D/L AnyConnect-win-3.0 from 5505 ASA / Web deployment
Feb 1st, 2012
Hi Folks,
The Specs,
Win 7
ASA 5505
AnyConnect-win-3.0.3054-k9.pkg
Attempting Web Deployment
I'm working with the ASA and a directly connected laptop running Win 7 and I'm trying to configure the AnyConnect client to download and install. I have used these before, just never with webVPN.  I'm using local authentication on the ASA. When I point IE9 to the ASA I get the login prompt and the option to select from which group. Here's where the problem starts....
When I go to the VPN webpage and login with a known good username and password nothing happens. It just brings me right back to the login screen. No errors appear. When I run "show vpn-sessiondb" on the ASA it does show that there is a session. ( I have the default 2 max connections). But I never get the ActiveX to start the d/l. of the client. Every seond time I attempt this I have to go into the asa and disconnect the 2 sessions.
My users have full 15 permissions and I have gone through the connection wizard a few times. I have also worked through the Cisco Guide located here --> http://www.cisco.com/en/US/docs/security/vpn_client/anyconnect/anyconnect30/administration/guide/ac02asaconfig.html
Any thoughts ?
John
jcarbonette Wed, 02/01/2012 - 08:12
So as it turns out, This setup work ok on Win XP. I tested this with another XP laptop. I was able to connect and d/l the client through ActiveX.
Now my issue is that when I run the wizard and un-check the SSL protocol, leaving only IPSEC I get an error saying
"The secure gateway has rejected the connection attempt. A new connection attempt to the same or another secure gateway is needed, which requires re-authentication. The following message was received from the secure gateway: CSTP is not enabled".
I have googled CSTP and cannot find anything on this? Anyone guide me in the right direction?
thomasdupont Thu, 05/17/2012 - 09:01
I am having the exact same issue. Did you ever find any additional information regarding this problem?
COR WEIJ Fri, 09/27/2013 - 02:33
I resolved it now for us.
In the Server list entry in the ANY connect client profile the Host Address was filled in with an IP number.
I changed that to the FQDN and as of that moment the connection succeeds.
COR WEIJ Fri, 09/27/2013 - 01:55
I have the same problem. I can't find any inormation about this error. The only thing I found is that CSTP is a proprietary Cisco protocol. But ther isn't any solution mentioned. I'm searching for it more than a week now.
Does anybody have a solution, please !!!
Related Content
