New switch not working correctly
Jan 31st, 2012
I have a Catalyst 3750 switch configured in a network. I would like an additional 3750 switch as a "hot" standby.
A 2nd 3750 switch was purchased, and the same configuration was entered in to the new switch, so I have 2 switches with the exact same configuration.
When I move the connections to the new switch, I have a few VLANs that do not come up. One VLAN does come up and work normally.
The VLANs in question show down, protocol down, and a show ip route reveals routes to the networks on these VLANs are not there
When I put everything back on the original switch, everything works normally.
Why would the new switch not work with the exact same configuration?
viswamin Tue, 01/31/2012 - 09:02
For the Vlan's to come up , you have to have atleast one port on that vlan which is in up state or atleast this vlan should be in the allowed list in the trunk link between the switches.
can you pls share the configs ?
-Vijay
Dholland64 Tue, 01/31/2012 - 09:12
Here is the config. In this case, when  I move over the connections, VLAN2 comes up and is operational, but 3-10 do not come up. I believe VLAN12 came up as well
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname 3750b
no logging console
enable secret 5 XXX
no aaa new-model
clock timezone MST -7
switch 1 provision ws-c3750g-24ts-1u
track 100 interface GigabitEthernet1/0/1 ip routing
ip subnet-zero
ip routing
no ip domain-lookup
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
description WAN uplink to SonicWall
no switchport
ip address 172.23.5.2 255.255.255.0
interface GigabitEthernet1/0/2
switchport trunk allowed vlan 1-12,241
switchport mode trunk
interface GigabitEthernet1/0/3
description uplink to 7206
switchport access vlan 3
switchport mode access
interface GigabitEthernet1/0/4
spanning-tree portfast
interface GigabitEthernet1/0/5
description uplink to eCloser 1841 router
switchport access vlan 241
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
switchport access vlan 12
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
switchport trunk allowed vlan 2-12
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface Vlan1
no ip address
interface Vlan2
ip address 10.0.1.251 255.255.255.0
ip helper-address 10.0.1.4
no ip redirects
standby 2 ip 10.0.1.5
standby 2 track 100 decrement 20
interface Vlan3
ip address 172.22.3.251 255.255.255.0
no ip redirects
standby 3 ip 172.22.3.1
standby 3 track 100 decrement 20
interface Vlan4
ip address 172.22.4.251 255.255.255.0
no ip redirects
standby 4 ip 172.22.4.1
standby 4 track 100 decrement 20
interface Vlan5
ip address 172.22.5.251 255.255.255.0
no ip redirects
standby 5 ip 172.22.5.1
standby 5 track 100 decrement 20
interface Vlan6
ip address 172.22.6.251 255.255.255.0
no ip redirects
standby 6 ip 172.22.6.1
standby 6 track 100 decrement 20
interface Vlan7
ip address 172.22.7.251 255.255.255.0
no ip redirects
standby 7 ip 172.22.7.1
standby 7 track 100 decrement 20
interface Vlan8
ip address 172.22.8.251 255.255.255.0
no ip redirects
standby 8 ip 172.22.8.1
standby 8 track 100 decrement 20
interface Vlan9
ip address 172.22.9.251 255.255.255.0
no ip redirects
standby 9 ip 172.22.9.1
standby 9 track 100 decrement 20
interface Vlan10
ip address 172.22.10.251 255.255.255.0
no ip redirects
standby 10 ip 172.22.10.1
standby 10 track 100 decrement 20
interface Vlan11
ip address 172.22.11.251 255.255.255.0
no ip redirects
standby 11 ip 172.22.11.1
standby 11 track 100 decrement 20
interface Vlan12
ip address 172.22.12.251 255.255.255.0
no ip redirects
standby 12 ip 172.22.12.1
standby 12 track 100 decrement 20
interface Vlan241
ip address 172.24.1.6 255.255.255.248
no ip redirects
standby 241 ip 172.24.1.1
standby 241 track 100 decrement 20
router eigrp 1
redistribute static
network 10.0.0.0
network 172.22.0.0
network 172.23.0.0
no auto-summary
no eigrp log-neighbor-changes
ip classless
no ip forward-protocol udp tftp
no ip forward-protocol udp nameserver
no ip forward-protocol udp domain
no ip forward-protocol udp time
no ip forward-protocol udp netbios-ns
no ip forward-protocol udp netbios-dgm
no ip forward-protocol udp tacacs
ip forward-protocol udp bootpc
ip forward-protocol udp bootps
ip route 0.0.0.0 0.0.0.0 172.23.5.1
ip route 10.3.10.0 255.255.255.0 172.24.1.2
ip route 10.201.32.0 255.255.252.0 172.24.1.25
ip route 10.201.32.0 255.255.252.0 172.24.1.2 200
ip route 10.201.37.0 255.255.255.0 172.24.1.2
ip route 10.201.38.31 255.255.255.255 172.24.1.2
ip route 10.201.64.0 255.255.255.0 172.24.1.2 200
ip route 10.201.128.0 255.255.255.0 172.24.1.2 200
ip route 10.201.176.0 255.255.255.0 172.24.1.2
ip route 10.201.248.0 255.255.255.0 172.24.1.2
no ip http server
access-list 199 permit ip 0.0.0.0 255.255.255.0 host 10.0.1.7
access-list 199 deny   ip any host 10.0.1.7
access-list 199 permit ip any any
snmp-server community gMv35t=Ws%iVLc9H RO
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps stpx root-inconsistency loop-inconsistency
snmp-server host 172.22.8.101 version 2c gMv35t=Ws%iVLc9H
control-plane
line con 0
line vty 0 4
exec-timeout 60 0
password t_sfc0resw
login
line vty 5 15
password xxx
login
Leo Laohoo Tue, 01/31/2012 - 13:17
Why don't you just Stack them together?
Dholland64 Thu, 02/02/2012 - 08:16
The issue is resolved.
When the configuration was copied from the old switch, the virtual VLAN interfaces were created, however not all of the VLANs themselves were created. Creating the missing VLANs solved the problem
bikespace Thu, 02/02/2012 - 15:03
You need to create the vlan database (not shown in the config).
If you do a show vlan you will see which ones are active.
just type vlan 2 name blah blah blah for each vlan.
Edit: Ah, I see you already got there :-)
Message was edited
integreon Thu, 02/02/2012 - 15:49
Glad you fixed it:) good work
Related Content
