Phone resets ip every 2 minutes
David Graham
I have 7940 and 7960 phones that are connected to a Cisco switch and the phones are working correctly. I have to integrate with a new business partner who is using new HP switches so I cannot get rid of them. When I plug in the phone to the switch everything is glorious and the phone works and I can call in and out.
I plug a laptop or desktop into the switch port on the back of the phone and things go weird.  The laptop will keep working without a problem but the phone will lose its IP address, unregisters from Call Manager, and start to search for a new one. The laptop keeps working fine and a ping -t or file copies keep on wokring. It only appears that the phone loses itself. Has anyone ever seen this happen? Has anyone worked with the HP switches and had this go thorugh without a problem?
Phone: 7940 or 7960
Call Manager: 7.1
Switch type: H3C S5800
Thanks much.
David Graham
I should add the the port configuration on the H3C is
interface GigabitEthernet1/0/35
port link-mode bridge
description Test port
port link-type hybrid
undo port hybrid vlan 1
port hybrid vlan 30 tagged
port hybrid vlan 3 untagged
port hybrid pvid vlan 3
undo voice vlan mode auto
voice vlan 30 enable
poe enable
stp edged-port enable
lldp compliance admin-status cdp txrx
qos trust dscp
Thanks again!
