This discussion is locked
Ask the Expert:Cisco Service Control Solution
Jan 27th, 2012
Read the bioWith Karthik Natarajan
Welcome to the Cisco Support Community Ask the Expert conversation. This is an opportunity to learn and ask questions of expert Karthik Natarajan about how to troubleshoot various components of Cisco Server Control Solution products including Cisco SCE 2000 Series Service Control Engine, Cisco SCE 8000 Series Service Control Engine, Cisco Service Control Subscriber Manager (SCMS SM), Cisco Service Control Collection Manager (SCMS CM), Cisco Service Control Application for Broadband (SCA BB). Karthik Natarajan is a manager in the Edge Routing Business Unit. He works on worldwide escalations about Cisco Service Control Engine Solutions. Natarajan has been associated with Cisco for more than 11 years working in several engineering positions in NMS and LAN Switching Technologies. He holds a bachelor's degree in computer sciences and engineering from Bharath Institute of Technology at Chennai, India. He also holds CCNP certification.
Remember to use the rating system to let Karthik know if you have received an adequate response.
Karthik might not be able to answer each question due to the volume expected during this event. Remember that you can continue the conversation on the Service Providers sub-community   discussion forum shortly after the event. This event lasts through February 10, 2012. Visit this forum often to view responses to your questions and the questions of other community members.
Overall Rating: 5 (1 ratings)
John Ventura Wed, 02/01/2012 - 07:26
Hi Karthik. I have a question. What is the maximum number of IP addresses that can be assigned to a subscriber per SCE chassis?
- John
Karthik Natarajan Wed, 02/01/2012 - 23:44
Hi John,
The maximum number of IP mappings per subcriber are as follows,
In SCE 8000,
           for Standalone mode, we can have 1024 Pure IP mappings. If Private IP mapping, the limit is 200.
           for Cascase mode, we can have 200 Pure IP mappings. If Private IP mapping, the limit is 50.
In SCE 2020/1010 the numbers are same as SCE 8000, except that in Cascase mode, we can have 300 Pure IP mappings.
An IP mapping may be either a single IP address or a range of addresses.
But on the chassis wide as well, we have some restrictions on the mappings.
Device          Subscribers     IP Addresses     IP Ranges
SCE 8000     1,000,000        1,000,000          250,000
SCE 2020     200,000          200,000             >7900
SCE 1010     100,000          100,000             >7900
The above limits are specified by the SCOS, but actual numbers would be less because of higher subscriber context size.
Karthik N.
Marianna Coelho Thu, 02/02/2012 - 12:35
Hi Karthik, Do you know how many anonymous subscribers can be in a SCE chassis? When are N/A subscribers changed to anonymous subscribers?
Thank you
Marianna
Consultor1 Thu, 02/02/2012 - 14:30
good afternoon
i need to know to whom a can turn to for the replacement of a team wap200 and what the warranty covers???
Mayandi
Karthik Natarajan Fri, 02/03/2012 - 06:01
Hi Marianna,
The amount of anonymous subscribers suppoerted per SCE chasssis is only 80,000 (common for both SCE 2020 & SCE 8000).
On a whole the SCE 2020 can hold max of 200K subs and SCE 8000 can hold a maximum of 1M subscribers.
Each traffic processor has a rate limit for creating new anonymous subscribers.
In SCE 2020, the rate limit is 60 new anonymous subscriber per second per traffic processor, the rate is enforced with a granularity of 100 milli seconds. In practice it is 6 per 100 milli seconds. Overall, we get a maximum rate of 180 anonymous subscriber per second on the SCE2000.
In SCE 8000, the rate was the same as in SCE2000 before SCOS release 3.6.0 and from SCOS release 3.6.0, it has been increased to 360 subscribers per second.
Unlike the SCE 2020, with the SCE 8000 the granularity is in seconds and the limit per TP is 30 new anonymous subscriber per seconds (15 per second prior to 3.6.0).
For example with SCE 8000 running SCOS release 3.6.0, let's say we have specific second where traffic processor #6 opened 30 anonymous subscribers already and now comes a flow for the 31st new subscriber side IP, the rate cannot be breached so the flow is mapped to the 'N/A' subscriber.
The traffic processor #6 will only try to create the anonymous subscriber (for that 31st subscriber side IP address) upon seeing a new flow from that same Subscriber side IP.
Hope this clarifies your query.
Karthik N.
Gustavo Hernandez Fri, 02/03/2012 - 08:40
Hi Karthik,
Is there any communication from SCA BB Console to CM during the apply? How does the SCA BB Console learn about CM IP address?
thx
-Lisa
Karthik Natarajan Fri, 02/03/2012 - 10:08
Hi Lisa,
When a service configuration is applied to a SCE device from SCA BB console, following steps happen (with respect to Collection Manager),
      1) SCA BB console would collect the IP address of Collection Manager server from SCE device (by reading the RDR formatter destinations). All RDR formatter destinations (other than the loopback IP address) would be checked if the destination is Collection Manager.
      2) It would then connect to Collection Manager, and get the database details.
      3) Connect to database, and update the INI_VALUES table with details on applied service configuration. For more details on table enties, you can refer to SCA BB Reference Guide (http://www.cisco.com/en/US/docs/cable/serv_exch/serv_control/broadband_app/rel37x/scabbrg/04_SCA_BB_RG.html#wp1001308).
      4) The SCA Reporter or Insight would use the mappings contained in the table for generating appropriate reports.
Karthik N.
18511613763312m Fri, 02/03/2012 - 08:58
Hi Karthink
  I have a cisco 2801 router and I want to connect two ADSL links on it and balance the load but not that kind of IOS that team would need or if I would be useful?
Marisol
Karthik Natarajan Fri, 02/03/2012 - 10:21
Hi Marisol,
I'm not an expert on the WAN routing topic, so I may not be able to answer your query. But I would suggest you to take a look at the ADSL configuration examples which will provide options required for your scenario. You may also post this query under the more appropriate 'WAN, Routing and Switching' community for support from other members.
Asymmetric Digital Subscriber Line (ADSL) Configuration Examples and TechNotes
http://www.cisco.com/en/US/tech/tk175/tk15/tech_configuration_examples_list.html
Cisco Support Community - WAN, Routing and Switching
https://supportforums.cisco.com/community/netpro/network-infrastructure/routing
Karthik N.
NTT Com Security Fri, 02/03/2012 - 17:28
Off topic.  How can I pull up the rules associated with the object_group on an ASA ver 8.2?
Karthik Natarajan Sat, 02/04/2012 - 06:42
Welcome to Cisco Support Forums.
To get the list of rules associated with Object Groups, you can use the following commands,
show access-list - Shows the ACL and the associated hit counter for each line. This command shows the expanded ACL entries for each object group defined.
show running-config object-group - Displays the current object groups by their group ID.
Hope this helps. If not, you may post this query under the 'Firewalling' community as well.
Cisco Support Community - Firewalling
https://supportforums.cisco.com/community/netpro/security/firewall
Karthik N.
gurcan.gungor Sat, 02/04/2012 - 08:55
I want to know more about the diagnostic capabilities of the SCE 8000.
We want to test SPA,SIP, SCM cards in our lab, what will be the correct procedure ? does cisco provide any documentation about this ?
For example we are getting common errors from the field deployed SCEs' SIP boards always the problematic one is SPA3. How could this be possible on 6 different SCE devices, and also error is common always.
Thanks.
Karthik Natarajan Tue, 02/07/2012 - 06:40
Hi Gurcan,
In SCE 8000, we do have a procedure for running hadrware diagnostics. It would check the status of different hardware components in the data path. The procedure could be only shared via the Cisco Technical Support team, so I would suggest you to get in touch with Cisco TAC. Also, to run this test the device should be taken out of network i.e., no outside traffic to be flowing through the device.
Karthik N.
gurcan.gungor Wed, 02/08/2012 - 01:35
Hi Karthik,
What is the correct method of communication with TAC, how can we connect with TAC without opening a TAC case.
Thanks.
Jaime Soto Vale... Tue, 02/07/2012 - 12:19
Hi Karthik,
I´m currently doing a lab tests of SCOS 3.7.2 and I´m seeing a issue when a want to see the reportes in SCABB.
The SCE8000 has a correct time configured and also the Collection Manager, but when we create a new report the Reporter shows a correct protocol classification but whith one hour of delay.
Best regards,
Jaime Soto.
Karthik Natarajan Tue, 02/07/2012 - 18:32
Hi Jamie,
You had mentioned that the reports are one hour out of sync, so it looks like its related to daylight savings. In CM, you would have configured the SCE Offset. Check if the value is correct. The SCA Reporter does not use the correct time intervals unless the offset stored in the Collection Manager is consistent with the timezone of the SCE.
~scmscm/cm/bin/updatetimezone.sh --rdr
Refer to http://www.cisco.com/en/US/docs/cable/serv_exch/serv_control/broadband_app/rel37x/cmug/Managing_the_Collection_Manager.html#wp1074349
As you had checked the time in SCE and CM are in sync. Could you also check the following,
1) Check if the machine running SCA Reporter is as well in sync with the other two components.
2) In SCE, the commands to configure time and timezone are different, so double check once.
clock set (in priv exec mode): http://www.cisco.com/en/US/docs/cable/serv_exch/serv_control/broadband_app/rel37x/sce8000_cli_ref/CLI_Ref_1.html#wp1085017
clock timezone (in global config mode): http://www.cisco.com/en/US/docs/cable/serv_exch/serv_control/broadband_app/rel37x/sce8000_cli_ref/CLI_Ref_1.html#wp1086316
Karthik N.
Jaime Soto Vale... Wed, 02/08/2012 - 09:34
Thanks Karthik,
The issue was the timezone in Collection Manager, now it is working well.
Jaime.
Jaime Soto Vale... Wed, 02/08/2012 - 13:48
Hi Karthik,
In our lab where we are testing SCOS 3.7.2 we are seeing a new issue. When SCE is reloaded it no longer sends RDRs to CM, even though from SCE the CM is UP.
For example before of reload:
SCE8000#>sh RDR-formatter
Status:  enabled
Connection is: up
Forwarding mode: simple-load-balancing
Connection Table:
| Collector       | Port  |Status| Priority per Category:                                |
| IP-Address  /   |       |      |-------------------------------------------------------|
| Host-Name       |       |      | Category1   | Category2   | Category3   | Category4   |
| 192.168.105.20  | 33000 | up   | 90  current | 90  current | 90  current | 90  current |
RDR:    queued:     0 ,sent:   104, thrown:     0, format-mismatch:     0
UM:     queued:     0 ,sent:     0, thrown:     0
Logger: queued:     0 ,sent:     0, thrown:     0
Errors: thrown:     0
Last time these counters were cleared: 17:23:40  CHI  WED  February  8  2012
SCE8000#>
and after of reload:
Status:  enabled
Connection is: up
Connection Table:
RDR:    queued:     0 ,sent:     0, thrown:     0, format-mismatch:     0
Errors: thrown:     0
Last time these counters were cleared: 17:43:06  CHI  WED  February  8  2012
But, if we apply the service configuration from SCABB to SCE, this one send RDRs again. (This conclusion was after a many time of troubleshooting, reload SCE, delete rdr configuration and load again, stop and start CM service, etc)
Status:  enabled
Connection is: up
Connection Table:
RDR:    queued:     0 ,sent:    76, thrown:     0, format-mismatch:     0
Errors: thrown:     0
Obviously this behavior isn´t normal, so I would like to know if you can help me. I checked this several times and always the only way to recover RDRs from SCE was the same.
SCE and CM are with 3.7.2 version.
Jaime.
gurcan.gungor Thu, 02/09/2012 - 01:06
hi,
we hit the same thing like you, and we opened a case.
And this is confirmed as bug, the bug ID is CSCtx48102.
Karthik Natarajan Thu, 02/09/2012 - 06:38
Hi Gurcan,
Thanks for sharing the defect ID.
Hi Jaime,
The issue you are facing is tracked by the defect mentioned. As a workaround we would suggest you to run the following command after any changes to the CLI or applying service configuration. This would retain the configuration even after reload.
SCE8000#>copy running-config-all startup-config-all
We are currently updating the defect with these details, and would be soon available on Cisco Bug Toolkit.
Karthik N.
Jaime Soto Vale... Thu, 02/09/2012 - 08:36
Hi Karthik,
I applied that command always after I did a change and also before reload it but the issue still appears: After reload the SCE don't send RDRs to CM until I apply the service configuration in the SCABB again.
Jaime.
Karthik Natarajan Fri, 02/10/2012 - 00:11
Hi Jaime,
We had tested the workaorund before suggesting it. As 3.7.2 is recently released, it could be possible that we are missiing some scenario. This would require further troubleshooting. So, I would suggest you to open a service request, and we can take it forward.
Karthik N.
Pavel Dimow Fri, 02/10/2012 - 12:26
Hi Karthik,
is there any other way to manage multiple configuration for multiple SCE beside SCA BB?
Thank you.
Karthik Natarajan Fri, 02/10/2012 - 21:25
Hi Pavel,
Yes, we do have a API flavor for service configuration. You can refer to Programming Guide section under SCA BB.
http://www.cisco.com/en/US/products/ps6135/products_programming_reference_guides_list.html
For applying/retriving the service configuration to the SCE, we do support the servconf CLU.
http://www.cisco.com/en/US/docs/cable/serv_exch/serv_control/broadband_app/rel37x/scabbug/14_SCA_BB_UG.html#wp1044435
Karthik N.
