Warning message
FTP'ing A virtual Blade to back it up.
Answered Question
Jan 30th, 2012
I first tried to back it up through the CM, but was getting errors in regards to the it failing while setting the remote directory.  So i Putty'ed onto the individual wave and typed in the following:
copy ftp virtual-blade 1 disk 1 192.x.x.x(ftp server) / bladename.img
and it came back with:
This will delete the existing disk image.
Are you sure you want to proceed?
I just want to make sure that this will not delete the blade that I am trying to back up???
Correct Answer by Daniel Arrondo Ostiz about 5 years 6 months ago
Hi Dan,
You are using the wrong syntax. With this command, what you are trying to do is copying a file from a FTP server into a virtual-blade disk. That's why it's asking you whether you want to overwrite the data.
The right command to use to make a backup is "copy virtual-blade 1 disk 1 ftp 192.x.x.x(ftp server) / bladename.img"
I hope this helps
Daniel
Overall Rating: 5 (1 ratings)
Correct Answer
Daniel Arrondo Ostiz Tue, 01/31/2012 - 00:47
  • Cisco Employee,
Hi Dan,
I hope this helps
Daniel
