Warning message
Autoswitching of out-going calls depending on prefix
Jan 30th, 2012
Hi Team
If a tellular is plugged to a UC320W, does the UC320W caters for autoswitching capabilities between preferred network where the UC320W will be able to choose the network to dial out depending on the prefix of the dialed out number?
Please advise.
Thanking you .
Kevin
nalbert Mon, 02/06/2012 - 13:52
  • Bronze, 100 points or more
Kevin,
Prefix based routing could be used to choose between different SIP providers and FXO ports. If you have one SIP provider for cellular calls and one SIP provider for Landline calls, then you could have different prefixes for each. FXO lines cannot be individually separated though.
nalbert Tue, 02/07/2012 - 10:31
Tony,
The UC320 is not designed to do complex routing. You would need a UC540 for more advanced functionality.
