WAVE-594-12G 3000 TCP Connections?
Jan 20th, 2012
Hello
Just deployed the new WAVE-594s into production. I've added the appliances into Cacti (MRTG monitoring) and noticed the maximum TFO connections bar was at 3k.
The documentation on Cisco's website and sizing guides shows this model at 1300 maximum supported TFO connections.
Can anyone confirm if this is a typo on the website and sizing guide or the code I'm running????
http://www.cisco.com/en/US/prod/collateral/contnetw/ps5680/ps6474/data_sheet_c78-685554.html
   Policy Engine Config Item            Value
   State                                Registered
   Default Action                       Use Policy
   Connection Limit                     3000
   Effective Limit                      2980
   Keepalive timeout                    3.0 seconds
Cisco Wide Area Application Services Software (WAAS)
Copyright (c) 1999-2011 by Cisco Systems, Inc.
Cisco Wide Area Application Services (accelerator-k9) Software Release 4.4.1 (build b12 May 27 2011)
Version: oe594-4.4.1.12
Compiled 08:42:00 May 27 2011 by damaster
Device Id: 50:3d:e5:9d:26:dc
System was restarted on Fri Jan 20 02:11:13 2012.
The system has been up for 23 hours, 33 minutes, 4 seconds.
CPU 0 is GenuineIntel Intel(R) Xeon(R) CPU           X3430  @ 2.40GHz (rev 30) running at 2393MHz.
CPU 1 is GenuineIntel Intel(R) Xeon(R) CPU           X3430  @ 2.40GHz (rev 30) running at 2393MHz.
CPU 2 is GenuineIntel Intel(R) Xeon(R) CPU           X3430  @ 2.40GHz (rev 30) running at 2393MHz.
CPU 3 is GenuineIntel Intel(R) Xeon(R) CPU           X3430  @ 2.40GHz (rev 30) running at 2393MHz.
Total 1 CPU, 4 CPU Cores, and 4 CPU Threads.
12288 Mbytes of Physical memory.
3968 MBytes of flash memory
2 GigabitEthernet interfaces
1 Console interface with RJ45 and mini-USB connectors
1 external USB interface
Cavium Nitrox XL NPX (CN1620) Crypto Accelerator [ OK ]
WAVE-594-K9
BIOS Information:
Vendor         :American Megatrends Inc.
Version        :A31C115A
Rel. Date      :04/27/2011
  Mainboard info:
    Model                  : OE594
    Serial Number          : FCH1535V14D
Detailed Memory Device (DIMM) configuration
        Size              Locator             Position        Serial Number
     2048 MB       CHANNELA_DIMM1             CHANNELA          00503432
     2048 MB       CHANNELA_DIMM2             CHANNELA          00503448
     2048 MB       CHANNELA_DIMM3             CHANNELA          00503439
     2048 MB       CHANNELB_DIMM1             CHANNELB          00503431
     2048 MB       CHANNELB_DIMM2             CHANNELB          00503440
     2048 MB       CHANNELB_DIMM3             CHANNELB          00503438
List of all disk drives:
b-beavers Thu, 02/16/2012 - 14:34
Your Central Manager likely says 1300 connections, correct?
johng231 Fri, 02/17/2012 - 08:44
The CM is reporting MAX connection limit 3000. My SE told me it was a BUG (CSCtr45923)
in 4.4.1, which is fixed in the newer releases. I don't have access to it to verify.
So when I upgrade, my connections are going to drop down to 1300.
