 00:26:99:10:1f:40 WTP Event Response sent to 10.84.4.36:1279
*Jan 27 22:09:52.494: 00:26:99:10:1f:40 WTP Event Request from 10.84.4.36:1279
*Jan 27 22:09:52.494: 00:26:99:10:1f:40 WTP Event Response sent to 10.84.4.36:1279
*Jan 27 22:09:52.495: 00:26:99:10:1f:40 WTP Event Request from 10.84.4.36:1279
*Jan 27 22:09:52.496: 00:26:99:10:1f:40 WTP Event Response sent to 10.84.4.36:1279
*Jan 27 22:09:52.497: 00:26:99:10:1f:40 WTP Event Request from 10.84.4.36:1279
*Jan 27 22:09:52.497: 00:26:99:10:1f:40 WTP Event Response sent to 10.84.4.36:1279
*Jan 27 22:09:52.499: 00:26:99:10:1f:40 WTP Event Request from 10.84.4.36:1279
*Jan 27 22:09:52.499: 00:26:99:10:1f:40 WTP Event Response sent to 10.84.4.36:1279
*Jan 27 22:09:52.501: 00:26:99:10:1f:40 WTP Event Request from 10.84.4.36:1279
*Jan 27 22:09:52.502: 00:26:99:10:1f:40 WTP Event Response sent to 10.84.4.36:1279
*Jan 27 22:09:52.584: 00:3a:98:f4:7a:10 WTP Event Request from 10.84.5.95:37884
*Jan 27 22:09:52.585: 00:3a:98:f4:7a:10 WTP Event Response sent to 10.84.5.95:37884
*Jan 27 22:09:52.587: 00:3a:98:f4:77:c0 Configuration update request for delete station sent to 10.84.4.93:37881
*Jan 27 22:09:52.588: e8:40:40:cd:8b:70 Successful transmission of LWAPP Add-Mobile to AP e8:40:40:cd:8b:70
*Jan 27 22:09:52.589: 00:3a:98:f4:77:c0 Configuration Update Response from 10.84.4.93:37881
*Jan 27 22:09:52.590: e8:40:40:cd:8b:70 Configuration Update Response from 10.84.2.111:23844
*Jan 27 22:09:52.594: 00:3a:98:f4:77:80 Echo Request from 10.84.4.77:37881
*Jan 27 22:09:52.594: 00:3a:98:f4:77:80 Echo Response sent to 10.84.4.77:37881
*Jan 27 22:09:52.782: 00:18:74:d0:43:d0 Successful transmission of LWAPP Add-Mobile to AP 00:18:74:d0:43:d0
*Jan 27 22:09:52.782: 00:18:74:d0:43:d0 Setting ADD_MOBILE ack state for STA 88:c6:63:d0:a5:e9 (idx 78), seqno 95 action 1
*Jan 27 22:09:52.784: 00:18:74:d0:43:d0 Configuration Update Response from 10.84.4.37:61619
*Jan 27 22:09:52.831: 00:26:99:10:b8:40 Echo Request from 10.84.4.48:56442
*Jan 27 22:09:52.831: 00:26:99:10:b8:40 Echo Response sent to 10.84.4.48:56442
*Jan 27 22:09:52.847: 00:3a:98:d6:e4:80 WTP Event Request from 10.84.2.10:62171
*Jan 27 22:09:52.848: 00:3a:98:d6:e4:80 WTP Event Response sent to 10.84.2.10:62171
*Jan 27 22:09:52.946: 00:3a:98:f8:e8:b0 Primary Discovery Request from 10.84.4.86:11221
*Jan 27 22:09:52.946: 00:3a:98:f8:e8:b0 Primary Discovery Response sent to  10.84.4.86:11221
*Jan 27 22:09:52.946: 00:3a:98:f8:e8:b0 Received LWAPP PRIMARY_DISCOVERY_REQ from AP
*Jan 27 22:09:52.947: f8:66:f2:c2:bd:42 Successful transmission of LWAPP Primary Discovery Response to AP f8:66:f2:c2:bd:42
*Jan 27 22:09:53.198: 00:1f:9e:80:72:b0 Successful transmission of LWAPP Add-Mobile to AP 00:1f:9e:80:72:b0
*Jan 27 22:09:53.200: 00:1f:9e:80:72:b0 Configuration Update Response from 10.84.4.55:22431
*Jan 27 22:09:53.280: 00:26:0b:15:d4:60 Echo Request from 10.84.4.81:62863
*Jan 27 22:09:53.280: 00:26:0b:15:d4:60 Echo Response sent to 10.84.4.81:62863
*Jan 27 22:09:53.298: 00:12:44:b2:31:00 Successful transmission of LWAPP Add-Mobile to AP 00:12:44:b2:31:00
*Jan 27 22:09:53.300: 00:12:44:b2:31:00 Configuration Update Response from 10.84.4.32:55403
*Jan 27 22:09:53.732: 00:18:74:4b:60:40 WTP Event Request from 10.84.4.34:13148
*Jan 27 22:09:53.733: 00:18:74:4b:60:40 WTP Event Response sent to 10.84.4.34:13148
*Jan 27 22:09:53.998: 00:3a:98:f8:e8:b0 WTP Event Request from 10.84.4.86:11221
*Jan 27 22:09:53.999: 00:3a:98:f8:e8:b0 WTP Event Response sent to 10.84.4.86:11221
*Jan 27 22:09:54.059: 00:3a:98:f8:e4:e0 WTP Event Request from 10.84.4.94:11213
*Jan 27 22:09:54.060: 00:3a:98:f8:e4:e0 WTP Event Response sent to 10.84.4.94:11213
*Jan 27 22:09:54.928: 00:18:74:4a:a6:80 Echo Request from 10.84.4.52:12775
*Jan 27 22:09:54.928: 00:18:74:4a:a6:80 Echo Response sent to 10.84.4.52:12775
*Jan 27 22:09:54.930: 00:18:74:4a:a6:80 WTP Event Request from 10.84.4.52:12775
*Jan 27 22:09:54.930: 00:18:74:4a:a6:80 Updated Link Latency info for AP 00:18:74:4a:a6:80, delay 1 ms
*Jan 27 22:09:54.930: 00:18:74:4a:a6:80 WTP Event Response sent to 10.84.4.52:12775
*Jan 27 22:09:56.083: 00:3a:98:d6:e4:80 Successful transmission of LWAPP Add-Mobile to AP 00:3a:98:d6:e4:80
*Jan 27 22:09:56.085: 00:3a:98:d6:e4:80 Configuration Update Response from 10.84.2.10:62171
*Jan 27 22:09:56.132: 00:3a:98:f8:f3:e0 Primary Discovery Request from 10.84.2.11:11243
*Jan 27 22:09:56.132: 00:3a:98:f8:f3:e0 Primary Discovery Response sent to  10.84.2.11:11243
*Jan 27 22:09:56.132: 00:3a:98:f8:f3:e0 Received LWAPP PRIMARY_DISCOVERY_REQ from AP
*Jan 27 22:09:56.132: 00:0b:5f:7b:38:bf Successful transmission of LWAPP Primary Discovery Response to AP 00:0b:5f:7b:38:bf
*Jan 27 22:09:56.146: 00:3a:98:f8:ea:80 WTP Event Request from 10.84.4.78:11224
*Jan 27 22:09:56.147: 00:3a:98:f8:ea:80 WTP Event Response sent to 10.84.4.78:11224
*Jan 27 22:09:56.825: 00:18:74:d0:30:f0 Successful transmission of LWAPP Add-Mobile to AP 00:18:74:d0:30:f0
*Jan 27 22:09:56.825: 00:18:74:d0:30:f0 Setting ADD_MOBILE ack state for STA 00:1c:bf:cf:6f:17 (idx 67), seqno 216 action 2
*Jan 27 22:09:56.828: 00:18:74:d0:30:f0 Configuration Update Response from 10.84.4.38:61581
*Jan 27 22:09:56.895: 00:1f:9e:41:b9:80 Primary Discovery Request from 10.84.4.56:57785
*Jan 27 22:09:56.895: 00:1f:9e:41:b9:80 Primary Discovery Response sent to  10.84.4.56:57785
*Jan 27 22:09:56.895: 00:1f:9e:41:b9:80 Received LWAPP PRIMARY_DISCOVERY_REQ from AP
*Jan 27 22:09:56.895: 00:1e:7a:be:1b:8e Successful transmission of LWAPP Primary Discovery Response to AP 00:1e:7a:be:1b:8e
*Jan 27 22:09:57.023: 00:3a:98:f8:e0:b0 Successful transmission of LWAPP Add-Mobile to AP 00:3a:98:f8:e0:b0
*Jan 27 22:09:57.026: 00:3a:98:f8:e0:b0 Configuration Update Response from 10.84.4.89:11205
*Jan 27 22:09:57.092: 00:26:99:10:1f:40 Echo Request from 10.84.4.36:1279
*Jan 27 22:09:57.092: 00:26:99:10:1f:40 Echo Response sent to 10.84.4.36:1279
*Jan 27 22:09:57.732: 00:3a:98:f4:78:c0 Echo Request from 10.84.4.90:37883
*Jan 27 22:09:57.732: 00:3a:98:f4:78:c0 Echo Response sent to 10.84.4.90:37883
*Jan 27 22:09:57.771: 00:18:74:d0:43:d0 WTP Event Request from 10.84.4.37:61619
*Jan 27 22:09:57.771: 00:18:74:d0:43:d0 WTP Event Response sent to 10.84.4.37:61619
*Jan 27 22:09:58.488: 00:3a:98:f8:e6:f0 Successful transmission of LWAPP Add-Mobile to AP 00:3a:98:f8:e6:f0
*Jan 27 22:09:58.490: 00:3a:98:f8:e6:f0 Configuration Update Response from 10.84.4.76:11217
*Jan 27 22:09:58.681: 00:3a:98:f4:77:60 WTP Event Request from 10.84.4.73:37880
*Jan 27 22:09:58.681: 00:3a:98:f4:77:60 WTP Event Response sent to 10.84.4.73:37880
*Jan 27 22:09:58.683: 00:3a:98:f4:77:60 WTP Event Request from 10.84.4.73:37880
*Jan 27 22:09:58.683: 00:3a:98:f4:77:60 WTP Event Response sent to 10.84.4.73:37880
*Jan 27 22:09:58.862: 00:3a:98:f8:e4:e0 Echo Request from 10.84.4.94:11213
blakekrone Fri, 01/27/2012 - 14:03
  • Silver, 250 points or more
What discovery options are you attempting to have the AP do to find the controller?
Can you do a show interface summary ?
rguzman.plannet Fri, 01/27/2012 - 14:19
I am not quite sure of your question, but I guess you mean if it is LWAPP or CAPWAP.
If so, it seems AP is trying first LWAPP but WLC answers in CAPWAP. At the begining I typed I converted one AP but when I tried the second one it didn't work for no reason apparently, I also changed to a different device just to discard th posibility of a device failure but it shows the same logs. It can also ping the WLC, gateway, etc, etc. but cannot complete the association to WLC.
blakekrone Fri, 01/27/2012 - 14:29
Part of the startup process is using various options to find the WLC such as DHCP Option 43, DNS query, local broadcast, last joined WLC, etc. When I was looking through the debugs it appeared as though there might have been a broadcast forwarder or something going on.
If you say that you have 4 AP spots available, you should be able to at least bring 2 more online before you hit the 48 that George mentioned.
Correct Answer
George Stefanick Fri, 01/27/2012 - 14:16
Rguzman,
JUST AN FYI
rguzman.plannet Fri, 01/27/2012 - 14:21
Damn! That's true I kinda remember that, I read it somewhere.
Well thanks a lot to everyone, anyways I am about to deploy the high availability scheme with a 5508.
Best regards!
George Stefanick Fri, 01/27/2012 - 14:25
On the 5508 you dont need a AP manager unless you want to break up traffic / ports.
Thanks for the ratings guys!
rguzman.plannet Fri, 01/27/2012 - 14:27
I was thinking...
Shouldn't it had adopted the AP since there are 46 adopted, the 47 was configured then adopted but right now it is not connected to the network. So if I configured the "48" it should be adopted too at least for the test.
Or there is a kind of register kept by the WLC that avoids more adoptions?
George Stefanick Fri, 01/27/2012 - 14:29
Well I was thinking the same as well, thats why I mentioned the 48 limit as an FYI. Count how many APs you actually have on your WLC is it 46 or 48 ?
rguzman.plannet Fri, 01/27/2012 - 14:31
Right now connected, adopted, working and visible from the WLC only 46.
George Stefanick Fri, 01/27/2012 - 15:00
What are you using to join to the WLC ie DNS, option 43, OTAP ?? Can you extend the WLC managment vlan to a switch port and put the ap on it so broadcast would be the means for the ap to join the wlc ?
rguzman.plannet Fri, 01/27/2012 - 15:09
I set IP addresses manually and use upgrade tool.
I just connected AP47 and was adopted by the WLC.
Did not really get this: Can you extend the WLC managment vlan to a switch port and put the ap on it so broadcast would be the means for the ap to join the wlc ?
blakekrone Fri, 01/27/2012 - 15:11
I don't think you are understanding how APs join the WLC.
You need to specify the WLC address via DHCP Option 43, DNS, or have the APs on the same broadcast network as the WLC management interface.
Again, we'll ask. Have you setup DHCP Option 43, DNS (CISCO-CAPWAP-CONTROLLER.yourdomain.com)?
blakekrone Fri, 01/27/2012 - 15:13
George remember OTAP is no long supported after 6.0.188
George Stefanick Fri, 01/27/2012 - 15:20
Yes I recall... Do you remember my hacking video that was on Network World ?? *cough* *cough* ... Did see the code rev ...
You can also do a IP forward UDP 5246 as well.
So  your AP starts up the first thing it will do is broadcast. If our ap is  on the same subnet as your WLC managment IP address she will learn  where the wlc lives. Keep in mind this only has to happen one time.  After the ap learns about the WLC it saved in NVRAM on the ap.
rguzman.plannet Fri, 01/27/2012 - 15:40
I have to admit, and doesn't make me feel proud lol, that the whole process it's alwayes been a bit confusing to me. But I have set up several WLCs either Stand Alone to LWAPP or already LWAPP devices. In the case of SA to LWAPP I have followed the cook recipe and I had never had this problem.
So let me get clear on this so that I can answer to your question.
By the way it is still weird that everything works fine until I add the AP47. And I dont think I missed a step on converting SA to LWAPP since I had just converted one and i took about 10 min. Then like I said I got a different AP and getting same results.
Thanks.
George Stefanick Sun, 01/29/2012 - 16:41
I would CLI into the problem AP and see if you see anything out of place. Sometimes when you upgrade from autonomous to thin you could run into problems which may cause you to reflash the ap.
Related Content
