OSPF periodic flooding
Jan 29th, 2012
Studying Ospf, and periodic flooding i found that ospf refresh it's LSA every 30 minutes (1800 seconds) if no change occur, but the output of my show ip ospf database shown an age of more than 1800 seconds as in the output above from my router 1800 series…
Searching on Google or Cisco site i haven't found nothing about configurable timer, but about 1800 second is the default behavior for the standard, in my lab there is the exception who proves the rule?
Router_A#sh ip ospf database
            OSPF Router with ID (10.10.10.10) (Process ID 10)
                Router Link States (Area 0)
Link ID         ADV Router      Age         Seq#       Checksum Link count
9.9.9.9         9.9.9.9         1888        0x80000002 0x009AC3 2
10.10.10.10     10.10.10.10     1887        0x80000003 0x005C7A 2
And after a lot of time router b has reset the timer but router a is going up...
9.9.9.9         9.9.9.9         2017        0x80000002 0x009AC3 2
10.10.10.10     10.10.10.10     127          0x80000004 0x005A7B 2
Mohamed Sobair Sun, 01/29/2012 - 09:13
  • Gold, 750 points or more
LSA Refreshes every 30 minutes, but this is a Partial update (Updates with new changes).
the FULL OSPF updates are sent every 2 hours, this updates contains (full topology) info. So what you are seeing is normal.
Mohamed
Beetlejuice01 Sun, 01/29/2012 - 09:30
Hi Mohamed, from the page 204 of Cisco book Offical Certification Guide CCNP of Wendell Odom:
If 30 minutes pass with no change to an lsa meaning no other reason existed in that 30 minutes to cause a reflooding of the lsa the owning router increments the sequence number,resets the timer to 0 and reflood lsa.
Because the owning router increments the sequence number and resets the LSAge every 1800 seconds (30 minutes) the output of various show ip ospf database command showld also show an age of less than 1800 seconds.
And continue... when a router realizes it needs to flush an lsa from lsdb for an area, it actually sets the age of the LSA to the MaxAge setting (3600)
If 1800 is 30 minutes 3600 is 1 hour... where have you found information about 2 hours?
The router B in my cases has reset timer at 1900 an more, the router A after 3600 seconds.
Mohamed Sobair Sun, 01/29/2012 - 09:58
Fabio,
I apologize, its not 2 hours. You are correct, its 1 hour the Maxage LSA.
what I meant, is when the router needs to flood an LSA, it set the maxage to the LSA. Only those routers who originate the LSA can set the timer and flood to its ospf neighbors.
The Changes are immediately flooded to all routers and the LSA refreshes every 30 minutes if the network is Stable.
If a new LSA must be created, the router must first flush the OLd LSA from all OSPF database, and this is done by setting the Maxage to the existing LSA, the router then reflodds it to its adjacent OSPF neigbor before sending the New LSA.
Have you performed any configuration changes while examining this behaviour?
Apologize again, I was almost sleeping.
Mohamed
Beetlejuice01 Sun, 01/29/2012 - 10:18
What i'm seeing in my test is only that with two router simply connected with a serial cable with no change on topology the LSA as described on the book with no change isn't refreshed after 30 minutes. Obviously if i made some change or change the status of some interface the change occur, but without change the rule "age of less than 1800 seconds" isn't as described from our collegue who written the book nor as i found on Cisco's material online...that's only strange. I've doesn't change any timer on router so it's the default behavior of the two router that is different one from the other because one finish the max age of 3600 and the other not.
You don't need to apologize i've seen your profile your knowledge is amazing :-D
I will try to reset the configuration to default and reconfigure a simple ospf from 0 to see if return's to the standard.
Richard Burts Sun, 01/29/2012 - 14:25
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Fabio
The behavior that you describe sounds very much like the features introduced in OSPF Demand Circuit. See this link for details
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094a8f.shtml
Perhaps you could post the output of the router configuration or at least the interface config and the OSPF config?
Rick
Beetlejuice01 Sun, 01/29/2012 - 22:22
Hi Richard,
I already know about that features, but it isn't my case. I've only configured a simple ospf over 2 serial interface and specified interface as point to point to auto establish a neighborship because i've configured frame relay. With that feature in the document you have posted when configured demand circuit to suppress lsa it's configured the do not advertise "dna" features, and it will be shown on the ip ospf database as example above:
9.9.9.9         9.9.9.9         2017      (DNA)  0x80000002 0x009AC3 2
Both Mohamed and Richard if you have an ospf case can you check if the timer goes over  1800?
Fabio
Beetlejuice01 Mon, 01/30/2012 - 01:15
hi Peter,
no Ospf LSA Group Pacing configured, i've already tried to configure this feature to do the lsa flooding but both routers ignore the timer who i set and reset timer when it want.
Beetlejuice01 Tue, 02/14/2012 - 01:31
Hi all, after a lot of time i have deleted the old config and configured ospf from 0, but with the same result.
Here a config of one router. Is the same on both, except for dce on frame relay.
Router#sh run
Building configuration...
Current configuration : 1053 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication login default local
aaa authorization console
aaa authorization exec default local
aaa session-id common
ip cef
frame-relay switching
username cisco privilege 15 secret 5 $1$c.Gq$Ra8zdDojuaaoek3X0gn8S1
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
bandwidth 2000
ip address 192.168.100.1 255.255.255.252
encapsulation frame-relay IETF
ip ospf network point-to-point
frame-relay interface-dlci 100
frame-relay lmi-type cisco
frame-relay intf-type dce
router ospf 1
log-adjacency-changes
network 192.168.100.0 0.0.0.3 area 0
ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line vty 0 4
scheduler allocate 20000 1000
end
AFTER more than 1800 sec...
Router#show ip ospf database
            OSPF Router with ID (192.168.100.1) (Process ID 1)
192.168.100.1   192.168.100.1   1816        0x80000002 0x00AB0D 2
192.168.100.2   192.168.100.2   1817        0x80000002 0x009F17 2
AFTER counter reset of Router A.
192.168.100.1   192.168.100.1   45          0x80000003 0x00A90E 2
192.168.100.2   192.168.100.2   1875        0x80000002 0x009F17 2
Timothy Hall Sun, 11/04/2012 - 15:21
  • Cisco Employee,
I know you asked this several months ago, but while studying for my CCNP Route exam I came across this which may shed some light...
http://www.cisco.com/en/US/docs/ios/12_1t/12_1t2/feature/guide/dt_ospff.html
You may want to check your IOS version and see if (DNA) or Do not Age is set to default.
Based on your output:
It doesn't show this in the last output though...
