Upgrading from 7.0.98.0 to 7.0.220.0
Answered Question
Jan 30th, 2012
We are looking to upgrade our 5508 wireless controller from 7.0.98.0 to 7.0.220.0. Reason being, we have experienced a lot of access points disassociating from the controller as well as client authentication issues. Has anyone upgraded from 7.0.98.0 to 7.0.220.0 and experienced any issues during the upgrade or after the upgrade?
Correct Answer by Tony Davis about 5 years 2 months ago
https://supportforums.cisco.com/message/3540673#3540673
This is the original thread discussing the predownload issue.  The code upgrade goes very smoothly... it's when you get to the AP's that the problems start.  If you do not have any maintenance window restrictions, then you have no problems ahead.
Please read the above thread, it will shed a lot of light on the subject.
Rule of thumb:  If you predownload the image to the AP's and "swap" the images, if the new image doesn't show as primary, you have a problem.  When you reload the wlc's and the AP's, the AP's will rejoin and "think" they have earlier code.  they will redownload, notice I say redownload the new code... even though it already exists in flash.  Then they will reboot again.  If you/your company has no problem with this method, you'll be fine.
Tony
Overall Rating: 5 (1 ratings)
Scott Fella Mon, 01/30/2012 - 11:11
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Jason,
You should be fine. I have done that upgrade with no issues. You can also download the primary code to the access points, but I know there has been issues with that. I know there was a post recently regarding downloading the code to the AP's does not work. I don't have that link, but it's on the forum somewhere.
Scott Fella
Sent from my iPhone
Correct Answer
Tony Davis Tue, 01/31/2012 - 09:40
Tony
Inayat Bunglawala Mon, 01/30/2012 - 12:39
Hi Jason,
I upgraded eight 4404 WLC's just over two weeks ago from v7.0.98.0 to v7.0.220.0 to fix a 'DHCP_REQD' issue that we were seeing often with our guest users. The upgrade went very smoothly. Just a small footnote: If you have a WCS then you will need to upgrade this first before upgrading the WLC's.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
