Radius Authentication - client not able to connect even after ssid broadcasting
Jan 28th, 2012
Hi Friends,
I have  Issues with Wifi radius Autentication.
we uses cisco 1140AG access point, which is used in Standalone mode  issue we face is,
only Several Laptops not able to connect to wifi ,
But in all laptops SSID "wether" is broadcasting. signal strength is full. But it was not able to connect,
If AP settings are wrong then all clients should not connect, since few clients connected it ruled out AP config errors,
We uses ( WPA - Enterprise + tkip ) settings , clients mostly windows 7.
Windows 7 settings also cannot be wrong, since it is globally  pushed via GPO for same Wifi settings.
i totally cant understand this scenario..
when i checked the radius logs, i am not able to see any logs for the client since it is not associating,
SSID is fully broadcasting in Laptop with full coverage. but just not connecting....
Any inputs to fix this issue is much helpful
Overall Rating: 3.5 (2 ratings)
Scott Fella Sat, 01/28/2012 - 10:43
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
You should see something in the radius logs if the ap and radius are communicating correctly. Did you setup your AAA clients in the radius. You can always use a radius test utility like NTRadping to test radius.
Scott Fella
Sent from my iPhone
Scott Fella Sat, 01/28/2012 - 10:49
  • Hall of Fame,
    2017 Wireless
You also mentioned that only a few are not connecting. So you ruled out radius. Now if some user are connected fine and some are not on the same ap, you rule out the AP and need to look at the client. Check the profile to see if they did get it pushed out via GPO and check the drivers. The clients that do not connect are the same device type and model that do?
safwan riyazudeen Sun, 01/29/2012 - 01:29
Hi Scott,
thanks for ur response.
I Think model is different, 2 laptops which is not at all connected, is Dell .. i will check the Laptop model which is working & revert on these....
but OS is windows 7 for all...
if GPO is not pushed proprely means SSID itself should not be detecting in Client right???
i tried to see netsh wlan show all.. to see if client settings r same. but unfortunatley since user PCs in Japanese.. that also not clear..
i have lot of issues in Radius authentications , mostly with My APAC clients, since all r standalone AP,s..  i now took control need to sort out 1 by 1...
Trending Topics - Security & Network
